lepitismak 1 Posted August 20, 2016 Posted August 20, 2016 Good evening, I am unable to perform remote access to my server Emby . I made all the necessary settings but charges that the server is not working when I try to access the link for remote access informed . Can anybody help me?
Luke 42186 Posted August 20, 2016 Posted August 20, 2016 Hi there, welcome. Can you describe the problem in a little more detail? Where exactly are you getting stuck? thanks.
lepitismak 1 Posted August 20, 2016 Author Posted August 20, 2016 I made all the settings step by step showed . I arrive on the home screen which informs the local and remote access links . When I click remote access, simply will not charge anything. I made all the settings step by step showed . I arrive on the home screen which informs the local and remote access links . When I click remote access, simply will not charge anything.
lepitismak 1 Posted August 20, 2016 Author Posted August 20, 2016 (edited) When access aap.emby.media and enter login information with which I invited the private messenger , I can normally access . Edited August 20, 2016 by lepitismak
lepitismak 1 Posted August 20, 2016 Author Posted August 20, 2016 On the same computer server , try to access another through the app.emby.media browser and access is normally released .When I try to access outside the network, by phone or even Xbox one , said that it was not possible to connect to the selected server.Something about this ?
