abeklagsbrun@yahoo.com 0 Posted August 1, 2016 Posted August 1, 2016 Hi all, I have a particular problem with DTS soundtracks. My 2012 Panasonic Viera VT55 just doesn't support them. The question is, what to do with those files? Shouldn't Emby be automatically transcoding those audio streams to AC3 or AAC? There is no transcoding entry in the Panasonic Configuration profile for DTS. Could that be the issue? Please advise.
abeklagsbrun@yahoo.com 0 Posted August 1, 2016 Author Posted August 1, 2016 Hi, sorry. I have a large collection of .MKV files. About half have dts sound and about half have ac3 sound. Right now, I have to use That P word because it handles DTS tracks properly. I would raher be using Emby.
Happy2Play 9811 Posted August 1, 2016 Posted August 1, 2016 Hi all, I have a particular problem with DTS soundtracks. My 2012 Panasonic Viera VT55 just doesn't support them. The question is, what to do with those files? Shouldn't Emby be automatically transcoding those audio streams to AC3 or AAC? There is no transcoding entry in the Panasonic Configuration profile for DTS. Could that be the issue? Please advise. Since dca is under direct play, No. You would need to do is remove dca from mkv audio under direct play, then hit save to create a custom profile. This will force Emby to transcode all mkv files with dts to the preset option of ac3.
abeklagsbrun@yahoo.com 0 Posted August 1, 2016 Author Posted August 1, 2016 I tried removing DCA under direct play.Now DTS containing MKV files cause an unable to play file error from the TV.
Luke 42239 Posted August 1, 2016 Posted August 1, 2016 That is the correct thing to do though. it should cause transcoding. did it do that, did the server start transcoding the file? it's possible that more changes are needed as well if the transcoding format is still not compatible.
gyrene2083 1 Posted March 17, 2018 Posted March 17, 2018 (edited) [DISREGARD I FOUND OUT IT'S AN ISSUE WITH THE EMBY VERSION, ON MY SAMSUNG] Edited March 17, 2018 by gyrene2083
gyrene2083 1 Posted March 20, 2018 Posted March 20, 2018 @ Luke, I believe I worded it poorly, it wasn't the Emby Version on the Samsung, it was the version on my server. I was having similar issues as Scrubsss, which I responded to in (No titles in DLNA....)
