thefarmer 0 Posted January 11, 2014 Posted January 11, 2014 Hi, I see there are a few threads on subtitles within the roku forum, but i can't find anything that relates to the issue that I have found/experiencing. When i enable subtitles (which are embedded within mkv container) the video does not play at all. It will try for about 10-15 seconds to play and then will return to the previous screen. If i select 'no' subtitles, it will fire up. I can enable subtitles on the same video within MBT though. Any ideas? thnx.
Tikuf 663 Posted January 11, 2014 Posted January 11, 2014 It could be a number of things but i will need logs to diagnose it thanks.
FrostByte 5453 Posted January 15, 2014 Posted January 15, 2014 I'm seeing similar issues and can provide logs if farmer doesn't
Tikuf 663 Posted January 15, 2014 Posted January 15, 2014 Wait until the new code for subs comes out it streamlines a few things. If it still doesn't function as expected I will be asking for logs. Cheers
thefarmer 0 Posted January 15, 2014 Author Posted January 15, 2014 thanks Tikuf, no problem on waiting....happy to provide logs if and when needed. Cheers
