gjviii 48 Posted August 23, 2016 Posted August 23, 2016 can someone take a quick look at the attached logs and see why my recordings wont start? i am able to watch live tv, i just don't seem to be able to record. i'm running server 3.1.116.0. I was running 3.0.070 when i noticed it stopped working, so i upgrade to beta. this is what i believe i see in the logs that show the issue: 2016-08-22 20:55:00.0208 Error App: Error recording stream *** Error Report *** Version: 3.1.116.0 Command line: C:\Users\user\AppData\Roaming\Emby-Server\System\MediaBrowser.ServerApplication.exe Operating system: Microsoft Windows NT 6.2.9200.0 Processor count: 4 64-Bit OS: True 64-Bit Process: True Program data path: C:\Users\user\AppData\Roaming\Emby-Server Application Path: C:\Users\user\AppData\Roaming\Emby-Server\System\MediaBrowser.ServerApplication.exe Program with Id EP024637200006T636075108000000000C864 not found System.InvalidOperationException at MediaBrowser.Server.Implementations.LiveTv.EmbyTV.EmbyTV.<RecordStream>d__97.MoveNext() --- End of stack trace from previous location where exception was thrown --- at System.Runtime.CompilerServices.TaskAwaiter.ThrowForNonSuccess(Task task) at System.Runtime.CompilerServices.TaskAwaiter.HandleNonSuccessAndDebuggerNotification(Task task) at MediaBrowser.Server.Implementations.LiveTv.EmbyTV.EmbyTV.<_timerProvider_TimerFired>d__8c.MoveNext() thanks for any input. server-63607494598.txt
Luke 42242 Posted August 23, 2016 Posted August 23, 2016 Was this part of a series or a manual recording?
gjviii 48 Posted August 23, 2016 Author Posted August 23, 2016 Was this part of a series or a manual recording? manual
gjviii 48 Posted August 23, 2016 Author Posted August 23, 2016 (edited) in the attached log above, i'd say about 20 minutes. i noticed the problems, cleared the logs,rebooted the server, set the record and waited for it to not record. earlier in the day, which is why i noticed it, i had shows scheduled a few hours in advance as a test, i'll try to record a 1/2 hour show every hour tonight and see if any of them record in the morning Edited August 23, 2016 by gjviii
Luke 42242 Posted August 23, 2016 Posted August 23, 2016 can you try another one? the only way that situation would happened is if you scheduled a recording and then after scheduling the guide data changed.
gjviii 48 Posted August 23, 2016 Author Posted August 23, 2016 can you try another one? the only way that situation would happened is if you scheduled a recording and then after scheduling the guide data changed. as a test, i'll try to record a 1/2 hour show every hour tonight and see if any of them record in the morning thanks
gjviii 48 Posted August 23, 2016 Author Posted August 23, 2016 (edited) okay, it looks like the recordings worked over night, however, some of them are not complete. I have a 5 minute buffer set pre/post, so the recordings should be about 40 minutes. Some of them (red Rising as an example) are only 5 minutes or so. I have attached logs to see why the recordings are now ending early. Thanks Log.txt Edited August 23, 2016 by gjviii
gjviii 48 Posted August 23, 2016 Author Posted August 23, 2016 This appears to be the log for one of the shows that failed to record the entire show? New Text Document (2).txt
gjviii 48 Posted August 24, 2016 Author Posted August 24, 2016 (edited) Another test that stops after about 5 minutes. I believe these are the logs showing the recording. Anyone see any reason for the stopping before the sow is completed? thanks for any input record-transcode-c557b64c-7846-4bfe-a0cd-0061553af43c.txt Edited August 24, 2016 by gjviii
Luke 42242 Posted August 24, 2016 Posted August 24, 2016 I think it might be a momentary signal drop on the HDHR that causes the recording to stop. This is something we need to improve on by automatically reconnecting.
Doonga 17 Posted August 24, 2016 Posted August 24, 2016 Oh I just made this thread about the aborted recordings yesterday. I didn't realize the same thing was being discussed here.
econ 74 Posted September 2, 2016 Posted September 2, 2016 I too am seeing the same issue of the live tv recordings being cut off.
econ 74 Posted September 12, 2016 Posted September 12, 2016 Any luck with looking into getting the HDHR to reconnect? The recordings are extremely unreliable within Emby at this point until it is fixed.
Luke 42242 Posted September 12, 2016 Posted September 12, 2016 It is a planned feature for an upcoming release.
