aswieton 0 Posted August 13, 2016 Posted August 13, 2016 Hi Very often have freeze problem during iptv playback. Every freez is connected to 'skipping 1 segments ahead, expired from playlists' message in transcode.log. Any help? Regards Artur
Luke 42244 Posted August 13, 2016 Posted August 13, 2016 Hi there, welcome. Sorry to hear this. In order to best help you, please provide the info requested in how to report a media playback issue. Thanks!
aswieton 0 Posted August 14, 2016 Author Posted August 14, 2016 Hi Here you have logs with this error. Ragards Artur server-63606729600.txt transcode-b863456e-df98-4b62-8b40-132aef20b775.txt
Luke 42244 Posted August 14, 2016 Posted August 14, 2016 Ok, it looks like your video transcoding is just not fast enough frame= 1004 fps= 17 q=22.0 size= 10254kB time=00:00:52.98 bitrate=1585.3kbits/s speed=0.874x frame= 1017 fps= 17 q=22.0 size= 10412kB time=00:00:55.57 bitrate=1534.7kbits/s speed=0.909x frame= 1029 fps= 17 q=24.0 size= 11154kB time=00:01:01.62 bitrate=1482.7kbits/s speed= 1x frame= 1042 fps= 17 q=24.0 size= 11301kB time=00:01:02.13 bitrate=1489.8kbits/s speed= 1x
aswieton 0 Posted August 14, 2016 Author Posted August 14, 2016 OK thanks But it's any solution for that? Emby is running on fast computer with i7 processor and more then 12GB RAM. So it's a internet connection problem (but playing the same stream thruogh web browser without emby works fine)? Regards Artur
Luke 42244 Posted August 14, 2016 Posted August 14, 2016 Can you try grabbing the ffmpeg command line from the transcode log, remove the -re and then run it separately? see how that performs. thanks.
aswieton 0 Posted August 16, 2016 Author Posted August 16, 2016 Hi I had done like you said and speed was from 1,2 - 2,5 frame= 2160 fps= 34 q=24.0 size= 41646kB time=00:01:26.70 bitrate=3934.9kbits/s speed=1.37x Never was bellow 1.0
Luke 42244 Posted August 16, 2016 Posted August 16, 2016 thanks. i will remove the -re from the server.
aswieton 0 Posted August 16, 2016 Author Posted August 16, 2016 Thanks! so I'll be wating for update. Regards Artur
aswieton 0 Posted August 23, 2016 Author Posted August 23, 2016 thanks. i will remove the -re from the server. Is this fix is in version 3.0.6070 Thanks Artur
aswieton 0 Posted August 24, 2016 Author Posted August 24, 2016 (edited) Great. Thanks! Is Better Edited August 24, 2016 by aswieton
