shad0h 8 Posted August 9, 2016 Posted August 9, 2016 Hi everyone, Just hoping to see if I am an exception or if this is common to us all, but I have noticed over the last few releases (beta and stable) that there is a very long delay between the new version being announced (pushed to git) and being available as an update in the Package Centre. The last beta update I installed took about a day and a half to appear (despite me clicking refresh many times), after the dashboard declared the new version was available. I see that the current update has been in the wild about 7 hours already as well, and still no update. As I said, more curious whether this is an issue that I am experiencing individually as the first priority.
Luke 42239 Posted August 9, 2016 Posted August 9, 2016 Hi, not everything is automated so sometimes there is some delay.
shad0h 8 Posted August 9, 2016 Author Posted August 9, 2016 Thanks @@Luke , That crossed my mind after I had posted. Appreciate the heads up.
solabc16 379 Posted August 9, 2016 Posted August 9, 2016 (edited) Hello @@shad0h Could you be more specific with versions and the delay experienced, so I can look into it. For release 3.0.6050, these are the timestamps:- Release Tagged : 2016-08-08T00:01:50Z Package Built : 2016-08-08T00:18:08Z SPK Published : 2016-08-08T00:22:06Z 1st User Download : 2016-08-08T01:05:13Z As a background, once the release is tagged, the Synology package is built. This includes all of the platform specific dependencies, configuration items and checks for the various supported architectures. To prevent DOA (for whatever reason) pacakges being published, the SPK is 'sanity checked' before being made public. The 'sanity checks' were implemented over the weekend, which resulted in releases after 3.1.90.0-1-beta being held, due to the issue reported here http://emby.media/community/index.php?/topic/37652-beta-31900-1-on-synology-dash-will-not-start/. We've since changed this behaviour, so that the full 'sanity checks' are now only applied to stable, on the beta channel the only check will be to make sure the Mono process starts and not look at any specific Emby Server functionality. - James Edited August 9, 2016 by solabc16 1
shad0h 8 Posted August 10, 2016 Author Posted August 10, 2016 (edited) Thanks @@solabc16 (James), Latest case in point was beta 197. After about 9 hours following release (looking at the time since commit on git), it was still not appearing in my Package Centre as an update. My synology emailed me at 4am (GMT+10, which was about 16 hours after commit) that the package was available to update, but again I don't know how long it may have been available in PC prior to that notification. Frankly, I don't know how Synology does it's check - whether it is a push, or a cron job pull - but just wanted to make sure I didn't have an issue on my side that I needed to investigate. Genuinely, this was not intended as a complaint, only a query to see if my experience was abnormal. Shane Edited August 10, 2016 by shad0h
solabc16 379 Posted August 10, 2016 Posted August 10, 2016 Hello @@shad0h No offence taken, I'm certainly keen to make sure this process is working as efficiently as is possible. I've certainly seen a wide variation in timings from Package Center when testing with Automatic Updates (not recommended) enabled. Let's track a few more through and see what we find. Do you have a static IP? Even if not, we can likely use your current IP to track through the recent requests we are seeing from Package Center and shed some more light on it. PM me your IP address if you're up for it and I'll share the logs and we can take it from there. - James
shad0h 8 Posted August 17, 2016 Author Posted August 17, 2016 (edited) Hi @@solabc16, Not sure if you have pushed the Synology package to them yet, as I had not seen the update for 107 after about 14 hours (before it was superseded), and I think it must be coming up on 10 hours for 108. Wasn't sure if the new .net/mono was holding up pushing the synology beta versions in anyway. Shane Edited August 17, 2016 by shad0h
solabc16 379 Posted August 17, 2016 Posted August 17, 2016 Hi @@shad0h As the only change between 3.1.106-beta and 3.1.109-beta is the "Update windows to target 4.6.2 (beta and dev channels only for now)", we'd held of pushing the releases for now, as they do not apply to the Synology platform. Best - James 1
solabc16 379 Posted August 17, 2016 Posted August 17, 2016 Hello @shad0h 3.1.110-beta is now available. - James 1
shad0h 8 Posted August 26, 2016 Author Posted August 26, 2016 Hey @@solabc16 Haven't seen a Syno update since 117 beta. Are these last (7 I think now) not relevant to us, or are we having an issue with package manager still ? Should I manually update to test ? Thanks mate, Shane
solabc16 379 Posted August 27, 2016 Posted August 27, 2016 Hello @@shad0h The latest beta and stable releases are now available. We just had a little bit to juggle, with regression testing for DSM release 6.0.2-8451, finalising the package for the Marvell architecture and the new stable release all coinciding. Once we have all of the architecures supported and in the public domain, this all gets a little easier. Thanks for your patience. - James 1
