solabc16 379 Posted September 1, 2016 Posted September 1, 2016 Hello @@horstepipe I've just published 3.1.130.0-1-beta on the beta channel, if you could run the timing tests above once you have this update installed, that would be useful. Thanks - James
Happy2Play 9811 Posted September 1, 2016 Posted September 1, 2016 This topic is specific to Synology, correct?
horstepipe 423 Posted September 1, 2016 Author Posted September 1, 2016 This topic is specific to Synology, correct? yes, sorry.
horstepipe 423 Posted September 1, 2016 Author Posted September 1, 2016 Hello @@horstepipe I've just published 3.1.130.0-1-beta on the beta channel, if you could run the timing tests above once you have this update installed, that would be useful. Thanks - James sure: real 8.45 user 11.83 sys 0.08
solabc16 379 Posted September 1, 2016 Posted September 1, 2016 This topic is specific to Synology, correct? Hello @@Happy2Play Yes, if you have the power, then please move this to the Synology forum, were it would be better placed. Best - James
solabc16 379 Posted September 1, 2016 Posted September 1, 2016 Hello @@horstepipe I've just published 3.1.130.0-2-beta on the beta channel, if you could run the timing tests again once you have this update installed, that would be great.Thanks- James
horstepipe 423 Posted September 1, 2016 Author Posted September 1, 2016 Hello @@horstepipe I've just published 3.1.130.0-2-beta on the beta channel, if you could run the timing tests again once you have this update installed, that would be great. Thanks - James sure :-) real 7.64 user 10.82 sys 0.11
solabc16 379 Posted September 1, 2016 Posted September 1, 2016 Thanks, could you run it a few times so we can get an average, then try running the chapter image extraction to see how it runs. -James
horstepipe 423 Posted September 1, 2016 Author Posted September 1, 2016 real 6.80 user 10.83 sys 0.02 real 6.80 user 10.83 sys 0.09 real 6.71 user 10.78 sys 0.13 real 6.78 user 10.78 sys 0.09 real 6.76 user 10.83 sys 0.06 real 6.65 user 10.81 sys 0.07 ok I'll try. Will the movies which failed before processed again or are they marked kind of finished in Emby? Same question for the half processed movies. If so, how can I reset all chapter images?
Happy2Play 9811 Posted September 1, 2016 Posted September 1, 2016 Well on Windows they are stored by movieid in "Emby-Server\Metadata\library" subfolders. example Emby-Server\Metadata\library\00\000eca2aa41b5a1766eb575847eb0914
horstepipe 423 Posted September 1, 2016 Author Posted September 1, 2016 Well on Windows they are stored by movieid in "Emby-Server\Metadata\library" subfolders. example Emby-Server\Metadata\library\00\000eca2aa41b5a1766eb575847eb0914 thanks, so simply delete all "chapters" folders should do the trick I hope
horstepipe 423 Posted September 1, 2016 Author Posted September 1, 2016 Thanks, could you run it a few times so we can get an average, then try running the chapter image extraction to see how it runs. -James that was way too fast I think I'll have to delete the chapters folders first.
horstepipe 423 Posted September 1, 2016 Author Posted September 1, 2016 mhh the images are still available although I removed the folders. Guess they're cached somewhere, hope the movies are being processed anyway.
horstepipe 423 Posted September 1, 2016 Author Posted September 1, 2016 ok looks like it is starting from scratch now.
horstepipe 423 Posted September 1, 2016 Author Posted September 1, 2016 Ok, keep us posted... - James here a preliminary result at 4%:
horstepipe 423 Posted September 3, 2016 Author Posted September 3, 2016 Ok, keep us posted... - James ok here we go: The chapter-failures.txt contains all movies which fail (makes sense :-) ) So the movies without chapters at all and the movies where only the first chapters were processed are listed there. I have 436 of 1031 failed movies, that's still quite a lot I think. Looks like almost all of my HD movies failed. I'm gonna pick some of these and post media info and log snippet here.
horstepipe 423 Posted September 3, 2016 Author Posted September 3, 2016 I skipped the ones with Writing application : mkvmerge v2.9.0 ('Moanin'') built on May 22 2009 17:46:31 Writing library : libebml v0.7.7 + libmatroska v0.8.1 will fire them through mkvtoolnix and look if they work then.
horstepipe 423 Posted September 3, 2016 Author Posted September 3, 2016 (edited) I tried a Writing application : mkvmerge v2.9.0 ('Moanin'') built on May 22 2009 17:46:31 Writing library : libebml v0.7.7 + libmatroska v0.8.1 movie with mkvtoolnix (standard settings) Now it's: General Unique ID : 233591176725227285863944400525957325982 (0xAFBC0631F83C0C289F9CF215409CE49E) Complete name : W:\Filme\12 Monkeys (1995)\12 Monkeys.1080p.bluray.dca (1).mkv Format : Matroska Format version : Version 4 / Version 2 File size : 12.0 GiB Duration : 2 h 9 min Overall bit rate : 13.3 Mb/s Encoded date : UTC 2016-09-03 14:26:13 Writing application : mkvmerge v9.4.0 ('Knurl') 64bit Writing library : libebml v1.3.4 + libmatroska v1.4.5 Video ID : 1 Format : AVC Format/Info : Advanced Video Codec Format profile : High@L4.1 Format settings, CABAC : Yes Format settings, ReFrames : 5 frames Codec ID : V_MPEG4/ISO/AVC Duration : 2 h 9 min Bit rate : 10.3 Mb/s Width : 1 904 pixels Height : 1 064 pixels Display aspect ratio : 16:9 Frame rate mode : Constant Frame rate : 23.976 (24000/1001) FPS Color space : YUV Chroma subsampling : 4:2:0 Bit depth : 8 bits Scan type : Progressive Bits/(Pixel*Frame) : 0.212 Stream size : 9.31 GiB (77%) Writing library : x264 core 65 r1074M b6bb3d4 Encoding settings : cabac=1 / ref=5 / deblock=1:0:0 / analyse=0x3:0x113 / me=hex / subme=6 / psy_rd=1.1:1.0 / mixed_ref=1 / me_range=16 / chroma_me=1 / trellis=1 / 8x8dct=1 / cqm=0 / deadzone=21,11 / chroma_qp_offset=-4 / threads=3 / nr=0 / decimate=0 / mbaff=0 / bframes=3 / b_pyramid=1 / b_adapt=2 / b_bias=0 / direct=3 / wpredb=1 / keyint=250 / keyint_min=25 / scenecut=40(pre) / rc=2pass / bitrate=10300 / ratetol=1.0 / qcomp=0.60 / qpmin=5 / qpmax=51 / qpstep=4 / cplxblur=20.0 / qblur=0.5 / ip_ratio=1.40 / pb_ratio=1.30 / aq=1:0.40 Default : Yes Forced : No Audio #1 ID : 2 Format : DTS Format/Info : Digital Theater Systems Mode : 16 Format settings, Endianness : Big Codec ID : A_DTS Duration : 2 h 9 min Bit rate mode : Constant Bit rate : 1 509 kb/s Channel(s) : 6 channels Channel positions : Front: L C R, Side: L R, LFE Sampling rate : 48.0 kHz Frame rate : 93.750 FPS (512 spf) Bit depth : 16 bits Compression mode : Lossy Stream size : 1.36 GiB (11%) Language : German Default : Yes Forced : No Audio #2 ID : 3 Format : DTS Format/Info : Digital Theater Systems Mode : 16 Format settings, Endianness : Big Codec ID : A_DTS Duration : 2 h 9 min Bit rate mode : Constant Bit rate : 1 509 kb/s Channel(s) : 6 channels Channel positions : Front: L C R, Side: L R, LFE Sampling rate : 48.0 kHz Frame rate : 93.750 FPS (512 spf) Bit depth : 16 bits Compression mode : Lossy Stream size : 1.36 GiB (11%) Language : English Default : No Forced : No But I'm still getting 2016-09-03 16:47:52.3105 Error MediaEncoder: ffmpeg image extraction failed for file:"/volume1/WollesNAS/Filme/12 Monkeys (1995)/12 Monkeys.1080p.bluray.dca.mkv" 2016-09-03 16:47:52.3110 Error MediaEncoder: I-frame image extraction failed, will attempt standard way. Input: file:"/volume1/WollesNAS/Filme/12 Monkeys (1995)/12 Monkeys.1080p.bluray.dca.mkv" 2016-09-03 16:47:52.8486 Info HttpServer: HTTP GET http://horstepipe.no-ip.biz:8096/?deviceId=CD232380BE19465C8D2F5DA9EFB2CAD8. UserAgent: 2016-09-03 16:47:58.0216 Info HttpServer: HTTP GET http://horstepipe.no-ip.biz:8096/?deviceId=CD232380BE19465C8D2F5DA9EFB2CAD8. UserAgent: 2016-09-03 16:48:02.8204 Info MediaEncoder: Killing ffmpeg process 2016-09-03 16:48:03.2081 Info HttpServer: HTTP GET http://horstepipe.no-ip.biz:8096/?deviceId=CD232380BE19465C8D2F5DA9EFB2CAD8. UserAgent: 2016-09-03 16:48:03.8305 Error MediaEncoder: ffmpeg image extraction failed for file:"/volume1/WollesNAS/Filme/12 Monkeys (1995)/12 Monkeys.1080p.bluray.dca.mkv" 2016-09-03 16:48:03.8333 Error App: Error extracting chapter images for /volume1/WollesNAS/Filme/12 Monkeys (1995)/12 Monkeys.1080p.bluray.dca.mkv *** Error Report *** Version: 3.1.132.0 Command line: /var/packages/EmbyServer/target/server/MediaBrowser.Server.Mono.exe -programdata /var/packages/EmbyServer/target/var -ffmpeg /var/packages/EmbyServer/target/ffmpeg/bin/ffmpeg -ffprobe /var/packages/EmbyServer/target/ffmpeg/bin/ffprobe Operating system: Unix 3.2.40.0 Processor count: 2 64-Bit OS: False 64-Bit Process: False Program data path: /var/packages/EmbyServer/target/var Mono: 4.4.2 (Stable 4.4.2.11/f72fe45 Sat Sep 3 02:34:25 CST 2016) Application Path: /volume1/@appstore/EmbyServer/releases/v3.1.132-beta/MediaBrowser.Server.Mono.exe ffmpeg image extraction failed for file:"/volume1/WollesNAS/Filme/12 Monkeys (1995)/12 Monkeys.1080p.bluray.dca.mkv" System.ApplicationException at MediaBrowser.MediaEncoding.Encoder.MediaEncoder+<ExtractImageInternal>d__37.MoveNext () <0x34a983c0 + 0x00e04> in <filename unknown>:0 --- End of stack trace from previous location where exception was thrown --- at System.Runtime.ExceptionServices.ExceptionDispatchInfo.Throw () <0x33ab6f68 + 0x00024> in <filename unknown>:0 at System.Runtime.CompilerServices.TaskAwaiter.ThrowForNonSuccess (System.Threading.Tasks.Task task) <0x33ab6c58 + 0x000bb> in <filename unknown>:0 at System.Runtime.CompilerServices.TaskAwaiter.HandleNonSuccessAndDebuggerNotification (System.Threading.Tasks.Task task) <0x33ab6b78 + 0x0008b> in <filename unknown>:0 at System.Runtime.CompilerServices.TaskAwaiter.ValidateEnd (System.Threading.Tasks.Task task) <0x2e6b41f8 + 0x0003f> in <filename unknown>:0 at System.Runtime.CompilerServices.ConfiguredTaskAwaitable`1+ConfiguredTaskAwaiter[TResult].GetResult () <0x2e448c48 + 0x0001b> in <filename unknown>:0 at MediaBrowser.MediaEncoding.Encoder.MediaEncoder+<ExtractImage>d__30.MoveNext () <0x34a973f0 + 0x00787> in <filename unknown>:0 --- End of stack trace from previous location where exception was thrown --- at System.Runtime.ExceptionServices.ExceptionDispatchInfo.Throw () <0x33ab6f68 + 0x00024> in <filename unknown>:0 at System.Runtime.CompilerServices.TaskAwaiter.ThrowForNonSuccess (System.Threading.Tasks.Task task) <0x33ab6c58 + 0x000bb> in <filename unknown>:0 at System.Runtime.CompilerServices.TaskAwaiter.HandleNonSuccessAndDebuggerNotification (System.Threading.Tasks.Task task) <0x33ab6b78 + 0x0008b> in <filename unknown>:0 at System.Runtime.CompilerServices.TaskAwaiter.ValidateEnd (System.Threading.Tasks.Task task) <0x2e6b41f8 + 0x0003f> in <filename unknown>:0 at System.Runtime.CompilerServices.ConfiguredTaskAwaitable`1+ConfiguredTaskAwaiter[TResult].GetResult () <0x2e448c48 + 0x0001b> in <filename unknown>:0 at MediaBrowser.Server.Implementations.MediaEncoder.EncodingManager+<RefreshChapterImages>d__0.MoveNext () <0x34a92ac0 + 0x00d57> in <filename unknown>:0 for that movie. Edited September 3, 2016 by horstepipe
solabc16 379 Posted September 4, 2016 Posted September 4, 2016 Hello @@horstepipe Can you run the timed test extract from the command line like before, for this specific movie. e.g. cd /var/packages/EmbyServer/target/ffmpeg/bin sudo time -p ./ffmpeg -ss 00:00:15.000 -i file:"/volume1/WollesNAS/Filme/12 Monkeys (1995)/12 Monkeys.1080p.bluray.dca.mkv" -threads 0 -v quiet -vframes 1 -vf "scale=600:trunc(600/dar/2)*2,thumbnail=30" -f image2 "/volume1/WollesNAS/Filme/12 Monkeys (1995)/testimg.jpg" - James
horstepipe 423 Posted September 4, 2016 Author Posted September 4, 2016 (edited) Hello @@horstepipe Can you run the timed test extract from the command line like before, for this specific movie. e.g. cd /var/packages/EmbyServer/target/ffmpeg/bin sudo time -p ./ffmpeg -ss 00:00:15.000 -i file:"/volume1/WollesNAS/Filme/12 Monkeys (1995)/12 Monkeys.1080p.bluray.dca.mkv" -threads 0 -v quiet -vframes 1 -vf "scale=600:trunc(600/dar/2)*2,thumbnail=30" -f image2 "/volume1/WollesNAS/Filme/12 Monkeys (1995)/testimg.jpg" - James admin@WollesNAS:/var/packages/EmbyServer/target/ffmpeg/bin$ sudo time -p ./ffmpeg -ss 00:00:15.000 -i file:"/volume1/WollesNAS/Filme/12 Monkeys (1995)/12 Monkeys.1080p.bluray.dca.mkv" -threads 0 -v quiet -vframes 1 -vf "scale=600:trunc(600/dar/2)*2,thumbnail=30" -f image2 "/volume1/WollesNAS/Filme/12 Monkeys (1995)/testimg.jpg" real 25.77 user 39.98 sys 0.18 admin@WollesNAS:/var/packages/EmbyServer/target/ffmpeg/bin$ admin@WollesNAS:/var/packages/EmbyServer/target/ffmpeg/bin$ sudo time -p ./ffmpeg -ss 00:00:15.000 -i file:"/volume1/WollesNAS/Filme/10 Cloverfield Lane (2016)/10 Cloverfield Lane.1080p.bluray.dca.mkv" -threads 0 -v quiet -vframes 1 -vf "scale=600:trunc(600/dar/2)*2,thumbnail=30" -f image2 "/volume1/WollesNAS/Filme/12 Monkeys (1995)/testimg.jpg" real 16.25 user 24.98 sys 0.09 admin@WollesNAS:/var/packages/EmbyServer/target/ffmpeg/bin$ admin@WollesNAS:/var/packages/EmbyServer/target/ffmpeg/bin$ sudo time -p ./ffmpeg -ss 00:00:15.000 -i file:"/volume1/WollesNAS/Filme/2012 (2009)/2012.1080p.bluray.dca.mkv" -threads 0 -v quiet -vframes 1 -vf "scale=600:trunc(600/dar/2)*2,thumbnail=30" -f image2 "/volume1/WollesNAS/Filme/12 Monkeys (1995)/testimg.jpg" real 10.40 user 16.77 sys 0.17 admin@WollesNAS:/var/packages/EmbyServer/target/ffmpeg/bin$ admin@WollesNAS:/var/packages/EmbyServer/target/ffmpeg/bin$ sudo time -p ./ffmpeg -ss 00:00:15.000 -i file:"/volume1/WollesNAS/Filme/39,90 (2007)/39,90.720p.bluray.dca.mkv" -threads 0 -v quiet -vframes 1 -vf "scale=600:trunc(600/dar/2)*2,thumbnail=30" -f image2 "/volume1/WollesNAS/Filme/12 Monkeys (1995)/testimg.jpg" real 3.50 user 4.69 sys 0.11 admin@WollesNAS:/var/packages/EmbyServer/target/ffmpeg/bin$ (this one is always that fast...) admin@WollesNAS:/var/packages/EmbyServer/target/ffmpeg/bin$ sudo time -p ./ffmpeg -ss 00:00:15.000 -i file:"/volume1/WollesNAS/Filme/7 Psychos (2012)/7 Psychos.1080p.bluray.dca.mkv" -threads 0 -v quiet -vframes 1 -vf "scale=600:trunc(600/dar/2)*2,thumbnail=30" -f image2 "/volume1/WollesNAS/Filme/12 Monkeys (1995)/testimg.jpg" real 7.62 user 10.91 sys 0.08 admin@WollesNAS:/var/packages/EmbyServer/target/ffmpeg/bin$ quite long, I guess...? It doesn't bother me if it needs a long time to extract the images, the main thing is that it works. Edited September 4, 2016 by horstepipe
Luke 42240 Posted September 4, 2016 Posted September 4, 2016 I will add a hidden config setting for the next beta release. 1
solabc16 379 Posted September 4, 2016 Posted September 4, 2016 Hello @@horstepipeThanks for the information above. The improvements we made to the FFmpeg build gave us ~15% improvement, which gave us a good step forward.Of course for those taking >20s, it's not going to bring them below the timeout.When you have a moment, could you send the media info for the movies you provided the timings for above. I'd like to try and get to the bottom of what is driving the variation, to see if there is anything else we can improve.Thanks @@Luke, we'll take advantage of that as soon as it's available.- James
horstepipe 423 Posted September 4, 2016 Author Posted September 4, 2016 Hello @@horstepipe Thanks for the information above. The improvements we made to the FFmpeg build gave us ~15% improvement, which gave us a good step forward. Of course for those taking >20s, it's not going to bring them below the timeout. When you have a moment, could you send the media info for the movies you provided the timings for above. I'd like to try and get to the bottom of what is driving the variation, to see if there is anything else we can improve. Thanks @@Luke, we'll take advantage of that as soon as it's available. - James Hey Those are exactly the movies from post 68, so you find the media info in the attached text file. Regards
horstepipe 423 Posted September 7, 2016 Author Posted September 7, 2016 Hey Good news here: I set the imageextractiontimeout in system.xml to 300000, removed the chapters-failures.txt file and started extraction. It took two days but it looks that now all of my movies have chapter images. Only a few movies got back into the chapters-failures.txt, but only the last one or two chapters are missing here. So I think this is because of corrupted MKVs. THANK YOU for support! Best regards
