huladaddy 0 Posted August 7, 2016 Posted August 7, 2016 I have tried resetting the local database, repairing the local database, a manual sync, and I have just tried creating a new userdata folder, but no matter what I do, kodi will only sync my movies, and not my tv shows. The TV shows remain at 0. Any ideas? kodi.log
Angelblue05 4132 Posted August 7, 2016 Posted August 7, 2016 If you launch emby for Kodi > TV - Nothing shows? Can you enable the add-on log level set to Debug (found in the add-on settings > advanced)? Then, go to the metadata manager and hit save for one series in your TV shows. Wait a few minutes, then post your log. Thanks.
huladaddy 0 Posted August 7, 2016 Author Posted August 7, 2016 Yes, Emby for Kodi > TV = nothing! As soon as I saved the metadata for a particular show, it showed up on emby for kodi. Is there a way to update all the metadata for all the shows at once?
Angelblue05 4132 Posted August 7, 2016 Posted August 7, 2016 Odd? And a reset doesn't work? Do you have any add-on installed the cleans up entries? Without the log it's hard to say how to fix it... You can try a manual sync, or a repair sync (both are found by launching the emby add-on)
huladaddy 0 Posted August 7, 2016 Author Posted August 7, 2016 Do I have to worry about any sensitive data in the debug logs?
Angelblue05 4132 Posted August 7, 2016 Posted August 7, 2016 You can PM me the file in this case. Thank you.
