bieltan 0 Posted January 12, 2014 Posted January 12, 2014 Greetings Community, I've been searching for a while now and not sure whats going on. I have a server setup on my Windows 7 machine and it streams fine to all of the following devices: Laptop, Samsung Nexus However it does not stream at all to my Rikomagic 802 IIIS. It opens up fine, "loads" the video's fine but will just sit with a black screen once you press play. It displays the movie controls and the movie poster in the corner. The Riko has Android 4.2.2 and the MediaBrowser is the most recent build provided by GoogleApps. This was streaming fine when I first purchased the Riko, however terribly due to bad wireless signal. So I purchased a lan adapter to get a better connection to the Riko. I also changed the MediaBrowser running ports on the server for security reasons. I tested on both my phone and laptop after I opened the ports on my firewall and it streams fine, but the Riko just gets stuck at 00:00. No updates were done to the MediaBrowser or android between it "working" and now. The Riko plays Netflix fine and Speedtest results: D 1.08 Mbps/ U 0.64 Mbps (not great but enough to stream). I've tested multiple shows/movies on both the Riko and my laptop, same results (Riko fails, laptop streams fine). Thoughts?
Redshirt 1487 Posted January 12, 2014 Posted January 12, 2014 In the Android client, try going into the settings and disable "HLS support". See if that helps.
Luke 42241 Posted January 12, 2014 Posted January 12, 2014 stinks that you can't query the device to determine if it can support that.
Redshirt 1487 Posted January 12, 2014 Posted January 12, 2014 I know. The android ecosystem is just too big to add per-device excludes too. What I really need to do is detect a failed hls playback in code and fall back to non-hls .ts or even .webm. It's unfortunate that hls works on every device I own.
bieltan 0 Posted January 14, 2014 Author Posted January 14, 2014 Turns out HLS Support was already disabled. So I re-enabled it, this allowed for the streaming to start up. However, it was still loading every 10 seconds or so. This leads me to believe it may have to do with the Riko since I streamed fine to my laptop, unless you have any other suggestions?
Redshirt 1487 Posted January 14, 2014 Posted January 14, 2014 If it plays with hls enabled, which is the preferred setting, but is buffering then I'd look at your bitrate values. They are likely too high for the given connection. Either that of the server can't transcode the media fast enough.
bieltan 0 Posted January 21, 2014 Author Posted January 21, 2014 Editing bitrate values can be done within a media decoder such as FFDshow correct? (correct me if I'm wrong - very new to this and learning). However, if I were to lower the bitrate of streaming files, wouldn't that downgrade the bitrate to every device that streams media through my server?
BATTLE DONKEY 98 Posted January 21, 2014 Posted January 21, 2014 Editing bitrate values can be done within a media decoder such as FFDshow correct? (correct me if I'm wrong - very new to this and learning). However, if I were to lower the bitrate of streaming files, wouldn't that downgrade the bitrate to every device that streams media through my server? I believe u can lower the bit rate for just the android app in the MBAndroid settings, where u found the hls toggle switch
Redshirt 1487 Posted January 21, 2014 Posted January 21, 2014 You can do that, but as you say it permanently alters the media bitrate and quality. When I say look at the bitrate values though, I'm referring to inside the android client. Just lowering them to something that doesn't stutter. They may be set to higher than your connection can provide. I'd also look at the server ffmpeg logs stored in the servers logs folder and make sure the fps= values in the transcode aren't lower than the source framerate. If the server isn't sending the media fast enough the client will have no choice but to pause and buffer.
bieltan 0 Posted January 22, 2014 Author Posted January 22, 2014 You can do that, but as you say it permanently alters the media bitrate and quality. When I say look at the bitrate values though, I'm referring to inside the android client. Just lowering them to something that doesn't stutter. They may be set to higher than your connection can provide. I'd also look at the server ffmpeg logs stored in the servers logs folder and make sure the fps= values in the transcode aren't lower than the source framerate. If the server isn't sending the media fast enough the client will have no choice but to pause and buffer. Excellent. I'll give this a shot. (again thanks so much for the assistance).
bieltan 0 Posted January 23, 2014 Author Posted January 23, 2014 You can do that, but as you say it permanently alters the media bitrate and quality. When I say look at the bitrate values though, I'm referring to inside the android client. Just lowering them to something that doesn't stutter. They may be set to higher than your connection can provide. I'd also look at the server ffmpeg logs stored in the servers logs folder and make sure the fps= values in the transcode aren't lower than the source framerate. If the server isn't sending the media fast enough the client will have no choice but to pause and buffer. It worked! Thanks again!
