horstepipe 422 Posted August 10, 2016 Posted August 10, 2016 (edited) hey I switched to the new Synology ARM package, at the moment ffmpeg is not supported, yet. I re-imported my database, metadata is saved in .nfo files <fileinfo> <streamdetails> <video> <codec>h264</codec> <micodec>h264</micodec> <bitrate>29345405</bitrate> <width>1920</width> <height>1080</height> <aspect>16:9</aspect> <aspectratio>16:9</aspectratio> <framerate>23.97602</framerate> <language>ger</language> <scantype>progressive</scantype> <default>True</default> <forced>True</forced> <duration>108</duration> <durationinseconds>6486</durationinseconds> </video> <audio> <codec>dca</codec> <micodec>dca</micodec> <bitrate>768000</bitrate> <language>ger</language> <scantype>progressive</scantype> <channels>6</channels> <samplingrate>48000</samplingrate> <default>True</default> <forced>True</forced> </audio> <audio> <codec>dca</codec> <micodec>dca</micodec> <bitrate>1536000</bitrate> <language>eng</language> <scantype>progressive</scantype> <channels>6</channels> <samplingrate>48000</samplingrate> <default>False</default> <forced>False</forced> </audio> <subtitle> <codec>srt</codec> <micodec>srt</micodec> <language>ger</language> <scantype>progressive</scantype> <default>True</default> <forced>True</forced> </subtitle> <subtitle> <codec>dvdsub</codec> <micodec>dvdsub</micodec> <language>ger</language> <scantype>progressive</scantype> <default>False</default> <forced>False</forced> </subtitle> <subtitle> <codec>pgssub</codec> <micodec>pgssub</micodec> <language>ger</language> <scantype>progressive</scantype> <default>False</default> <forced>False</forced> </subtitle> <subtitle> <codec>dvdsub</codec> <micodec>dvdsub</micodec> <language>eng</language> <scantype>progressive</scantype> <default>False</default> <forced>False</forced> </subtitle> <subtitle> <codec>pgssub</codec> <micodec>pgssub</micodec> <language>eng</language> <scantype>progressive</scantype> <default>False</default> <forced>False</forced> </subtitle> <subtitle> <codec>dvdsub</codec> <micodec>dvdsub</micodec> <language>ger</language> <scantype>progressive</scantype> <default>False</default> <forced>False</forced> </subtitle> <subtitle> <codec>pgssub</codec> <micodec>pgssub</micodec> <language>ger</language> <scantype>progressive</scantype> <default>False</default> <forced>False</forced> </subtitle> </streamdetails> </fileinfo> Unfortunately, Emby doesn't recognize it. Does ffmpeg have to be available to show metadata although the information is already saved in .nfo file? Emby Server Version 3.1.97.0 running on Synology DS414 (ArmadaXP) Edited August 10, 2016 by horstepipe
Luke 42186 Posted August 10, 2016 Posted August 10, 2016 Yea we don't use media info from nfo's in Emby. We write it so that Kodi can see it, but we need more accurate information then that in order to successfully stream and transcode. 1
horstepipe 422 Posted August 10, 2016 Author Posted August 10, 2016 Yea we don't use media info from nfo's in Emby. We write it so that Kodi can see it, but we need more accurate information then that in order to successfully stream and transcode. ok thank you for the information.
solabc16 379 Posted August 10, 2016 Posted August 10, 2016 (edited) Evening All This query refers to a pre-release in development package that is not in the public domain, so may be misleading. The behaviour is expected, as FFprobe is not currently available, as opposed to FFmpeg. Best - James Edited August 10, 2016 by solabc16
