GothsterC 50 Posted August 12, 2016 Posted August 12, 2016 This seems to be a new behavior that I don't recall ever happening. My 10 year daughter showed me some very inappropriate background images being displayed while she browsed the kids library. The background images were from movies that she doesn't have access to. So if she doesn't have access to those movies, why are background images from those movies being displayed in the kids library? I recall that before only images from movies that she had access to were shown in the background while browsing. The only thing I have found is that I can go into each client as the kid user and disable backgrounds, but this needs to be done with many different clients and there is nothing stopping the kids from turning the backgrounds back on. Please help.
GothsterC 50 Posted August 12, 2016 Author Posted August 12, 2016 (edited) I'm using Emby Server 3.0.6060 on the latest update to Windows 10. I checked and saw this behavior in both the Windows web app (using Chrome and Firefox) as well as the Amazon Fire TV app. I haven't checked the Amazon Fire tablet yet, but they also have those. I have several libraries including Kids (G, PG), Teens (PG-13) and Grownups ®. They can only access the kids library but were seeing background (fanart) images from the R-rated library. I selected and became a supporter of Emby because of the parental controls. I checked for this in the past when I gave the kids access to their Emby library and could swear they only saw backgrounds from images within their own libraries, so something must have changed somewhere. I've also reviewed my settings and found nothing that could have triggered this. Thanks Edited August 12, 2016 by GothsterC
GothsterC 50 Posted August 12, 2016 Author Posted August 12, 2016 After logging in, the inappropriate background images appear behind the icons in the Home and Movies screens. I've attached a screenshot and lightened it so you can see the image better.
Luke 42186 Posted August 12, 2016 Posted August 12, 2016 is that backdrop from a movie in your library?
GothsterC 50 Posted August 12, 2016 Author Posted August 12, 2016 Yes. Because I have children, I have movies on various drives. I have a drive for kid movies. I have a drive for more adult movies. I have set up separate libraries that point to the correct locations. The kids have access to only their own drives, not to the adult ones. The backgrounds are downloaded by Emby from the various sources (themoviedb.org, etc.) automatically and serve as backgrounds when viewing a particular movie. However when you are browsing, let's say the movies, you get a random background image from one of the movies behind the icons. In the past, the random background image was only from content the user had access to, but now it is showing images from the other locations. They should have access to these images Drive K: Kids\Alvin and the Chipmunks [2007]\Alvin and the Chipmunks [2007]-fanart.jpg, *-fanart-1.jpg, , *-fanart-2.jpg and so on Drive K: Kids\Alvin and the Chipmunks [2007]\extrafanart\fanart1.jpg, fanart-2.jpg and so on They should not have access to these images, but they can randomly appear in the background Drive R: Grownups\The Dreamers [2003]\The Dreamers [2003]-fanart.jpg, *-fanart-1.jpg, , *-fanart-2.jpg and so on Drive R: Grownups\The Dreamers [2003]\extrafanart\fanart1.jpg, fanart-2.jpg and so on They don't have access to any of the movies on drive R, but the randomly generated slideshow that appears in the background is drawing from that drive. I hope this is clear. Thanks
Luke 42186 Posted August 12, 2016 Posted August 12, 2016 thanks. what mechanism is being used to restrict that movie from the kids? just normal library access or one of the parental control features?
GothsterC 50 Posted August 12, 2016 Author Posted August 12, 2016 I create the library using the Library settings by having a separate library for each drive. So I have a library called Kids that points to the K drive and a library called Grownups that points to the R drive. I then created a user called Kids using the Users settings. In there, I used the Access tab and only selected access to the Kids library. All others are disabled. I have nothing special setup in the Parental Controls tab.
Luke 42186 Posted August 12, 2016 Posted August 12, 2016 Ok, what i would suggest doing is going to the access tab for the kids user and just double checking that everything is the way you expect, and then also click save just to resave the settings. see if that makes a difference, thanks.
GothsterC 50 Posted August 12, 2016 Author Posted August 12, 2016 I just did what you asked. Everything looks correct and I saved again. I went back in as Kids. They still only show the movies they have access to, but the backdrop image when browsing the movie icons showed another, but different image, from the restricted library.
