Rayger 14 Posted January 11, 2014 Posted January 11, 2014 There used to be a setting in the server dashboard that would allow you to uncheck what metadata you don't want to fetch, such as genres. Did this setting get moved and I am just missing it? I don't want to go through all my movies and uncheck genre fetching for every single title. Thank you.
Luke 42289 Posted January 11, 2014 Posted January 11, 2014 we never had the ability to turn off genre fetching for all movies. what you could do is turn off internet data altogether for an entire folder of movies
Rayger 14 Posted January 12, 2014 Author Posted January 12, 2014 I am completely certain there used to be check boxes for metadata you don't want downloaded. I unchecked genres before and currently my server will not refetch genres for anything, which is what I desire. I am just afraid of this setting reverting in the future and me losing all of my work, making custom genres for everything. Sent from my RM-878_nam_usa_100 using Tapatalk
Luke 42289 Posted January 12, 2014 Posted January 12, 2014 that's actually not what the setting was doing, which is exactly why the page was removed in order to avoid that type of confusion. the only way stop genres from being downloaded is to lock genre fields for all titles, or disable internet downloading altogether.
Rayger 14 Posted January 12, 2014 Author Posted January 12, 2014 Ok, great. Thanks for clearing that up.
