lcasadonte 3 Posted August 28, 2016 Posted August 28, 2016 Is there a way to do this, even if its just a color coded icon (red, yellow, green)?
Guest asrequested Posted August 28, 2016 Posted August 28, 2016 There is a way to see your signal strength using the HDHR software
lcasadonte 3 Posted August 28, 2016 Author Posted August 28, 2016 but only through that software right? I think signal strength is available via the api if i remember right and there was a way to incorporate the api result into a guide in kodi if i remember right but was hoping to see when signals shift in and out dynamically in the guide itself. Like bad weather days you could see the degradation of the signal in the guide.
Guest asrequested Posted August 28, 2016 Posted August 28, 2016 but only through that software right? I think signal strength is available via the api if i remember right and there was a way to incorporate the api result into a guide in kodi if i remember right but was hoping to see when signals shift in and out dynamically in the guide itself. Like bad weather days you could see the degradation of the signal in the guide. You should post that in the feature request thread. Maybe others would like it, too.
lcasadonte 3 Posted August 28, 2016 Author Posted August 28, 2016 Ok just wanted to make sure it wasn't a user issue but couldn't find anything searching so I thought I would ask. Thanks for your help.
