Starkadius 219 Posted January 11, 2014 Posted January 11, 2014 (edited) @Aphid I was not entirely sure what tidy genre meant since no where does it mention what it does but I figured it out after experimenting with it. Well I believe there is a bug with the latest release. It seems that when it fetches the genres it does add them to the series.xml file but it appears blank on the web client even after refreshing over and over. I tried this with "Max Genres:0" and up to 5. What I found that fixed it was that I had to go into the xml, make a change manually and save it. I ran a refresh and the genres appear. Not sure what's going on since the xml appears fine. Edit: I don't want to open up a topic for every issue I find even though it is the proper way but I want to also mention that when I change Max Genres to 6, 7 or more it still only adds 5 genres and the rest to tags. Using 0 as the max does assign all the tags as genres though. Edited January 11, 2014 by Starkadius
Aphid 212 Posted January 14, 2014 Posted January 14, 2014 If the series.xml file is being updated, then I am not sure what could be causing this. It might be a problem with MB itself, or maybe the plugin should be doing something to notify the server of a refresh (beyond returning true in FetchAsync). @@Luke, do you have any idea what could cause this? Edit: I don't want to open up a topic for every issue I find even though it is the proper way but I want to also mention that when I change Max Genres to 6, 7 or more it still only adds 5 genres and the rest to tags. Using 0 as the max does assign all the tags as genres though. I have no idea. It works for 1-5? I guess I should document this somewhere in the config page: Tidy Genres - Re-maps a few of the genres, a little like the genre cleaner addon. For example, if AniDB lists "Zombie" as a category, then the series will have the "Supernatural" genre added. Also, if "Move Excess Genres to Tags" is enabled, "Zombie" will be added to tags instead of genres. Move Excess Genres to Tags - Moves genres above the max genre limit into tags. Also modifies the tidy behavior as mentioned above.
Luke 42253 Posted January 14, 2014 Posted January 14, 2014 if you're modifying genres within FetchAsync, and returning true, then that's all you need to do.
Koleckai Silvestri 1154 Posted January 14, 2014 Posted January 14, 2014 Do you have the Genre Cleaner plugin installed as well?
Starkadius 219 Posted January 15, 2014 Author Posted January 15, 2014 I don't have genre cleaner installed currently. Here is the example of the problem occuring. http://www.youtube.com/watch?v=_ze-2GMrWAM What seems to make the genres appear is restarting the server every time a change is made to the genres.
Starkadius 219 Posted February 25, 2014 Author Posted February 25, 2014 (edited) @@Aphid Has the plugin been updated to support the latest server beta? I can't seem to populate the anime with any anidb/anilist Genres. Edited February 25, 2014 by Starkadius
Aphid 212 Posted February 25, 2014 Posted February 25, 2014 It is in progress. There are a few issues still to be worked out, and a few changes need to be made to the server before things will work properly. 1
