MSattler 390 Posted August 5, 2016 Posted August 5, 2016 @@Luke, Is this possible? To me it seems the only way I can get the intro video to work is by forcing users to watch a trailer. I don't want to watch a trailer, just the intro video before the movie. thanks!
Luke 42186 Posted August 5, 2016 Posted August 5, 2016 In cinema mode config you should be able to configure it to 0 trailers.
MSattler 390 Posted August 5, 2016 Author Posted August 5, 2016 In cinema mode config you should be able to configure it to 0 trailers. No, it says value must be greater than or equal to 1. Thanks!
Solution Luke 42186 Posted August 5, 2016 Solution Posted August 5, 2016 ok. what if you just uncheck all of the trailer checkboxes?
MSattler 390 Posted August 5, 2016 Author Posted August 5, 2016 ok. what if you just uncheck all of the trailer checkboxes ahh, that seems to work. Thanks!
