Taffer 0 Posted January 11, 2014 Posted January 11, 2014 I am having problems with my supporter keys. I have paid via PayPal for MBC key, as well as Breeze and Movie themes. When I try to enter the key for either plugin I get a meesage saying that I need to be a supporter of MBCin order to use premium features. I think the problem is because I have registered MBC with one email and the others with a different email. Can someone help me with this ?
Tikuf 663 Posted January 11, 2014 Posted January 11, 2014 http://localhost:8096/mediabrowser/dashboard/supporterkey.html (sub out localhost if required with the ip of you box) look at the section multiple key linking at least I think that is what you are asking
Taffer 0 Posted January 11, 2014 Author Posted January 11, 2014 Sorry should ave included steps I did try linking the keys, in oder from to to bottom I have MBC supporter key then MB2 supporter key then email for breeze supporter key Then current MBC supporter key then the supporter key for breeze . When I click save I get a message that says keys are linked I then go to MBC and it still says that breeze is in trial period
ebr 16354 Posted January 11, 2014 Posted January 11, 2014 What version of the server are you running? Is your supporter badge in the top line gold? If you go to the plug-in catalog and drill down to the Breeze theme, does it tell you it is registered or in trial there?
Taffer 0 Posted January 12, 2014 Author Posted January 12, 2014 I start the media browser classic Configurator then go to help and select the link for server dashboard In the dashboard the server version is 3.0.5115.35703 The supporter badge is gold and when the mouse hovers over it I get a message saying thank you for supporting media browser If I select.plugins then I see cover art, movie theme videos and TV theme videos Clicking on cover art plugin shows a message in the top right corner stating version 4.0.4.8 registered Clicking on the movie or TV theme video plugin just shows a page for normalising audio and filters etc no registration information If I go to the catalogue then select MBC plugins from the drop down menu and select breeze I can see all the blurb about breeze etc the link to install which states it must be installed from MBC Configurator and PayPal donation info etc but nothing stating the plugin is registered When I go to the MBC Configurator and select plugins I can see breeze plugin but there is no adjustments or info available for that When I look at the theme video backdrop plugin I can configure the play sources and deletion nut no registration info is there either
Solution Taffer 0 Posted January 12, 2014 Author Solution Posted January 12, 2014 Dont know what changed but I just went through the steps again and now it is accepting the new registration code. Breeze is now showing as registered when I start MBC but I don't know how to tell if movie themes are registered
ewe 0 Posted January 17, 2014 Posted January 17, 2014 How Do I get a supporter key. I go to the MB2 store and it showes it closed. What's up with that/
Yogi 367 Posted January 17, 2014 Posted January 17, 2014 (edited) Support for MB2 is no longer active. For MB3 in the web client go to help and click on the Become a supporter tab and go from there.When you receive your key go to the Supporter Key section and enter it there. Edited January 17, 2014 by Yogi
