D-Ruffy 3 Posted August 8, 2016 Posted August 8, 2016 (edited) Hallo zusammen, wir haben heute Mittag noch gemütlich Paar Folgen geguckt bis auf einemal ohne das sich etwas geändert hat Emby nach ca 3 Sekunden das Abspielen abbricht egal mit welchen Client System (getestet bis jetzt Fire TV, Web, Kodi, Android App, DLNA) Habe den Emby-Server schon ein paar mal neugestartet und auch den ganzen Server keiner Besserung. Im LOG steht nur folgendes http://10.10.20.3:8096/emby/videos/08099b7607d6d7328639bddb059fd250/stream.mkv?DeviceId=1f57fa3d19884f83&MediaSourceId=08099b7607d6d7328639bddb059fd250&VideoCodec=h264&AudioCodec=aac,mp3&AudioStreamIndex=1&VideoBitrate=3147333&AudioBitrate=128000&MaxAudioChannels=2&Level=51&Profile=high&PlaySessionId=de1fe040dc8c47d5b4d57d94a94e50cc&api_key=48eb4b23254e4835b0cb90473b1866a2&CopyTimestamps=true&ForceLiveStream=false&SubtitleMethod=Encode {"Protocol":"File","Id":"08099b7607d6d7328639bddb059fd250","Path":"E:\\Serien\\....mkv","Type":"Default","Container":"mkv","Name":"1080P/H264/AC3","RunTimeTicks":24073920000,"ReadAtNativeFramerate":false,"SupportsTranscoding":true,"SupportsDirectStream":true,"SupportsDirectPlay":true,"RequiresOpening":false,"RequiresClosing":false,"VideoType":"VideoFile","MediaStreams":[{"Codec":"h264","Language":"ger","TimeBase":"1/1000","CodecTimeBase":"1001/48000","Title":"folge","DisplayTitle":"folge","NalLengthSize":"4","IsInterlaced":false,"IsAVC":true,"BitRate":9544565,"BitDepth":8,"RefFrames":4,"IsDefault":true,"IsForced":true,"Height":1078,"Width":1920,"AverageFrameRate":25,"RealFrameRate":25,"Profile":"High","Type":"Video","AspectRatio":"16:9","Index":0,"IsExternal":false,"IsTextSubtitleStream":false,"SupportsExternalStream":false,"PixelFormat":"yuv420p","Level":41,"IsAnamorphic":false},{"Codec":"ac3","Language":"ger","TimeBase":"1/1000","CodecTimeBase":"1/48000","DisplayTitle":"Ger Dolby Digital 5.1 Default","IsInterlaced":false,"ChannelLayout":"5.1","BitRate":384000,"Channels":6,"SampleRate":48000,"IsDefault":true,"IsForced":true,"Type":"Audio","Index":1,"IsExternal":false,"IsTextSubtitleStream":false,"SupportsExternalStream":false,"Level":0},{"Codec":"ac3","Language":"eng","TimeBase":"1/1000","CodecTimeBase":"1/48000","DisplayTitle":"Eng Dolby Digital 5.1","IsInterlaced":false,"ChannelLayout":"5.1","BitRate":384000,"Channels":6,"SampleRate":48000,"IsDefault":false,"IsForced":false,"Type":"Audio","Index":2,"IsExternal":false,"IsTextSubtitleStream":false,"SupportsExternalStream":false,"Level":0}],"PlayableStreamFileNames":[],"Formats":[],"Bitrate":9544565,"RequiredHttpHeaders":{}} C:\Users\Admin\AppData\Roaming\Emby-Server\ffmpeg\20160410\ffmpeg.exe -fflags +genpts -i file:"E:\Serien\....mkv" -map 0:0 -map 0:1 -map -0:s -codec:v:0 libx264 -force_key_frames "expr:gte(t,n_forced*5)" -copyts -avoid_negative_ts disabled -start_at_zero -pix_fmt yuv420p -preset superfast -crf 23 -b:v 3147333 -maxrate 3147333 -bufsize 6294666 -vsync -1 -profile:v high -level 51 -map_metadata -1 -threads 0 -codec:a:0 aac -strict experimental -ac 2 -ab 128000 -af "aresample=async=1,volume=2" -y "C:\Users\Admin\AppData\Roaming\Emby-Server\transcoding-temp\0bcd90c51a00a055f4c203bceb13e186.mkv" ffmpeg version N-79277-g0c90b2e Copyright (c) 2000-2016 the FFmpeg developers built with gcc 5.3.0 (GCC) configuration: --enable-gpl --enable-version3 --disable-w32threads --enable-avisynth --enable-bzlib --enable-fontconfig --enable-frei0r --enable-gnutls --enable-iconv --enable-libass --enable-libbluray --enable-libbs2b --enable-libcaca --enable-libfreetype --enable-libgme --enable-libgsm --enable-libilbc --enable-libmodplug --enable-libmfx --enable-libmp3lame --enable-libopencore-amrnb --enable-libopencore-amrwb --enable-libopenjpeg --enable-libopus --enable-librtmp --enable-libschroedinger --enable-libsnappy --enable-libsoxr --enable-libspeex --enable-libtheora --enable-libtwolame --enable-libvidstab --enable-libvo-amrwbenc --enable-libvorbis --enable-libvpx --enable-libwavpack --enable-libwebp --enable-libx264 --enable-libx265 --enable-libxavs --enable-libxvid --enable-libzimg --enable-lzma --enable-decklink --enable-zlib libavutil 55. 20.100 / 55. 20.100 libavcodec 57. 34.100 / 57. 34.100 libavformat 57. 32.100 / 57. 32.100 libavdevice 57. 0.101 / 57. 0.101 libavfilter 6. 41.100 / 6. 41.100 libswscale 4. 1.100 / 4. 1.100 libswresample 2. 0.101 / 2. 0.101 libpostproc 54. 0.100 / 54. 0.100 Input #0, matroska,webm, from 'file:E:\Serien\....mkv': Metadata: title : Folge encoder : libebml v1.2.2 + libmatroska v1.3.0 creation_time : 2016-08-01 20:44:29 Duration: 00:40:07.39, start: 0.000000, bitrate: 9544 kb/s Stream #0:0(ger): Video: h264 (High), yuv420p, 1920x1078, SAR 1:1 DAR 960:539, 25 fps, 25 tbr, 1k tbn, 47.95 tbc (default) (forced) Metadata: title : folge Stream #0:1(ger): Audio: ac3, 48000 Hz, 5.1(side), fltp, 384 kb/s (default) (forced) Stream #0:2(eng): Audio: ac3, 48000 Hz, 5.1(side), fltp, 384 kb/s [libx264 @ 00000000006de880] using SAR=1/1 [libx264 @ 00000000006de880] using cpu capabilities: MMX2 SSE2Fast SSSE3 SSE4.2 AVX [libx264 @ 00000000006de880] profile High, level 5.1 [libx264 @ 00000000006de880] 264 - core 148 r2665 a01e339 - H.264/MPEG-4 AVC codec - Copyleft 2003-2016 - http://www.videolan.org/x264.html - options: cabac=1 ref=1 deblock=1:0:0 analyse=0x3:0x3 me=dia subme=1 psy=1 psy_rd=1.00:0.00 mixed_ref=0 me_range=16 chroma_me=1 trellis=0 8x8dct=1 cqm=0 deadzone=21,11 fast_pskip=1 chroma_qp_offset=0 threads=12 lookahead_threads=2 sliced_threads=0 nr=0 decimate=1 interlaced=0 bluray_compat=0 constrained_intra=0 bframes=3 b_pyramid=2 b_adapt=1 b_bias=0 direct=1 weightb=1 open_gop=0 weightp=1 keyint=250 keyint_min=25 scenecut=40 intra_refresh=0 rc_lookahead=0 rc=crf mbtree=0 crf=23.0 qcomp=0.60 qpmin=0 qpmax=69 qpstep=4 vbv_maxrate=3147 vbv_bufsize=6294 crf_max=0.0 nal_hrd=none filler=0 ip_ratio=1.40 pb_ratio=1.30 aq=1:1.00 Output #0, matroska, to 'C:\Users\Admin\AppData\Roaming\Emby-Server\transcoding-temp\0bcd90c51a00a055f4c203bceb13e186.mkv': Metadata: encoder : Lavf57.32.100 Stream #0:0: Video: h264 (libx264) (H264 / 0x34363248), yuv420p, 1920x1078 [SAR 1:1 DAR 960:539], q=-1--1, 3147 kb/s, 25 fps, 1k tbn, 25 tbc (default) (forced) Metadata: encoder : Lavc57.34.100 libx264 Side data: cpb: bitrate max/min/avg: 3147000/0/3147000 buffer size: 6294000 vbv_delay: -1 Stream #0:1: Audio: aac (LC) ([255][0][0][0] / 0x00FF), 48000 Hz, stereo, fltp, 128 kb/s (default) (forced) Metadata: encoder : Lavc57.34.100 aac Stream mapping: Stream #0:0 -> #0:0 (h264 (native) -> h264 (libx264)) Stream #0:1 -> #0:1 (ac3 (native) -> aac (native)) Press [q] to stop, [?] for help frame= 52 fps=0.0 q=26.0 size= 241kB time=00:00:02.60 bitrate= 758.3kbits/s speed= 5.2x frame= 104 fps=104 q=29.0 size= 1534kB time=00:00:04.50 bitrate=2790.7kbits/s speed=4.49x frame= 152 fps=101 q=27.0 size= 2348kB time=00:00:06.50 bitrate=2957.0kbits/s speed=4.32x frame= 203 fps=101 q=27.0 size= 2964kB time=00:00:08.59 bitrate=2824.3kbits/s speed=4.29x frame= 255 fps=101 q=28.0 size= 3787kB time=00:00:10.53 bitrate=2943.9kbits/s speed=4.17x frame= 308 fps=102 q=30.0 size= 4681kB time=00:00:12.69 bitrate=3021.0kbits/s speed=4.19x frame= 353 fps= 99 q=30.0 size= 5407kB time=00:00:14.63 bitrate=3026.7kbits/s speed=4.12x frame= 404 fps=100 q=30.0 size= 6270kB time=00:00:16.74 bitrate=3067.3kbits/s speed=4.13x frame= 463 fps=101 q=26.0 size= 7136kB time=00:00:18.96 bitrate=3082.1kbits/s speed=4.15x frame= 516 fps=101 q=26.0 size= 7950kB time=00:00:21.16 bitrate=3077.5kbits/s speed=4.14x frame= 571 fps=102 q=26.0 size= 8878kB time=00:00:23.31 bitrate=3119.1kbits/s speed=4.15x frame= 625 fps=102 q=24.0 size= 9730kB time=00:00:25.64 bitrate=3108.6kbits/s speed=4.19x frame= 681 fps=103 q=26.0 size= 10672kB time=00:00:27.67 bitrate=3159.5kbits/s speed=4.17x frame= 704 fps=101 q=-1.0 Lsize= 11337kB time=00:00:28.63 bitrate=3243.9kbits/s speed=4.13x video:10877kB audio:444kB subtitle:0kB other streams:0kB global headers:0kB muxing overhead: 0.137790% [libx264 @ 00000000006de880] frame I:12 Avg QP:15.96 size: 58865 [libx264 @ 00000000006de880] frame P:494 Avg QP:20.55 size: 17665 [libx264 @ 00000000006de880] frame B:198 Avg QP:21.12 size: 8606 [libx264 @ 00000000006de880] consecutive B-frames: 48.6% 41.5% 0.9% 9.1% [libx264 @ 00000000006de880] mb I I16..4: 48.5% 37.5% 14.1% [libx264 @ 00000000006de880] mb P I16..4: 16.4% 10.8% 0.3% P16..4: 32.5% 0.0% 0.0% 0.0% 0.0% skip:40.0% [libx264 @ 00000000006de880] mb B I16..4: 3.5% 2.6% 0.0% B16..8: 20.8% 0.0% 0.0% direct: 8.8% skip:64.2% L0:40.8% L1:53.3% BI: 5.9% [libx264 @ 00000000006de880] 8x8 transform intra:39.3% inter:61.7% Ich hoffe jemand hat eine Idee Danke und Gruß Edited August 8, 2016 by D-Ruffy
Luke 42239 Posted August 8, 2016 Posted August 8, 2016 Hallo, willkommen. Das Protokoll sieht für mich in Ordnung. Vielleicht kann die Verbindung nicht nur die Bitrate umgehen? Versuchen Sie, die Qualität zu 1mbps senken. Vielen Dank.
D-Ruffy 3 Posted August 8, 2016 Author Posted August 8, 2016 Hi Luke, Danke für die Antwort. Das hat bisher wunderbar funktioniert, es funktioniert jetzt auch nicht mehr bei Filmen die ich vorher ohne Probleme Gucken konnte. Ich habe grade mal ein Paar Filme von dem Server kopiert per UNC-Pfad und es mit stabilen 114MB/s kopiert die ganze Zeit daher sollte das Netzwerk nicht das Problem sein oder? Gruß
D-Ruffy 3 Posted August 9, 2016 Author Posted August 9, 2016 Hab Emby neuinstalliert, geht wieder Danke
Luke 42239 Posted August 10, 2016 Posted August 10, 2016 Hallo, es ist immer noch eine gute Idee, die Bitrate Einstellung zu versuchen, Senkung oder zumindest so dass es auf Auto .
Luke 42239 Posted August 10, 2016 Posted August 10, 2016 Hallo , ja , da Sie neu installiert , das bedeutet, dass die Bitrate Einstellung auf Auto zurück ist, wie ich vorgeschlagen. Genießen
