Jonz 11 Posted August 5, 2016 Posted August 5, 2016 I have a LG 42LS5700 TV (Netcast) which is connecting via DLNA to Emby Server running on OSX. Here are the problems faced :- 1.) Timeout when trying to play movie files from the dlna folder "Movies" - there is hundreds of media files here 2.) TV crashes and restarts itself when trying to browser dlna folder "Latest" - there is hundreds of media files here 3.) I've tried playing another movie file on a different library and it works , but this only contains 3 media files. This started to happen only a month ago, i've been using my LG TV without any issues before this. I am using the latest version of Emby Server and it still does not help the situation. Do assist to find the root cause of this. I've attached my latest log file. Thanks server-63605984903.txt
Luke 42237 Posted August 5, 2016 Posted August 5, 2016 Hi, sorry to hear about this. Does the TV indicate a timeout error or is that what you're gathering based on activity? the emby server log looks OK. I have an LG that I can test with so we should be able to work together on this to get it figured out. thanks.
Jonz 11 Posted August 7, 2016 Author Posted August 7, 2016 Hi, sorry to hear about this. Does the TV indicate a timeout error or is that what you're gathering based on activity? the emby server log looks OK. I have an LG that I can test with so we should be able to work together on this to get it figured out. thanks. Thanks Luke, Well, the TV goes on an infinite "Loading" and finally will come up with "Unknown Error" prompt. Here is the latest log again. I've turn off my other TV so it's easier to pin point the LG TV i'm referring to. There is quite a lot of error in the log, any idea what those are? server-63606124800.txt
Luke 42237 Posted August 8, 2016 Posted August 8, 2016 Have you created a custom lg dlna profile? if so, can you try deleting it and comparing to the stock profile? thanks.
Jonz 11 Posted August 28, 2016 Author Posted August 28, 2016 Have you created a custom lg dlna profile? if so, can you try deleting it and comparing to the stock profile? thanks. Tried using stock profile still no go for me. I have posted the below logs. The profile is just a mirror of the stock profile , i just changed the name of the emby server so i can easily identify my TV is picking up the right profile. Can you assist further? The below is an excerpt of the error from logs. 2016-08-28 15:12:41.5107 Info HttpServer: HTTP Response 200 to 192.168.1.219. Time: 72ms. http://192.168.1.6:8096/dlna/64c20dc96904d561182102a04b57ce0e/contentdirectory/control 2016-08-28 15:12:41.5148 Info HttpServer: HTTP GET http://192.168.1.6:8096/dlna/64c20dc96904d561182102a04b57ce0e/icons/logo240.png. UserAgent: FXUI 2016-08-28 15:12:41.5159 Info HttpServer: HTTP Response 200 to 192.168.1.219. Time: 1ms. http://192.168.1.6:8096/dlna/64c20dc96904d561182102a04b57ce0e/icons/logo240.png 2016-08-28 15:12:42.2793 Info HttpServer: HTTP POST http://192.168.1.6:8096/dlna/64c20dc96904d561182102a04b57ce0e/contentdirectory/control. UserAgent: Linux/2.6.35 UPnP/1.0 DLNADOC/1.50 INTEL_NMPR/2.0 LGE_DLNA_SDK/1.6.0 2016-08-28 15:12:42.3803 Error UpnpContentDirectory: Error processing control request *** Error Report *** Version: 3.0.6200.0 Command line: /Applications/Emby.Server.Mac.app/Contents/MonoBundle/Emby.Server.Mac.exe Operating system: Unix 15.5.0.0 Processor count: 4 64-Bit OS: False 64-Bit Process: False Program data path: /Users/Jonz/.config/emby-server Mono: 4.4.2 (mono-4.4.0-branch-c7sr1/f72fe45) Application Path: /Applications/Emby.Server.Mac.app/Contents/MonoBundle/Emby.Server.Mac.exe One or more errors occurred. server-63607976577.txt
Luke 42237 Posted August 28, 2016 Posted August 28, 2016 Hi, the new 3.0.6300 has some dlna improvements. can you try that? thanks!
Jonz 11 Posted August 30, 2016 Author Posted August 30, 2016 (edited) Hi, the new 3.0.6300 has some dlna improvements. can you try that? thanks! On latest 3.0.6400 , same issues. Have a look at the log. Using default profile. Crashes the TV when i browse to "Latest" folder. Can't play movie files. 2016-08-30 12:22:01.8500 Info HttpServer: HTTP GET http://192.168.1.6:8096/dlna/64c20dc96904d561182102a04b57ce0e/description.xml. UserAgent: DAFUPnP 2016-08-30 12:22:01.8643 Info Dlna: No matching device profile found. The default will need to be used. Cache-Control: no-cache Connection: Keep-Alive Pragma: no-cache Accept: text/xml, application/xml User-Agent: DAFUPnP Host: 192.168.1.6:8096 2016-08-30 12:22:05.3656 Info HttpServer: HTTP GET http://192.168.1.6:8096/dlna/64c20dc96904d561182102a04b57ce0e/description.xml. UserAgent: DAFUPnP 2016-08-30 12:22:05.3674 Info Dlna: No matching device profile found. The default will need to be used. Cache-Control: no-cache Connection: Keep-Alive Pragma: no-cache Accept: text/xml, application/xml User-Agent: DAFUPnP Host: 192.168.1.6:8096 2016-08-30 12:22:05.3730 Info HttpServer: HTTP Response 200 to 192.168.1.182. Time: 3524ms (slow). http://192.168.1.6:8096/dlna/64c20dc96904d561182102a04b57ce0e/description.xml 2016-08-30 12:22:05.4337 Info HttpServer: HTTP Response 200 to 192.168.1.182. Time: 68ms. http://192.168.1.6:8096/dlna/64c20dc96904d561182102a04b57ce0e/description.xml 2016-08-30 12:22:05.4345 Info HttpServer: HTTP GET http://192.168.1.6:8096/dlna/64c20dc96904d561182102a04b57ce0e/description.xml. UserAgent: Microsoft-Windows/6.3 UPnP/1.0 2016-08-30 12:22:05.4361 Info Dlna: No matching device profile found. The default will need to be used. Cache-Control: no-cache Connection: Close Pragma: no-cache Accept: text/xml, application/xml User-Agent: Microsoft-Windows/6.3 UPnP/1.0 Host: 192.168.1.6:8096 2016-08-30 12:22:08.8733 Info HttpServer: HTTP Response 200 to 192.168.1.182. Time: 3439ms (slow). http://192.168.1.6:8096/dlna/64c20dc96904d561182102a04b57ce0e/description.xml 2016-08-30 12:22:08.8733 Info HttpServer: HTTP GET http://192.168.1.6:8096/dlna/64c20dc96904d561182102a04b57ce0e/description.xml. UserAgent: Microsoft-Windows/6.3 UPnP/1.0 2016-08-30 12:22:08.8756 Info Dlna: No matching device profile found. The default will need to be used. Cache-Control: no-cache Connection: Close Pragma: no-cache Accept: text/xml, application/xml User-Agent: Microsoft-Windows/6.3 UPnP/1.0 Host: 192.168.1.6:8096 2016-08-30 12:22:08.9116 Info HttpServer: HTTP Response 200 to 192.168.1.182. Time: 38ms. http://192.168.1.6:8096/dlna/64c20dc96904d561182102a04b57ce0e/description.xml 2016-08-30 12:22:08.9116 Info HttpServer: HTTP GET http://localhost:8096/. UserAgent: Mozilla/5.0 (Macintosh; Intel Mac OS X 10_11_5) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/54.0.2837.0 Safari/537.36 2016-08-30 12:22:08.9181 Info HttpServer: HTTP GET http://192.168.1.6:8096/dlna/64c20dc96904d561182102a04b57ce0e/icons/logo240.png. UserAgent: User-Agent: Microsoft-DLNA DLNADOC/1.50 2016-08-30 12:22:12.5131 Info HttpServer: HTTP GET http://192.168.1.6:8096/dlna/64c20dc96904d561182102a04b57ce0e/icons/logo240.jpg. UserAgent: User-Agent: Microsoft-DLNA DLNADOC/1.50 2016-08-30 12:22:12.5146 Info HttpServer: HTTP Response 200 to 192.168.1.182. Time: 3597ms (slow). http://192.168.1.6:8096/dlna/64c20dc96904d561182102a04b57ce0e/icons/logo240.png 2016-08-30 12:22:12.5170 Info HttpServer: HTTP GET http://192.168.1.6:8096/dlna/64c20dc96904d561182102a04b57ce0e/icons/logo120.png. UserAgent: User-Agent: Microsoft-DLNA DLNADOC/1.50 2016-08-30 12:22:12.5185 Info HttpServer: HTTP Response 200 to 192.168.1.182. Time: 5ms. http://192.168.1.6:8096/dlna/64c20dc96904d561182102a04b57ce0e/icons/logo240.jpg 2016-08-30 12:22:12.5309 Info HttpServer: HTTP Response 200 to 192.168.1.182. Time: 14ms. http://192.168.1.6:8096/dlna/64c20dc96904d561182102a04b57ce0e/icons/logo120.png 2016-08-30 12:22:12.5375 Info HttpServer: HTTP GET http://192.168.1.6:8096/dlna/64c20dc96904d561182102a04b57ce0e/icons/logo120.jpg. UserAgent: User-Agent: Microsoft-DLNA DLNADOC/1.50 2016-08-30 12:22:12.5529 Info HttpServer: HTTP Response 200 to 192.168.1.182. Time: 16ms. http://192.168.1.6:8096/dlna/64c20dc96904d561182102a04b57ce0e/icons/logo120.jpg 2016-08-30 12:22:12.5567 Info HttpClient: HttpClientManager POST: https://www.mb3admin.com/admin/service/registration/validate 2016-08-30 12:22:12.5567 Info HttpClient: HttpClientManager POST: https://connect.emby.media/service/Servers?id=a89be7b8a09cbbb675f0878532ef2d68 2016-08-30 12:22:12.5599 Info HttpServer: HTTP GET http://192.168.1.6:8096/dlna/64c20dc96904d561182102a04b57ce0e/icons/logo48.png. UserAgent: User-Agent: Microsoft-DLNA DLNADOC/1.50 2016-08-30 12:22:12.5639 Info HttpServer: HTTP Response 200 to 192.168.1.182. Time: 4ms. http://192.168.1.6:8096/dlna/64c20dc96904d561182102a04b57ce0e/icons/logo48.png 2016-08-30 12:22:12.5642 Info App: Entry point completed: MediaBrowser.Server.Implementations.Connect.ConnectEntryPoint 2016-08-30 12:22:12.5642 Info App: Starting entry point MediaBrowser.Server.Implementations.FileOrganization.FileOrganizationNotifier 2016-08-30 12:22:12.5663 Info App: Entry point completed: MediaBrowser.Server.Implementations.FileOrganization.FileOrganizationNotifier 2016-08-30 12:22:12.5663 Info App: Starting entry point MediaBrowser.Server.Implementations.EntryPoints.UdpServerEntryPoint 2016-08-30 12:22:12.5683 Info App: Entry point completed: MediaBrowser.Server.Implementations.EntryPoints.UdpServerEntryPoint 2016-08-30 12:22:12.5683 Info App: Starting entry point MediaBrowser.Server.Implementations.EntryPoints.ServerEventNotifier 2016-08-30 12:22:12.5699 Info HttpServer: HTTP GET http://192.168.1.6:8096/dlna/64c20dc96904d561182102a04b57ce0e/icons/logo48.jpg. UserAgent: User-Agent: Microsoft-DLNA DLNADOC/1.50 2016-08-30 12:22:12.5713 Info App: Entry point completed: MediaBrowser.Server.Implementations.EntryPoints.ServerEventNotifier 2016-08-30 12:22:12.5713 Info App: Starting entry point MediaBrowser.Server.Implementations.EntryPoints.UserDataChangeNotifier 2016-08-30 12:22:12.5713 Info App: Entry point completed: MediaBrowser.Server.Implementations.EntryPoints.UserDataChangeNotifier 2016-08-30 12:22:12.5713 Info App: Starting entry point MediaBrowser.Server.Implementations.IO.LibraryMonitorStartup 2016-08-30 12:22:12.5729 Info HttpServer: HTTP Response 200 to 192.168.1.182. Time: 3ms. http://192.168.1.6:8096/dlna/64c20dc96904d561182102a04b57ce0e/icons/logo48.jpg 2016-08-30 12:22:12.5893 Info HttpServer: HTTP GET http://192.168.1.6:8096/dlna/64c20dc96904d561182102a04b57ce0e/contentdirectory/contentdirectory.xml. UserAgent: Microsoft-Windows/6.3 UPnP/1.0 2016-08-30 12:22:12.6070 Info HttpServer: HTTP Response 200 to 192.168.1.182. Time: 18ms. http://192.168.1.6:8096/dlna/64c20dc96904d561182102a04b57ce0e/contentdirectory/contentdirectory.xml 2016-08-30 12:22:12.7259 Info App: Entry point completed: MediaBrowser.Server.Implementations.IO.LibraryMonitorStartup 2016-08-30 12:22:12.7259 Info App: Starting entry point MediaBrowser.Server.Implementations.LiveTv.EmbyTV.EntryPoint 2016-08-30 12:22:12.7288 Info App: Loading live tv data from /Users/Jonz/.config/emby-server/data/livetv/timers 2016-08-30 12:22:12.7468 Info App: Entry point completed: MediaBrowser.Server.Implementations.LiveTv.EmbyTV.EntryPoint 2016-08-30 12:22:12.7468 Info App: Starting entry point MediaBrowser.Server.Implementations.LiveTv.TunerHosts.HdHomerun.HdHomerunDiscovery 2016-08-30 12:22:12.7475 Info App: Entry point completed: MediaBrowser.Server.Implementations.LiveTv.TunerHosts.HdHomerun.HdHomerunDiscovery 2016-08-30 12:22:12.7475 Info App: Starting entry point MediaBrowser.Server.Implementations.LiveTv.TunerHosts.SatIp.SatIpDiscovery 2016-08-30 12:22:12.7475 Info HttpServer: HTTP GET http://192.168.1.6:8096/dlna/64c20dc96904d561182102a04b57ce0e/icons/logo120.png. UserAgent: User-Agent: Microsoft-DLNA DLNADOC/1.50 2016-08-30 12:22:12.7475 Info App: Entry point completed: MediaBrowser.Server.Implementations.LiveTv.TunerHosts.SatIp.SatIpDiscovery 2016-08-30 12:22:12.7475 Info App: Starting entry point MediaBrowser.Server.Implementations.Sync.SyncNotificationEntryPoint 2016-08-30 12:22:12.7475 Info App: Entry point completed: MediaBrowser.Server.Implementations.Sync.SyncNotificationEntryPoint 2016-08-30 12:22:12.7490 Info HttpServer: HTTP Response 200 to 192.168.1.182. Time: 2ms. http://192.168.1.6:8096/dlna/64c20dc96904d561182102a04b57ce0e/icons/logo120.png 2016-08-30 12:22:12.7490 Info App: Starting entry point MediaBrowser.Server.Implementations.News.NewsEntryPoint 2016-08-30 12:22:12.7498 Info App: Entry point completed: MediaBrowser.Server.Implementations.News.NewsEntryPoint 2016-08-30 12:22:12.7498 Info App: All entry points have started 2016-08-30 12:22:12.7551 Info HttpServer: HTTP GET http://192.168.1.6:8096/dlna/64c20dc96904d561182102a04b57ce0e/icons/logo120.jpg. UserAgent: User-Agent: Microsoft-DLNA DLNADOC/1.50 2016-08-30 12:22:12.7564 Info HttpServer: HTTP Response 200 to 192.168.1.182. Time: 1ms. http://192.168.1.6:8096/dlna/64c20dc96904d561182102a04b57ce0e/icons/logo120.jpg 2016-08-30 12:22:12.7640 Info HttpServer: HTTP GET http://192.168.1.6:8096/dlna/64c20dc96904d561182102a04b57ce0e/icons/logo48.png. UserAgent: User-Agent: Microsoft-DLNA DLNADOC/1.50 2016-08-30 12:22:12.7653 Info HttpServer: HTTP Response 200 to 192.168.1.182. Time: 1ms. http://192.168.1.6:8096/dlna/64c20dc96904d561182102a04b57ce0e/icons/logo48.png 2016-08-30 12:22:12.7855 Info HttpServer: HTTP GET http://192.168.1.6:8096/dlna/64c20dc96904d561182102a04b57ce0e/contentdirectory/contentdirectory.xml. UserAgent: Microsoft-Windows/6.3 UPnP/1.0 2016-08-30 12:22:12.7871 Info HttpServer: HTTP Response 200 to 192.168.1.182. Time: 2ms. http://192.168.1.6:8096/dlna/64c20dc96904d561182102a04b57ce0e/contentdirectory/contentdirectory.xml 2016-08-30 12:22:12.8869 Info HttpClient: HttpClientManager GET: https://connect.emby.media/service/ServerAuthorizations?serverId=a89be7b8a09cbbb675f0878532ef2d68 2016-08-30 12:22:13.2541 Info HttpClient: HttpClientManager GET: http://emby.media/community/index.php?/blog/rss/1-media-browser-developers-blog 2016-08-30 12:22:14.2914 Info TaskManager: Check for application updates Completed after 0 minute(s) and 15 seconds 2016-08-30 12:22:14.2997 Info TaskManager: ExecuteQueuedTasks 2016-08-30 12:22:17.5676 Info HttpClient: HttpClientManager GET: http://bot.whatismyipaddress.com 2016-08-30 12:22:18.1600 Info HttpClient: HttpClientManager POST: https://connect.emby.media/service/Servers?id=a89be7b8a09cbbb675f0878532ef2d68 2016-08-30 12:22:18.4973 Info HttpClient: HttpClientManager GET: https://connect.emby.media/service/ServerAuthorizations?serverId=a89be7b8a09cbbb675f0878532ef2d68 2016-08-30 12:22:32.2323 Info HttpServer: WS ws://localhost:8096/embywebsocket?api_key=c1e0f4d32c2741fab229fdff24f6aa16&deviceId=27cd771778cfc4247b239495a247bdc9. UserAgent: Mozilla/5.0 (Macintosh; Intel Mac OS X 10_11_5) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/54.0.2837.0 Safari/537.36 2016-08-30 12:22:32.3107 Info App: ScheduledTasksWebSocketListener Begin transmitting over websocket to 127.0.0.1:55713 2016-08-30 12:22:32.3163 Info App: SessionInfoWebSocketListener Begin transmitting over websocket to 127.0.0.1:55713 2016-08-30 12:22:32.3320 Info App: ActivityLogWebSocketListener Begin transmitting over websocket to 127.0.0.1:55713 2016-08-30 12:22:32.5936 Info App: App Activity: app: Emby Mobile, version: 3.0.6400.0, deviceId: 27cd771778cfc4247b239495a247bdc9, deviceName: Chrome 54.0.2837.0 2016-08-30 12:22:32.7344 Info HttpServer: HTTP GET http://localhost:8096/emby/System/ActivityLog/Entries?startIndex=0&limit=7&minDate=2016-08-29T04:22:32.719Z. UserAgent: Mozilla/5.0 (Macintosh; Intel Mac OS X 10_11_5) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/54.0.2837.0 Safari/537.36 2016-08-30 12:22:32.8220 Info HttpServer: HTTP Response 200 to 127.0.0.1. Time: 91ms. http://localhost:8096/emby/System/ActivityLog/Entries?startIndex=0&limit=7&minDate=2016-08-29T04:22:32.719Z 2016-08-30 12:22:32.9749 Info App: ActivityLogWebSocketListener Begin transmitting over websocket to 127.0.0.1:55713 2016-08-30 12:22:32.9808 Info App: ScheduledTasksWebSocketListener stop transmitting over websocket to 127.0.0.1:55713 2016-08-30 12:22:32.9808 Info App: SessionInfoWebSocketListener stop transmitting over websocket to 127.0.0.1:55713 2016-08-30 12:22:32.9808 Info App: ActivityLogWebSocketListener stop transmitting over websocket to 127.0.0.1:55713 2016-08-30 12:22:33.2347 Info HttpServer: HTTP GET http://localhost:8096/emby/System/Configuration/dlna. UserAgent: Mozilla/5.0 (Macintosh; Intel Mac OS X 10_11_5) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/54.0.2837.0 Safari/537.36 2016-08-30 12:22:33.2347 Info HttpServer: HTTP GET http://localhost:8096/emby/users. UserAgent: Mozilla/5.0 (Macintosh; Intel Mac OS X 10_11_5) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/54.0.2837.0 Safari/537.36 2016-08-30 12:22:33.2742 Info HttpServer: HTTP Response 200 to 127.0.0.1. Time: 40ms. http://localhost:8096/emby/System/Configuration/dlna 2016-08-30 12:22:33.3242 Info HttpServer: HTTP Response 200 to 127.0.0.1. Time: 89ms. http://localhost:8096/emby/users 2016-08-30 12:22:37.7262 Info HttpServer: HTTP GET http://localhost:8096/emby/System/Configuration/dlna. UserAgent: Mozilla/5.0 (Macintosh; Intel Mac OS X 10_11_5) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/54.0.2837.0 Safari/537.36 2016-08-30 12:22:37.7368 Info HttpServer: HTTP Response 200 to 127.0.0.1. Time: 11ms. http://localhost:8096/emby/System/Configuration/dlna 2016-08-30 12:22:37.7486 Info HttpServer: HTTP POST http://localhost:8096/emby/System/Configuration/dlna. UserAgent: Mozilla/5.0 (Macintosh; Intel Mac OS X 10_11_5) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/54.0.2837.0 Safari/537.36 2016-08-30 12:22:37.7765 Info HttpServer: HTTP Response 204 to 127.0.0.1. Time: 28ms. http://localhost:8096/emby/System/Configuration/dlna 2016-08-30 12:22:55.6268 Error SsdpHandler: Error sending Datagram to 239.255.255.250:1900 from 127.0.0.1:1900: M-SEARCH * HTTP/1.1 . HOST: 239.255.255.250:1900 . USER-AGENT: UPnP/1.0 DLNADOC/1.50 Platinum/1.0.4.2 . X-EMBY-SERVERID: 5a1c2a99373a4bb9a4ca437d90e23a5e . MAN: "ssdp:discover" . ST: ssdp:all . MX: 3 . . *** Error Report *** Version: 3.0.6400.0 Command line: /Applications/Emby.Server.Mac.app/Contents/MonoBundle/Emby.Server.Mac.exe /Applications/Emby.Server.Mac.app/Contents/MonoBundle/Emby.Server.Mac.exe Operating system: Unix 15.5.0.0 Processor count: 4 64-Bit OS: False 64-Bit Process: False Program data path: /Users/Jonz/.config/emby-server Mono: 4.4.2 (mono-4.4.0-branch-c7sr1/f72fe45) Application Path: /Applications/Emby.Server.Mac.app/Contents/MonoBundle/Emby.Server.Mac.exe The requested address is not valid in this context System.Net.Sockets.SocketException at System.Net.Sockets.Socket.EndSend (IAsyncResult result) <0x10b7bb30 + 0x0008b> in <filename unknown>:0 at MediaBrowser.Dlna.Ssdp.Datagram+<Send>c__AnonStorey0.<>m__0 (IAsyncResult result) <0x10b7b610 + 0x00027> in <filename unknown>:0 2016-08-30 12:22:56.1211 Error SsdpHandler: Error sending Datagram to 239.255.255.250:1900 from 127.0.0.1:1900: M-SEARCH * HTTP/1.1 . HOST: 239.255.255.250:1900 . USER-AGENT: UPnP/1.0 DLNADOC/1.50 Platinum/1.0.4.2 . X-EMBY-SERVERID: 5a1c2a99373a4bb9a4ca437d90e23a5e . MAN: "ssdp:discover" . ST: ssdp:all . MX: 3 . . *** Error Report *** Version: 3.0.6400.0 Command line: /Applications/Emby.Server.Mac.app/Contents/MonoBundle/Emby.Server.Mac.exe /Applications/Emby.Server.Mac.app/Contents/MonoBundle/Emby.Server.Mac.exe Operating system: Unix 15.5.0.0 Processor count: 4 64-Bit OS: False 64-Bit Process: False Program data path: /Users/Jonz/.config/emby-server Mono: 4.4.2 (mono-4.4.0-branch-c7sr1/f72fe45) Application Path: /Applications/Emby.Server.Mac.app/Contents/MonoBundle/Emby.Server.Mac.exe The requested address is not valid in this context System.Net.Sockets.SocketException at System.Net.Sockets.Socket.EndSend (IAsyncResult result) <0x10b7bb30 + 0x0008b> in <filename unknown>:0 at MediaBrowser.Dlna.Ssdp.Datagram+<Send>c__AnonStorey0.<>m__0 (IAsyncResult result) <0x10b7b610 + 0x00027> in <filename unknown>:0 2016-08-30 12:22:56.6237 Error SsdpHandler: Error sending Datagram to 239.255.255.250:1900 from 127.0.0.1:1900: M-SEARCH * HTTP/1.1 . HOST: 239.255.255.250:1900 . USER-AGENT: UPnP/1.0 DLNADOC/1.50 Platinum/1.0.4.2 . X-EMBY-SERVERID: 5a1c2a99373a4bb9a4ca437d90e23a5e . MAN: "ssdp:discover" . ST: ssdp:all . MX: 3 . . *** Error Report *** Version: 3.0.6400.0 Command line: /Applications/Emby.Server.Mac.app/Contents/MonoBundle/Emby.Server.Mac.exe /Applications/Emby.Server.Mac.app/Contents/MonoBundle/Emby.Server.Mac.exe Operating system: Unix 15.5.0.0 Processor count: 4 64-Bit OS: False 64-Bit Process: False Program data path: /Users/Jonz/.config/emby-server Mono: 4.4.2 (mono-4.4.0-branch-c7sr1/f72fe45) Application Path: /Applications/Emby.Server.Mac.app/Contents/MonoBundle/Emby.Server.Mac.exe The requested address is not valid in this context System.Net.Sockets.SocketException at System.Net.Sockets.Socket.EndSend (IAsyncResult result) <0x10b7bb30 + 0x0008b> in <filename unknown>:0 at MediaBrowser.Dlna.Ssdp.Datagram+<Send>c__AnonStorey0.<>m__0 (IAsyncResult result) <0x10b7b610 + 0x00027> in <filename unknown>:0 2016-08-30 12:22:58.5605 Error SsdpHandler: Error sending Datagram to 239.255.255.250:1900 from 127.0.0.1:0: NOTIFY * HTTP/1.1 . HOST: 239.255.255.250:1900 . CACHE-CONTROL: max-age = 600 . LOCATION: http://127.0.0.1:8096/dlna/a88351a89d11084d89af5baef10ce1d7/description.xml . SERVER: Unix32/15.5 UPnP/1.0 DLNADOC/1.5 Emby/3.0.6400.0 . NTS: ssdp:alive . NT: upnp:rootdevice . USN: uuid:a88351a89d11084d89af5baef10ce1d7::upnp:rootdevice . . *** Error Report *** Version: 3.0.6400.0 Command line: /Applications/Emby.Server.Mac.app/Contents/MonoBundle/Emby.Server.Mac.exe /Applications/Emby.Server.Mac.app/Contents/MonoBundle/Emby.Server.Mac.exe Operating system: Unix 15.5.0.0 Processor count: 4 64-Bit OS: False 64-Bit Process: False Program data path: /Users/Jonz/.config/emby-server Mono: 4.4.2 (mono-4.4.0-branch-c7sr1/f72fe45) Application Path: /Applications/Emby.Server.Mac.app/Contents/MonoBundle/Emby.Server.Mac.exe The requested address is not valid in this context System.Net.Sockets.SocketException at System.Net.Sockets.Socket.EndSend (IAsyncResult result) <0x10b7bb30 + 0x0008b> in <filename unknown>:0 at MediaBrowser.Dlna.Ssdp.Datagram+<Send>c__AnonStorey0.<>m__0 (IAsyncResult result) <0x10b7b610 + 0x00027> in <filename unknown>:0 2016-08-30 12:22:58.5616 Error SsdpHandler: Error sending Datagram to 239.255.255.250:1900 from 127.0.0.1:0: NOTIFY * HTTP/1.1 . HOST: 239.255.255.250:1900 . CACHE-CONTROL: max-age = 600 . LOCATION: http://127.0.0.1:8096/dlna/a88351a89d11084d89af5baef10ce1d7/description.xml . SERVER: Unix32/15.5 UPnP/1.0 DLNADOC/1.5 Emby/3.0.6400.0 . NTS: ssdp:alive . NT: urn:schemas-upnp-org:device:MediaServer:1 . USN: uuid:a88351a89d11084d89af5baef10ce1d7::urn:schemas-upnp-org:device:MediaServer:1 . . *** Error Report *** Version: 3.0.6400.0 Command line: /Applications/Emby.Server.Mac.app/Contents/MonoBundle/Emby.Server.Mac.exe /Applications/Emby.Server.Mac.app/Contents/MonoBundle/Emby.Server.Mac.exe Operating system: Unix 15.5.0.0 Processor count: 4 64-Bit OS: False 64-Bit Process: False Program data path: /Users/Jonz/.config/emby-server Mono: 4.4.2 (mono-4.4.0-branch-c7sr1/f72fe45) Application Path: /Applications/Emby.Server.Mac.app/Contents/MonoBundle/Emby.Server.Mac.exe The requested address is not valid in this context System.Net.Sockets.SocketException at System.Net.Sockets.Socket.EndSend (IAsyncResult result) <0x10b7bb30 + 0x0008b> in <filename unknown>:0 at MediaBrowser.Dlna.Ssdp.Datagram+<Send>c__AnonStorey0.<>m__0 (IAsyncResult result) <0x10b7b610 + 0x00027> in <filename unknown>:0 2016-08-30 12:22:58.5674 Error SsdpHandler: Error sending Datagram to 239.255.255.250:1900 from 127.0.0.1:0: NOTIFY * HTTP/1.1 . HOST: 239.255.255.250:1900 . CACHE-CONTROL: max-age = 600 . LOCATION: http://127.0.0.1:8096/dlna/a88351a89d11084d89af5baef10ce1d7/description.xml . SERVER: Unix32/15.5 UPnP/1.0 DLNADOC/1.5 Emby/3.0.6400.0 . NTS: ssdp:alive . NT: urn:schemas-upnp-org:service:ContentDirectory:1 . USN: uuid:a88351a89d11084d89af5baef10ce1d7::urn:schemas-upnp-org:service:ContentDirectory:1 . . *** Error Report *** Version: 3.0.6400.0 Command line: /Applications/Emby.Server.Mac.app/Contents/MonoBundle/Emby.Server.Mac.exe /Applications/Emby.Server.Mac.app/Contents/MonoBundle/Emby.Server.Mac.exe Operating system: Unix 15.5.0.0 Processor count: 4 64-Bit OS: False 64-Bit Process: False Program data path: /Users/Jonz/.config/emby-server Mono: 4.4.2 (mono-4.4.0-branch-c7sr1/f72fe45) Application Path: /Applications/Emby.Server.Mac.app/Contents/MonoBundle/Emby.Server.Mac.exe The requested address is not valid in this context System.Net.Sockets.SocketException at System.Net.Sockets.Socket.EndSend (IAsyncResult result) <0x10b7bb30 + 0x0008b> in <filename unknown>:0 at MediaBrowser.Dlna.Ssdp.Datagram+<Send>c__AnonStorey0.<>m__0 (IAsyncResult result) <0x10b7b610 + 0x00027> in <filename unknown>:0 2016-08-30 12:22:58.5714 Error SsdpHandler: Error sending Datagram to 239.255.255.250:1900 from 127.0.0.1:0: NOTIFY * HTTP/1.1 . HOST: 239.255.255.250:1900 . CACHE-CONTROL: max-age = 600 . LOCATION: http://127.0.0.1:8096/dlna/a88351a89d11084d89af5baef10ce1d7/description.xml . SERVER: Unix32/15.5 UPnP/1.0 DLNADOC/1.5 Emby/3.0.6400.0 . NTS: ssdp:alive . NT: urn:microsoft.com:service:X_MS_MediaReceiverRegistrar:1 . USN: uuid:a88351a89d11084d89af5baef10ce1d7::urn:microsoft.com:service:X_MS_MediaReceiverRegistrar:1 . . *** Error Report *** Version: 3.0.6400.0 Command line: /Applications/Emby.Server.Mac.app/Contents/MonoBundle/Emby.Server.Mac.exe /Applications/Emby.Server.Mac.app/Contents/MonoBundle/Emby.Server.Mac.exe Operating system: Unix 15.5.0.0 Processor count: 4 64-Bit OS: False 64-Bit Process: False Program data path: /Users/Jonz/.config/emby-server Mono: 4.4.2 (mono-4.4.0-branch-c7sr1/f72fe45) Application Path: /Applications/Emby.Server.Mac.app/Contents/MonoBundle/Emby.Server.Mac.exe The requested address is not valid in this context System.Net.Sockets.SocketException at System.Net.Sockets.Socket.EndSend (IAsyncResult result) <0x10b7bb30 + 0x0008b> in <filename unknown>:0 at MediaBrowser.Dlna.Ssdp.Datagram+<Send>c__AnonStorey0.<>m__0 (IAsyncResult result) <0x10b7b610 + 0x00027> in <filename unknown>:0 2016-08-30 12:22:58.5777 Error SsdpHandler: Error sending Datagram to 239.255.255.250:1900 from 127.0.0.1:0: NOTIFY * HTTP/1.1 . HOST: 239.255.255.250:1900 . CACHE-CONTROL: max-age = 600 . LOCATION: http://127.0.0.1:8096/dlna/a88351a89d11084d89af5baef10ce1d7/description.xml . SERVER: Unix32/15.5 UPnP/1.0 DLNADOC/1.5 Emby/3.0.6400.0 . NTS: ssdp:alive . NT: urn:schemas-upnp-org:service:ConnectionManager:1 . USN: uuid:a88351a89d11084d89af5baef10ce1d7::urn:schemas-upnp-org:service:ConnectionManager:1 . . *** Error Report *** Version: 3.0.6400.0 Command line: /Applications/Emby.Server.Mac.app/Contents/MonoBundle/Emby.Server.Mac.exe /Applications/Emby.Server.Mac.app/Contents/MonoBundle/Emby.Server.Mac.exe Operating system: Unix 15.5.0.0 Processor count: 4 64-Bit OS: False 64-Bit Process: False Program data path: /Users/Jonz/.config/emby-server Mono: 4.4.2 (mono-4.4.0-branch-c7sr1/f72fe45) Application Path: /Applications/Emby.Server.Mac.app/Contents/MonoBundle/Emby.Server.Mac.exe The requested address is not valid in this context System.Net.Sockets.SocketException at System.Net.Sockets.Socket.EndSend (IAsyncResult result) <0x10b7bb30 + 0x0008b> in <filename unknown>:0 at MediaBrowser.Dlna.Ssdp.Datagram+<Send>c__AnonStorey0.<>m__0 (IAsyncResult result) <0x10b7b610 + 0x00027> in <filename unknown>:0 2016-08-30 12:22:58.5777 Error SsdpHandler: Error sending Datagram to 239.255.255.250:1900 from 127.0.0.1:0: NOTIFY * HTTP/1.1 . HOST: 239.255.255.250:1900 . CACHE-CONTROL: max-age = 600 . LOCATION: http://127.0.0.1:8096/dlna/a88351a89d11084d89af5baef10ce1d7/description.xml . SERVER: Unix32/15.5 UPnP/1.0 DLNADOC/1.5 Emby/3.0.6400.0 . NTS: ssdp:alive . NT: uuid:a88351a89d11084d89af5baef10ce1d7 . USN: uuid:a88351a89d11084d89af5baef10ce1d7 . . *** Error Report *** Version: 3.0.6400.0 Command line: /Applications/Emby.Server.Mac.app/Contents/MonoBundle/Emby.Server.Mac.exe /Applications/Emby.Server.Mac.app/Contents/MonoBundle/Emby.Server.Mac.exe Operating system: Unix 15.5.0.0 Processor count: 4 64-Bit OS: False 64-Bit Process: False Program data path: /Users/Jonz/.config/emby-server Mono: 4.4.2 (mono-4.4.0-branch-c7sr1/f72fe45) Application Path: /Applications/Emby.Server.Mac.app/Contents/MonoBundle/Emby.Server.Mac.exe The requested address is not valid in this context System.Net.Sockets.SocketException at System.Net.Sockets.Socket.EndSend (IAsyncResult result) <0x10b7bb30 + 0x0008b> in <filename unknown>:0 at MediaBrowser.Dlna.Ssdp.Datagram+<Send>c__AnonStorey0.<>m__0 (IAsyncResult result) <0x10b7b610 + 0x00027> in <filename unknown>:0 server-63608156506.txt Edited August 30, 2016 by Jonz
Jonz 11 Posted September 3, 2016 Author Posted September 3, 2016 Just to add to the above :- I noticed that i can play my movie files from the "Genre" folder. Means if i navigate with my TV to let say "Animation" folder, the file would play. However, it will timeout if i try to play it from "Movies" or "Latest". Any reason why this is happening?
