Counterfitninja 6 Posted August 5, 2016 Posted August 5, 2016 Hi, Is there anyway to remove all decvices quickly? Mine appear to be massivly duplicated and removing them one by one seems very laborious Ta
dcook 303 Posted August 5, 2016 Posted August 5, 2016 This is a bug that is reported before, with the same device being listed over and over. To my knowledge no fix was made yet, and the answer from developer was that its normal and expected behavior We have also requested a delete all button, which has not been accepted yet.
CBers 7541 Posted August 5, 2016 Posted August 5, 2016 You could shut Emby server and delete all files under: %AppData%/MediaBrowser-Server/data/devices or %AppData%/Emby-Server/data/devices depending on when you installed Emby.
