Suggestion for quicker way to add multiple folders to library
I'm just in the process of setting up a new Emby Server install on my brothers PC, he has multiple drives with multiple folders, it seems painfully slow to go through and select each folder individually going back and forth adding them, especially when you do what I did and clicked outside the Add Media Library  window and lost the lot :angry:
So could I make a suggestion that if you had a tree view of attached drives, you could expand each level and tick a check box for each drive/folder you wanted to add it would be a lot quicker.
Edited by Ronski
  • Like 2
Hi, yes that would be a good idea. Thanks.
  • Like 1
  • 5 years later...
Seems this one not implemented yet, this would be one of the greatest feature to manage different libraries like action , drama, comedy and actor based without creating duplicate files.
Choosing single path everytime is hell.
