tigrao 18 Posted August 23, 2016 Posted August 23, 2016 I have been trying to get to the bottom of a problem that completely incapacitates my server. My server's interface is non-responsive and the Emby web client takes almost ten minutes to load. When I could finally get task manager to come up I can see that I have over 140 ffmpeg processes running. In my server log I see over and over lines similar to this: 2016-08-23 10:42:56.9220 Info MediaEncoder: Killing ffmpeg process 2016-08-23 10:42:57.9121 Error MediaEncoder: ffmpeg image extraction failed for file:"D:\Recorded TV\Wild Kratts_KBYUDT_2016_08_22_18_28_00.wtv" 2016-08-23 10:42:57.9121 Error MediaEncoder: I-frame image extraction failed, will attempt standard way. Input: file:"D:\Recorded TV\Wild Kratts_KBYUDT_2016_08_22_18_28_00.wtv" 2016-08-23 10:43:08.3129 Info MediaEncoder: Killing ffmpeg process 2016-08-23 10:43:09.3131 Error MediaEncoder: ffmpeg image extraction failed for file:"D:\Recorded TV\Transformers Rescue Bots_DFCHD_2016_08_13_06_28_00.wtv" 2016-08-23 10:43:09.3131 Error MediaEncoder: I-frame image extraction failed, will attempt standard way. Input: file:"D:\Recorded TV\Transformers Rescue Bots_DFCHD_2016_08_13_06_28_00.wtv" 2016-08-23 10:43:20.7540 Info MediaEncoder: Killing ffmpeg process 2016-08-23 10:43:21.7541 Error MediaEncoder: ffmpeg image extraction failed for file:"D:\Recorded TV\Super Why!_KUEDDT_2016_05_10_10_58_00.wtv" 2016-08-23 10:43:21.7541 Error MediaEncoder: I-frame image extraction failed, will attempt standard way. Input: file:"D:\Recorded TV\Super Why!_KUEDDT_2016_05_10_10_58_00.wtv" 2016-08-23 10:43:34.8152 Info MediaEncoder: Killing ffmpeg process 2016-08-23 10:43:35.8153 Error MediaEncoder: ffmpeg image extraction failed for file:"D:\Recorded TV\Super WHY!_KUEDH_2016_03_16_10_58_17.wtv" 2016-08-23 10:43:35.8153 Error MediaEncoder: I-frame image extraction failed, will attempt standard way. Input: file:"D:\Recorded TV\Super WHY!_KUEDH_2016_03_16_10_58_17.wtv" Yes, I record a lot of kids shows. I've gone in and tried to turn off metadata settings, but that doesn't seem to be helping anything. How can I keep my server from being taken hostage by ffmpeg processes trying to extract images?
Luke 42186 Posted August 24, 2016 Posted August 24, 2016 It looks like some image extractions failed and hung and got stuck in a state that prevented us from killing them. This is very rare, I haven't seen it happen in a couple years. Make sure to turn off the screen grabber for all types, not just movies, notice the dropdown at the top of that screen. thanks.
tigrao 18 Posted August 24, 2016 Author Posted August 24, 2016 I killed those 140 processes and then went through all of the media types. There were some that were not turned off on music and home videos I think it was. The problem hasn't come back in the last six hours. I will check again tomorrow. Sent from my iPhone using Tapatalk
Luke 42186 Posted August 24, 2016 Posted August 24, 2016 Double check them. make sure to click save after each one. Thanks for your patience.
