anderbytes 141 Posted August 6, 2016 Posted August 6, 2016 Now that hardware acceleration is widely used, I need to suggest that inside user configuration can give permissions to HW or SW encoding separately. Why? Maybe I want to allow only HW encoding because I don't want CPU spikes everywhere... Or maybe somebody only desire SW encodings because sees more quality in it...
Luke 42245 Posted August 6, 2016 Posted August 6, 2016 Why? Maybe I want to allow only HW encoding because I don't want CPU spikes everywhere... I suppose this is possible yes. Or maybe somebody only desire SW encodings because sees more quality in it... Permissions is not the same thing as desire. If you desire to switch it back and forth, then we should have that embedded into the video player.
MSattler 390 Posted August 6, 2016 Posted August 6, 2016 Now that hardware acceleration is widely used, I need to suggest that inside user configuration can give permissions to HW or SW encoding separately. Why? Maybe I want to allow only HW encoding because I don't want CPU spikes everywhere... Or maybe somebody only desire SW encodings because sees more quality in it... Are you asking Emby to be able to support HW or SW decoding per user? Or are you asking which we believe is better from actual usage?
anderbytes 141 Posted August 6, 2016 Author Posted August 6, 2016 Support HW or SW (or both) per user. I like being able to have more ways to configure my experience. Usually Linux users are like this... they don't like the K.I.S.S. :-))
anderbytes 141 Posted August 6, 2016 Author Posted August 6, 2016 I suppose this is possible yes. Permissions is not the same thing as desire. If you desire to switch it back and forth, then we should have that embedded into the video player. Then I misused the word 'desire' , hehe. But that's a good idea, too, if possible.
