horstepipe 423 Posted August 24, 2016 Posted August 24, 2016 hey just a small general question: When does the plugin fetch new trailers? As soon as I press the trailers button? on library scan on the "refresh channels" task ...? regards
CBers 7557 Posted August 24, 2016 Posted August 24, 2016 It doesn't "fetch" trailers, just locates online ones. There should be a task in Scheduled Tasks - might be via the Refresh channels one. If you want trailers downloaded, then you need to use a 3rd-party plugin, such as @@radeon's YTrailer plugin. 1
horstepipe 423 Posted August 24, 2016 Author Posted August 24, 2016 nope don't want them to be downloaded. Just wondering when the list will be refreshed.
