sh0rty 728 Posted August 1, 2016 Posted August 1, 2016 (edited) Coverart plugin treats source images with the same base size (e.g. landscape.jpg as thumb) somehow in different manor when choosing the rounded corner treatment. Affected are so kind of images when treated with rounded corners. Makes the screens look not uniform. @@ebr @@Luke BTW great enhancements on the uniform card optics in latest releases. Thanks for that! PS: latest dev, but happens for months now. Edited August 2, 2016 by shorty1483
ebr 16340 Posted August 2, 2016 Posted August 2, 2016 I've never seen this. Can anyone else reproduce?
Ernst 29 Posted August 2, 2016 Posted August 2, 2016 (edited) I can confirm this is the case. I use this treatment for music artists and see the same difference. I assume the rounding is applied before the image is resized, that would explain they end up not uniform. Just my two cents. As a matter of fact, I also use the treatment for actors and the same differences show. The larger the base image is, the smaller the rounded effect, hence my assumption the image is first rounded and then resized. Hope this helps Edited August 2, 2016 by Ernst 1
Happy2Play 9814 Posted August 2, 2016 Posted August 2, 2016 Not sure I follow. Please post server version also. Test from dev3.1.6058.1690 Is the screen shot in post 1 episodes thumbs vs series thumbs? Only issue is exposed corners again
sh0rty 728 Posted August 2, 2016 Author Posted August 2, 2016 Not sure I follow. Please post server version also. Test from dev3.1.6058.1690 Is the screen shot in post 1 episodes thumbs vs series thumbs? Only issue is exposed corners again First are episodes, second are series thumbs. But one if a kind are different treated. This is a problem long time existing, at least on my two servers. Gesendet von meinem HTC One M8 mit Tapatalk
Happy2Play 9814 Posted August 2, 2016 Posted August 2, 2016 I see what you are talking about now and it is all about aspect ratio. Enlarged image to show the difference 1047 X 1250 560 X 840
Happy2Play 9814 Posted August 2, 2016 Posted August 2, 2016 (edited) @@ebr here is another example with three different presentations of rounded (using People). Shows the same with or without "Use original art aspect ratio". 300 X 450 600 X 750 1000 X 1500 Image size is a factor 500x281 1000x562 Edited August 2, 2016 by Happy2Play 1
Luke 42251 Posted August 3, 2016 Posted August 3, 2016 Not sure I follow. Please post server version also. Test from dev3.1.6058.1690 Is the screen shot in post 1 episodes thumbs vs series thumbs? Only issue is exposed corners again In this screen it is not cover art's problem. the poster card layout is applying a background color. if this is undesirable, just switch to the regular poster view.
