bluemonkey07 590 Posted August 7, 2016 Posted August 7, 2016 Server version 3.0.6030 Cinema mode set to only include local trailers yet clients still stream online trailers Checked with emby theatre and android tv, android mobile and web client
bluemonkey07 590 Posted August 21, 2016 Author Posted August 21, 2016 Still an issue with server version 3.0.6060
Luke 42186 Posted August 21, 2016 Posted August 21, 2016 I think it is actually only an issue for a small number of servers. I saw this recently. There is probably an old trailer hanging around in your database that is incorrectly marked as a local trailer (due to a defect in the server many months ago). I would suggest removing the channel plugin, letting the refresh channels and clean database operations run, then try installing it again.
bluemonkey07 590 Posted August 22, 2016 Author Posted August 22, 2016 (edited) OK i will try that and let you know how it goes Update: OK so seems that has highlighted another issue in that the trailers plugin will not uninstall via the web client so I will have to wait until I fly home tomorrow to uninstall manually Edited August 22, 2016 by Vidman
bluemonkey07 590 Posted August 24, 2016 Author Posted August 24, 2016 I think it is actually only an issue for a small number of servers. I saw this recently. There is probably an old trailer hanging around in your database that is incorrectly marked as a local trailer (due to a defect in the server many months ago). I would suggest removing the channel plugin, letting the refresh channels and clean database operations run, then try installing it again.Ok this ^^ seems to have done the trick
bluemonkey07 590 Posted August 24, 2016 Author Posted August 24, 2016 (edited) Whoops I spoke to soon I just got trailers for Kubo and Pete's dragon on android tv which i definitely don't have locally Edited August 24, 2016 by Vidman
