SwanStream 64 Posted August 25, 2016 Posted August 25, 2016 Scenario: I split my HTPC's HDMI signal to several locations, only one of which can handle more than two channel audio. I've configured the EDID so the HTPC thinks all locations are capable of everything, which is the way I need it so I can use the max available at any location. To make audio work in MOST locations I've got Kodi set to 2 channel audio and all is good for the most part... if I'm sittin there watchin stuff and decide to watch something on the "big screen" then as it starts I simply go to audio and tick the box for direct sound and suddenly all the magic of multi-channel DTS comes screamin out the speakers and things are right with the world. Other locations may (or may not) have full spectrum sound based on their own audio decoding capabilities, but I don't care since I'm parked infront of Big Betty. But later, when I've moved to another location and I'm watching something with a multichannel track on a TV without 'smarts' on board to re-encode that to 2 channel, I'm left with left/right sounds and missing center-channel (i.e. dialog). Fixable by going to audio and unticking that same box. Not a big deal, but.... I'm not sure if this should be a feature request, but seems to me that the menu that appears at the bottom of the screen when playing something should be "till I move away from this track" i.e. only applies till show ends or I hit stop, then settings revert to the configuration I've set at the base of the application. I believe that's the case with audio delay, subtitles and a few other settings, but for some reason the direct sound setting is affecting the univeral configuration rather than current session. Anyone have thoughts on that?
xnappo 1611 Posted August 26, 2016 Posted August 26, 2016 I don't see how this is an Emby for Kodi request? It is completely just a Kodi thing. 1
Solution SwanStream 64 Posted August 26, 2016 Author Solution Posted August 26, 2016 I don't see how this is an Emby for Kodi request? It is completely just a Kodi thing. Ya know, integration is so solid these days I plum forgot Kodi is it's own "thing"!! You guys have done a great job making it a very solid front-end. I'll move my discussion there. Apologies for the clutter! 1
