Angelblue05 4132 Posted August 30, 2016 Posted August 30, 2016 (edited) I can't explain it. But it's definitely not an Emby for Kodi issue. The job of the add-on is to provide the path to Kodi. It's done that, it's not involved in anything else pass that. Kodi is unable to open the file - Didn't work: 18:42:06 T:140669750331136 ERROR: CDVDPlayer::OpenInputStream - error opening [/share/TV Shows/Suits/Season 6/Suits.S06E03.Back.on.the.Map.WEBDL-1080p.mkv] Kodi is able to open the file - Did work: 18:41:35 T:140672681084928 NOTICE: DVDPlayer: Opening: /share/TV Shows/Suits/Season 5/Suits.S05E15.Tick.Tock.WEBDL-1080p.mkv Can you try the following: Go to Kodi settings > add-ons > install from zip. Navigate to the season 6 folder. Does Kodi throws an error or does it open the folder (you won't see the content which is normal)? Let me know and we'll go from there. From a different device, is the folder accessible? Edited August 30, 2016 by Angelblue05
838Joel 63 Posted August 30, 2016 Author Posted August 30, 2016 Did that, and working to access the path for both season
838Joel 63 Posted August 30, 2016 Author Posted August 30, 2016 I'm looking now on the Emby server logs... At some point I see that: 2016-08-29 18:41:11.0174 Debug Dlna: Found matching device profile: Kodi 2016-08-29 18:41:11.0182 Debug Dlna: Found matching device profile: Kodi Later I see that: 2016-08-29 18:46:36.7407 Info Dlna: No matching device profile found. The default will need to be used. So, I check my configuration, and the user set now was HTPC, but I did put that probably when I did re-install everything.... I can recall that the user was Kodi before! So I change it back to Kodi (Server and addon) in the configurations.... Now forcing a repair on the Kodi/addons DB, and I will see if that change something! BRB
838Joel 63 Posted August 30, 2016 Author Posted August 30, 2016 Same situation: On Season 6 I have this: 2016-08-29 21:19:20.2485 Info Dlna: No matching device profile found. The default will need to be used. Host: 192.168.100.50:8096 Connection: close Is that relevant? I don't know! I don't get it, I did re-install everything so many times, unless it's related to DB on the server, corrupted? Is un-install and re-install Emby server remove and re-create the DB? If not, then probably garbage from the old DB still!!!
Angelblue05 4132 Posted August 30, 2016 Posted August 30, 2016 (edited) Dlna has nothing to do with the add-on. It's just a different way to access server content in Kodi with less options. Your issue is not server related either. Kodi is unable to open the file. So it's most likely something related to your environment and those specific files. Is it something you are able to do, reset the permissions on those files and re-apply them, in case something funky is going on. Maybe move one file to season 5 to see if it's then playable. The big question is why would it play everything correctly, except those files. This is why I'm so insisting on this. Unless you tell me all your new episodes in every show added does not work? But if I go via SMB directly on the remote server, it's there and work... Can you expand on what this means exactly and how is it relevant to the situation? Can you also confirm you are able to playback those files in the Emby webclient for example? Edited August 30, 2016 by Angelblue05
838Joel 63 Posted August 30, 2016 Author Posted August 30, 2016 Going to sleep now, but I will continu investigationg tomorrow... And thanks for you help, it's really appreciated... But to your last question, today I tried to play Season 5 on my Android phone having Kodi... And strangely it was not playing! Anyway I'll do more testing tomorrow by moving files, etc... Will let you know for sure! 1
Angelblue05 4132 Posted August 30, 2016 Posted August 30, 2016 (edited) Your paths are probably not network paths, is this correct? For now, you can probably play your content using http by going to the add-on settings > playback > enable Play from HTTP. Anyway, I'll be around to help. Edited August 30, 2016 by Angelblue05
838Joel 63 Posted August 30, 2016 Author Posted August 30, 2016 Angelblue05, to respond to one of your question The big question is why would it play everything correctly, except those files. This is why I'm so insisting on this. Unless you tell me all your new episodes in every show added does not work? Yes all my new episodes in every show added are not working... BUT, why all new movies are working? Also, yes my path for shows or movies is not a network path, but direct /share/TV Shows or /share/Movies... Anyhow, I did put the setting about playing it thru http instead of SMB... And now all TV Shows episodes are working.... 1
breezytm 124 Posted August 30, 2016 Posted August 30, 2016 (edited) Angelblue05, to respond to one of your question Yes all my new episodes in every show added are not working... BUT, why all new movies are working? Also, yes my path for shows or movies is not a network path, but direct /share/TV Shows or /share/Movies... Anyhow, I did put the setting about playing it thru http instead of SMB... And now all TV Shows episodes are working.... Use path substitution my friend. Would make your life much easier. - I think that should be a step when creating a library in emby with the option to skip it if the user chooses not to do it. P.S I really did think Suits season 6 stopped working because it is really trash Edited August 30, 2016 by breezytm
838Joel 63 Posted August 30, 2016 Author Posted August 30, 2016 Breezytm, I did use that path substitution before, and kind of not work out!!! Did change to \\Server\TV Shows\ and did not help. If that was only because of the Show Suits, I would agree, but other shows are affected as well.... Like they say, happy wife, happy life!
Angelblue05 4132 Posted August 30, 2016 Posted August 30, 2016 Are you able to access the Kodi userdata, is there a passwords.xml file? If so, edit the file and delete anything that would have to do with where your content is located. http://kodi.wiki/view/userdata
838Joel 63 Posted August 30, 2016 Author Posted August 30, 2016 (edited) There is multiple folder named "userdata", but the first I look into is having indeed a password.xml. What should I do, because basically here what it contain: <passwords> <path> <from pathversion="1">smb://192.168.100.50/</from> <to pathversion="1">smb://Joel:mypassword@192.168.100.50/</to> </path> <path> <from pathversion="1">smb://SUBCONSCIOUS/TV Shows</from> <to pathversion="1">smb://Joel:mypassword@SUBCONSCIOUS/TV Shows/</to> </path> </passwords> My server Subconscious is 192.168.100.50. Should I empty it all and just keep <passwords></passwords> ? This is my two password files that are the same inside: ./share/CACHEDEV1_DATA/.qpkg/KODI/root/.kodi/userdata/passwords.xml ./share/CACHEDEV1_DATA/.qpkg/HD_Station/share/CACHEDEV1_DATA/.qpkg/KODI/root/.kodi/userdata/passwords.xml Edited August 30, 2016 by 838Joel 1
Angelblue05 4132 Posted August 30, 2016 Posted August 30, 2016 (edited) Remove both, just keep the <passwords></passwords> By the way, is Kodi located on the same device as where your server is located? You can try to disable play from HTTP to see if it's able to playback directly. Let me know. Edited August 30, 2016 by Angelblue05
838Joel 63 Posted August 30, 2016 Author Posted August 30, 2016 Will do shortly... No, I have two NAS server like I mentionned in my first post. NAS1 have QMono and Emby server, nad my NAS2 have the Kodi on it.
838Joel 63 Posted August 30, 2016 Author Posted August 30, 2016 well I edit the first one, and both passwords.xml file changed!!!! Strange, because I don<t see any link between those files
838Joel 63 Posted August 30, 2016 Author Posted August 30, 2016 okay I found the link: [/share/CACHEDEV1_DATA/.qpkg/HD_Station/root] # ls -lalrwxrwxrwx 1 admin administ 43 Aug 30 10:54 .kodi -> /share/CACHEDEV1_DATA/.qpkg/KODI/root/.kodi/
Angelblue05 4132 Posted August 30, 2016 Posted August 30, 2016 (edited) Ok, you'll need path substitution in Emby to get this to work most likely. How about you do a path substitution using from: /share/ to: \\192.168.100.50\ Enter the network credentials in the add-on settings > playback. Server name will be the IP address, user: Joel, and the password to go with it. Restart Kodi. Then, try disabling play from HTTP, to test out direct play using the path substitution. Let me know. Edited August 30, 2016 by Angelblue05
838Joel 63 Posted August 30, 2016 Author Posted August 30, 2016 Okay, did all that, but I had to stop Qmono & Emby and restart them on NAS1... Then start back Kodi on NAS2, tested and all is working without the http->smb checked! I can see my passwords.xml file look like this now <passwords> <path> <from pathversion="1">smb://192.168.100.50/</from> <to pathversion="1">smb://Joel:mypassword@192.168.100.50/</to> </path> </passwords> And of course I did substitute /share/ to \\192.168.100.50\ on the Emby server library itself... This is good news, but I still wonder why it was partially working before with old downloaded TV Shows and not the new one... And moreover why this was not the case for old movies vs new movies that was always working... Mystery here! 1
Angelblue05 4132 Posted August 30, 2016 Posted August 30, 2016 (edited) Truly a mystery, I agree. Well, glad it's resolved. Hopefully moving forward, everything will remain working. What was weird in your previous passwords.xml - is that you had one set up for TV Shows exclusively, and it was missing a slash, meaning when Kodi would try to apply the substitution for the password, there was a double slash like: smb://user:pass@servername//TV Shows - Maybe it came into play somehow? Edited August 30, 2016 by Angelblue05
838Joel 63 Posted August 30, 2016 Author Posted August 30, 2016 Maybe! Thanks for your help all the way long! Really appreciated! 1
Luke 42239 Posted September 29, 2017 Posted September 29, 2017 We have a new QNAP package available for testing: https://emby.media/community/index.php?/topic/51334-new-qnap-package-for-testing/ Unlike the current package in the QNAP community, this is built by the Emby Team and will be tested and supported by us. It is also built with the new .NET Core runtime from Microsoft, which has major performance improvements over the mono runtime used by the community package. Please try it out if interested in helping us test it. Thanks !
