tixx 8 Posted August 21, 2016 Posted August 21, 2016 Hi, Running emby client on an android box, and to use it effectively, you really need to use a mouse. (i know its designed more for touch or mouse). However plex has a nice little feature that you can enable to make the interface flatter and easier to use with a normal remote control. Just a suggestion, if emby could have something similar that would be great. 2
tixx 8 Posted June 17, 2017 Author Posted June 17, 2017 Hi Luke, Any update on the above request? Thanks
