Garbonzo17
I have read the wiki and scoured through the message boards cant find a way to do this.
I have multiple copies of a lot of stuff for redundancy, I am trying to move everything to a larger drive I have, and delete the duplicates.
the larger drives is also a mirror raid setup, so I can free up these smaller 1, 2, 3 TB drives, and move every thing to the RAID.
So while its finding hundreds of files that are NOT already on the RAID it also has 1500+ that are..... I have to hit the "trash can" icon next to every one... and then OK the delete, it takes FOREVER...
I have it set to overwrite if PROPER, REPACK, etc.... but it doesn't do anything with identical files. only better versions which is good if I want 1080 or 720 vs smaller files... but I prefer the smaller...
I just want boxes next to the trash can or some other way to mass delete these identicals files as I drag them to my "target" auto-organize folder.
I realize this may not be the right place to post, please advise where it should go..
ANY help appreciated.
TIA..
-G..
