Tikuf 663 Posted January 18, 2014 Posted January 18, 2014 Can I see some server logs (ffmpeg logs if it makes it that far). Eric the issue I think will be down to the fact we don't probe the remote file for mi so we are likely looking for an non existant video stream from that podcast. It will work if we can differentiate between audio and video podcasts. (but I wont know for sure until i see some logs).
ebr 16343 Posted January 18, 2014 Posted January 18, 2014 Yes, audio and video podcasts are different object types as I use that information on the MBC side.
Tikuf 663 Posted January 18, 2014 Posted January 18, 2014 Eric I just installed podcasts it it a bug in the server where we are callingĀ ffmpeg -i file:"http://podcast.cbc.ca/mp3/podcasts/vinylcafe_20130810_51747.mp3" In the c/l where it should just be ffmpeg -i "http://podcast.cbc.ca/mp3/podcasts/vinylcafe_20130810_51747.mp3" @@Luke
CBers 7558 Posted January 18, 2014 Posted January 18, 2014 I can play audio-only podcasts through the Android app.
Erik 124 Posted January 19, 2014 Posted January 19, 2014 Thanks guys. I assume this means you don't need the logs then? I will try it also with MBT when I am back home.
