freakbeat 0 Posted August 12, 2016 Posted August 12, 2016 I got this output when i tried to run the mkbundlex script: freakbeat@darkstar:~/Downloads/Emby/Tools/Linux_Build_Scripts$ ./MediaBrowser.Mono.Build.mkbundle.sh mediabrowser/MediaBrowser.Mono.mkbundlex.3.0.6060.0.tar.gz ./MediaBrowser.Mono.Build.mkbundle.sh: line 24: [mediabrowser/MediaBrowser.Mono.mkbundlex.3.0.6060.0.tar.gz: No such file or directory ======================================== MediaBrowser for Mono Mkbundle Creator Logs available in mediabrowser/logs_mkbundlex Archive available in mediabrowser ======================================== ======================================== Check Dependencies ======================================== Checking for git Checking for tar Checking for gzip Checking for mono freakbeat@darkstar:~/Downloads/Emby/Tools/Linux_Build_Scripts/mediabrowser$ ls MediaBrowser.Mono.3.0.6060.0.tar.gz MediaBrowser.Mono.mkbundlex.3.0.6060.0.tar.gz what i have wrong? Thanks
Luke 42244 Posted August 12, 2016 Posted August 12, 2016 We actually don't really use that script anymore. You can just build the solution with the Release Mono configuration.
freakbeat 0 Posted August 12, 2016 Author Posted August 12, 2016 I'm sorry for my ignorance, where is the release mono config? how build that? there's any manual ? Thanks for the reply..
Luke 42244 Posted August 12, 2016 Posted August 12, 2016 Just locate MediaBrowser.sln and build that solution under the Release Mono configuration. If you don't know how to do that then research building .net projects with xamarin. Or why not just use one of our prebuilt packages?
freakbeat 0 Posted August 12, 2016 Author Posted August 12, 2016 I'm testing on x64 platform but i'm trying to figure out how to build for RPi 3 armv8 , I couldn't find any prebuilt packages for RPi 3
Luke 42244 Posted August 12, 2016 Posted August 12, 2016 what i would suggest doing is following the manual linux install instructions here: http://emby.media/linux-server.html everything is all built for you, you just need to supply the dependencies.
freakbeat 0 Posted August 12, 2016 Author Posted August 12, 2016 Does this work for Raspberry pi 3? Thanks
freakbeat 0 Posted August 12, 2016 Author Posted August 12, 2016 Let me try and will come back here to post results. Thank you for all the help
