killride 47 Posted August 17, 2016 Posted August 17, 2016 Hi everybody, One of you try to use path substitution to direct play with a FTP server ? I tried and it works when I put the credentials into the path on the server but it doesn't if I use the network credentials on Emby for kodi and modify the password.xml to match with my configuration. By default when you create network credentials the password.xml looks like smb://SRV/ to smb://Login:PW@SRV/. Then I tried to put FTP:// instead SMB:// but doesn't work. Any ideas ? Thanks.
xnappo 1611 Posted August 17, 2016 Posted August 17, 2016 You may be able to get this to work by: 1. Change playback mode to 'Native' 2. Reset DB 3. Implement native Kodi path substitution: http://kodi.wiki/view/Path_substitution
xnappo 1611 Posted August 18, 2016 Posted August 18, 2016 @@killride - cool - report back if it works (curious).
killride 47 Posted September 23, 2016 Author Posted September 23, 2016 You're the MAN @@xnappo . I make a little try with my betatest server and It works very well !!! I'm gonna make more test but seems ok. Thank you very much ! 1
