sea3pea0 5 Posted August 21, 2016 Posted August 21, 2016 Kodi is randomly skipping to next track in middle of song. I am running Emby Server Version 3.1.115.0 on a Synology DS412+. I am running Kodi 16.1 with the Titan Beta skin. I am also running the latest version of the Emby Beta addon for Kodi. Here are my Kodi logs and here are the Emby Server logs. Sometimes it will make it through a whole song and sometimes not. doesn't really matter what song, for instance if it skips a song I can go back to the same song and sometimes it will play it all the way through. Any ideas?
marcelveldt 736 Posted August 22, 2016 Posted August 22, 2016 Did you setup the music section to use http/stream instead of direct access?
sea3pea0 5 Posted August 22, 2016 Author Posted August 22, 2016 I have the "Direct stream music library" switched off since I have Kodi and Emby Server on the same network. I also have "Play from http stream instead of SMB" off. I am using an NFS server on my synology NAS and I have the path substitutions set up accordingly. I have tested this on different devices and I get the same behavior. The strange thing is the behavior isn't really consistent, sometimes it happens other times the tracks actually manage to play out their entire length. By the way @@marcelveldt, you have my compliments on the Titan skin. It is hands down my favorite skin. 1
Angelblue05 4132 Posted August 23, 2016 Posted August 23, 2016 (edited) @@sea3pea0 I see what you did there with your username If you switch back to the default skin, does this happen? Thing is, Emby has nothing to do with the music playback, it only maintain the metadata/file structure, if music plays then it's nothing on our side we can do to fix this - it is all Kodi, so something else it at play here. Edited August 23, 2016 by Angelblue05 1
Solution sea3pea0 5 Posted August 23, 2016 Author Solution Posted August 23, 2016 The problem hasn't been happening lately and I have no idea why because I didn't really change anything except for updating emby server. Today emby's(mono) RAM usage on my syno is a little lower, 70% compared to 85%+ yesterday. 1
