PenkethBoy 2068 Posted August 27, 2016 Posted August 27, 2016 Hi Having an issue with Genre Cleaner to do with Music Genres When i pick the Music option under settings > click Initialise - i only get one genre - comedy (irony alert!) i have checked my music library and as you would expect i have lots Now what might be throwing the plugin off is that i have three music libraries (Audio Books, Music, Podcasts) Audio Books only has two genres "Audio Book" and "Comedy" - Music and Podcast do not have comedy as a Genre So 1) Why is the plugin only picking up one library - limitation? bug? 2) Why only picking up one genre instead of two? Seams to work for tv shows and movies but i only have one library of each Windows Pro 10, 3.1.6082.28134 and plugin 1.0.1.8 Thanks
ebr 16340 Posted August 27, 2016 Posted August 27, 2016 To do the initial population for music genres it asks the server for all genres associated with Albums. So, is it possible that your genres are defined somewhere other than the Albums or that, somehow, your setup isn't producing albums?
PenkethBoy 2068 Posted August 28, 2016 Author Posted August 28, 2016 All three Libraries have albums Album Libraries Audio Books - 29 Music - 376 Podcasts - 14 When viewing the library and you choose the genre option they appear as expected Not sure how i would define them in a differnt place as the information was populated by the server scans - was going to use this plug in to map some genres as i have done for tv and movies if you need more info or logs let me know
Happy2Play 9814 Posted August 28, 2016 Posted August 28, 2016 All three Libraries have albums Album Libraries Audio Books - 29 Music - 376 Podcasts - 14 When viewing the library and you choose the genre option they appear as expected Not sure how i would define them in a differnt place as the information was populated by the server scans - was going to use this plug in to map some genres as i have done for tv and movies if you need more info or logs let me know Okay what is the physical structure of your Music? Emby reacts to folder structure in different ways. Music Artist Album Track
ebr 16340 Posted August 28, 2016 Posted August 28, 2016 Try the beta version of the plug-in and see if it will populate your initial music genres. You may need to be patient...
PenkethBoy 2068 Posted August 29, 2016 Author Posted August 29, 2016 (edited) yes i have the standard structure for music podcasts and audio books sorry where would i find the beta plugin? - ah figured this out now Just updated my server to latest dev and 1.0.1.9 was installed but no difference in behaviour still only comedy shown Edited August 29, 2016 by PenkethBoy
Happy2Play 9814 Posted August 29, 2016 Posted August 29, 2016 @@ebr This can be replicated. OT: Tested on Dev and Beta servers. Sometimes you have refresh the page to get "initialize" button. 1
Happy2Play 9814 Posted August 29, 2016 Posted August 29, 2016 Refreshing 3 different are Artists made no difference.
ebr 16340 Posted August 29, 2016 Posted August 29, 2016 Can someone post a server log from when they did the initialize with the beta version of the plugin?
Happy2Play 9814 Posted August 29, 2016 Posted August 29, 2016 (edited) @@ebr here you go, went through initialize and save for Music (timestamp 2016-08-28 22:21:42.3781). Deleted the config xml afterwards. Edited August 29, 2016 by Happy2Play
PenkethBoy 2068 Posted August 29, 2016 Author Posted August 29, 2016 Here is my log as well around 10:44:23 is when i initialise the cleaner if you need more info happy to help
ebr 16340 Posted August 29, 2016 Posted August 29, 2016 Luke, here is the query they have returning only a couple of random entries. See anything obvious? Guys - does the user running the dash have access to all the libraries? /emby/Genres?SortBy=SortName&SortOrder=Ascending&IncludeItemTypes=MusicAlbum,Audio,MusicArtist&Recursive=true&StartIndex=0&userId=06d517a29e044718816b34ce7f76c674. UserAgent: Mozilla/5.0 (Windows NT 10.0; Win64; x64) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/53.0.2785.80 Safari/537.36
ebr 16340 Posted August 29, 2016 Posted August 29, 2016 Also, Happy, can you try doing this with the browser's console window up so we can be sure something isn't failing at the js level?
PenkethBoy 2068 Posted August 29, 2016 Author Posted August 29, 2016 yep my user has full access as i only have one user on this server and all the genres are visible in the library view
Happy2Play 9814 Posted August 29, 2016 Posted August 29, 2016 Full access also and nothing failing in console.
PenkethBoy 2068 Posted August 29, 2016 Author Posted August 29, 2016 (edited) as i am about to rebuild my library i just deleted the audio book library the one with the comedy genre - re scaned and cleaned the db when i access the plugin now i get "no genres found" popup at the bottom of the screen console below possibly not related but if i search for a music genre from the home screen they do appear in the search results - but appear as MusicGenre - but film movie genres are listed as just genre not moviegenre when search for Edited August 29, 2016 by PenkethBoy
PenkethBoy 2068 Posted August 30, 2016 Author Posted August 30, 2016 (edited) As i am rebuilding my server today i just tested with one music library and it failed with no genre found as with two - so likely multiple music libraries not the issue [edit] Have just started rebuilding my database shut down the server deleted the old library.db and rebooted to a clean database set up one music library (of music albums) and tried the plugin again - came up with no genres found even though they exist via genres page of the music library Edited August 30, 2016 by PenkethBoy
Happy2Play 9814 Posted August 31, 2016 Posted August 31, 2016 Almost like something was cached. First time I initialized I Musical again so I clicked the x to remove it and initialized again and all is well. See all 16 genres from my collection. v1.0.2.0
PenkethBoy 2068 Posted August 31, 2016 Author Posted August 31, 2016 Thanks you appears to be working well and with three music libraries 1
