Raven 6 Posted August 21, 2016 Author Posted August 21, 2016 Nope, it's set as a Movie content library:
Happy2Play 9800 Posted August 21, 2016 Posted August 21, 2016 Are you running custom css removing options then? If not then there are other issue. missing tab header, movie years, and overlay menu options.
Happy2Play 9800 Posted August 21, 2016 Posted August 21, 2016 Also you shouldn't be seeing "SortBy=IsFolder" then because you have a library set to "Movie" content. So a config somewhere is making your library "Folder" view.
Raven 6 Posted August 21, 2016 Author Posted August 21, 2016 (edited) Well, that's weird then. Not running any custom CSS here. Don't know if it helps, but here's my Home View settings: Dashboard: Library, Display: Starting to wonder if my install is somehow corrupted... Any easy way to reset (without losing everything)? Edited August 21, 2016 by Raven
Happy2Play 9800 Posted August 21, 2016 Posted August 21, 2016 You could just shut down the server and reinstall from the download page. Nothing will be lost
Raven 6 Posted August 21, 2016 Author Posted August 21, 2016 (edited) Ok, trying that now. Will report back shortly. No dice. Reinstalled current stable release and nothing changed. Edited August 21, 2016 by Raven
Raven 6 Posted August 21, 2016 Author Posted August 21, 2016 Tried to add the folder path for the Movies library as UNC (rather than using path substitution) but after a full library scan, nothing different. Well, I don't know exactly what the issue is but I created a new Library item of Content type Movies based on the same media folder. Library Scan is still running but looks like the new Movies library is displaying correctly (tab strip is present, Collections displayed correctly, etc). So, looks like I'm going to have to re-add each Media Library. Any way of defaulting to the Movies tab instead of Suggestions?
Happy2Play 9800 Posted August 21, 2016 Posted August 21, 2016 Any way of defaulting to the Movies tab instead of Suggestions? Unfortunately no, there are feature requests for it. Your currently doing the last thing I could have suggested. Glad to hear it is working out. Hopefully @@Luke can comment on how this could have happened. Is your TV content missing the tab strip also?
Raven 6 Posted August 21, 2016 Author Posted August 21, 2016 Yep, Tv is also missing it. As are all the other media folders that have a content type of something other than Unset/Mixed - except, oddly, Music. Looks like I've got a lot of Library Scanning ahead of me! I did notice that if I rename the new Movies library to "Movies" (which is what the original, faulty library was called), everything goes screwy again. Renaming it to anything else fixes it. Might just let the scan finish, restart the server and then try renaming it and see what happens. Thanks so much for all your help with this today
Raven 6 Posted August 21, 2016 Author Posted August 21, 2016 Dang! Renaming the new library to "Movies" breaks everything again! @@Luke - any ideas about this part of the issue?
Happy2Play 9800 Posted August 21, 2016 Posted August 21, 2016 TV missing what? Missing what I highlighted in post 27, tabs. So all the libraries are seen as what I would say as "unset" every though you can see in post 26 they are not.
Raven 6 Posted August 22, 2016 Author Posted August 22, 2016 So, any ideas why renaming the new Movies library to "Movies" breaks the sorting, tab strip, etc? Steps: Existing library of Content type: Movies called "Movies". Collection sorting broken and tab strip missing, etc Create a new library of Content type: Movies called "New Movies" based on same folder. All working perfectly, no issues. Delete old "Movies" library Scan Library Restart Emby Server Rename library from "New Movies" to "Movies". Original problems resurface. Rename library back to "New Movies". Problems gone all working again.
Happy2Play 9800 Posted August 22, 2016 Posted August 22, 2016 (edited) What files are in Movies folder in c:\Users\username\AppData\Roaming\Emby-Server\root\default? Edited August 22, 2016 by Happy2Play
Raven 6 Posted August 22, 2016 Author Posted August 22, 2016 I'll check when I get home tonight but from memory there's a folder for each media library using the same name as the library. Not much inside each folder except for a landscape.jpg, a 1kb .lnk file and a zero byte file (can't remember the name - maybe mblink)?
Happy2Play 9800 Posted August 22, 2016 Posted August 22, 2016 To me is sounds like a database somewhere is holding that Library name as a folder view. Can you post a server log.
Raven 6 Posted August 22, 2016 Author Posted August 22, 2016 Yeah, that's what I suspect too but no idea where. Will post server log tonight when I get home - what steps do you want me to take before grabbing the log?
Happy2Play 9800 Posted August 22, 2016 Posted August 22, 2016 What I am thinking actually would point to the system.xml but the log show the config, possibly an issue in content type. example of one I mapped. Near the bottom of the file. \Emby-Server\config <ContentTypes> <NameValuePair> <Name>C:\Users\media\Desktop\Video Test\TV Series\Reality</Name> <Value>tvshows</Value> </NameValuePair> </ContentTypes>
Raven 6 Posted August 22, 2016 Author Posted August 22, 2016 (edited) Hmmm, The <ContentTypes> tag in my System.xml file is completely empty. That's perhaps the issue? I've attached it along with latest server log. server-63607487969.txt system.xml Edited August 22, 2016 by Raven
Happy2Play 9800 Posted August 22, 2016 Posted August 22, 2016 No that is good, that means there is nothing there that can interfere with the default content types. I'm out of ideas that could change your content type view. @@Luke will have to comment on what could cause the view issue, but I am leaning toward a database issue. 1
Happy2Play 9800 Posted August 22, 2016 Posted August 22, 2016 Just did a quick look and it looks like the information is stored in the library.db. And if that information isn't being completely removed when a library is being delete then that would explain the renaming a new library back to Movies returns the issue. Just a guess though.
Raven 6 Posted August 22, 2016 Author Posted August 22, 2016 I'm guessing if I delete library.db I will have to rebuild everything again from scratch or just run a Scan Library?
Raven 6 Posted August 23, 2016 Author Posted August 23, 2016 Just a quick bump - will I have to rebuild everything and lose played status etc if I delete library.db? @@Luke @@Happy2Play ?
Happy2Play 9800 Posted August 23, 2016 Posted August 23, 2016 Nothing is lost, a library scan will rebuilt that database if you delete it. 1
Solution Happy2Play 9800 Posted August 23, 2016 Solution Posted August 23, 2016 @@Raven @@Luke I can reproduce this issue, all Collections before Movies. It is a user config.xml issue. Emby-Server\config\users\USERID\config.xml You need to look at the <PlainFolderViews> I bet yours point to your libraries, like I configured mine to. <?xml version="1.0"?> <UserConfiguration xmlns:xsd="http://www.w3.org/2001/XMLSchema" xmlns:xsi="http://www.w3.org/2001/XMLSchema-instance"> <AudioLanguagePreference>eng</AudioLanguagePreference> <PlayDefaultAudioTrack>true</PlayDefaultAudioTrack> <SubtitleLanguagePreference /> <DisplayMissingEpisodes>false</DisplayMissingEpisodes> <DisplayUnairedEpisodes>false</DisplayUnairedEpisodes> <GroupMoviesIntoBoxSets>false</GroupMoviesIntoBoxSets> <GroupedFolders /> <SubtitleMode>None</SubtitleMode> <DisplayCollectionsView>true</DisplayCollectionsView> <EnableLocalPassword>true</EnableLocalPassword> <OrderedViews> <string>384bb658bdd82344138c376d0e4945c0</string> <string>f59d130de19731a61863f59d47783782</string> </OrderedViews> <LatestItemsExcludes /> <PlainFolderViews> <string>384bb658bdd82344138c376d0e4945c0</string> <string>f59d130de19731a61863f59d47783782</string> </PlainFolderViews> <HidePlayedInLatest>true</HidePlayedInLatest> <EnableChannelView>false</EnableChannelView> <RememberAudioSelections>true</RememberAudioSelections> <RememberSubtitleSelections>true</RememberSubtitleSelections> <EnableNextEpisodeAutoPlay>true</EnableNextEpisodeAutoPlay> <DisplayFoldersView>false</DisplayFoldersView> </UserConfiguration> 1
