josejavier_cu 0 Posted January 8, 2024 Posted January 8, 2024 Hace 1 minuto, Lucas dijo: Hola, que firewall, windows? Si desea continuar así, deberá configurarlo. ¿Ha comprobado si hay alguna regla que bloquee el servidor emby? Yes, Im using Windows, but using SimpleWall as a firewall. I have always been using it without a firewall because it is on a LAN and I really didn't need it much, but I want to prevent Emby from automatically showing up in "Network Locations" on other Windows computers. I don't know if there is a simpler solution, so I decided to use a firewall. Blocking port 8096 and making a white list of IPs that I want them to access worked for me, it's just that checking the TV doesn't show them to me. I dont know if I explained well.
Luke 42237 Posted January 13, 2024 Posted January 13, 2024 On 1/8/2024 at 6:44 PM, josejavier_cu said: Yes, Im using Windows, but using SimpleWall as a firewall. I have always been using it without a firewall because it is on a LAN and I really didn't need it much, but I want to prevent Emby from automatically showing up in "Network Locations" on other Windows computers. I don't know if there is a simpler solution, so I decided to use a firewall. Blocking port 8096 and making a white list of IPs that I want them to access worked for me, it's just that checking the TV doesn't show them to me. I dont know if I explained well. OK can you start with 1900 UDP port. Does that get things going?
