jasonmcroy 320 Posted July 30, 2016 Posted July 30, 2016 In the live TV section settings we currently have optional record paths for Movies and Series Recording which I have set up to separate my recorded movies and shows. Could you add an option to set a recording path for Sports? It would be nice to have this in a separate folder from my regular TV Shows.
Guest asrequested Posted July 30, 2016 Posted July 30, 2016 In the live TV section settings we currently have optional record paths for Movies and Series Recording which I have set up to separate my recorded movies and shows. Could you add an option to set a recording path for Sports? It would be nice to have this in a separate folder from my regular TV Shows. If you set a default recording path and check create sub-folders, a sport folder will be created in the recordings folder/library.
jasonmcroy 320 Posted July 30, 2016 Author Posted July 30, 2016 Yes, I have played around with that. However, that creates those other folder as sub directories under the Recordings folder. I would prefer to have a more direct path like the existing TV Recordings and Movies path.
Guest asrequested Posted July 30, 2016 Posted July 30, 2016 Yes, I have played around with that. However, that creates those other folder as sub directories under the Recordings folder. I would prefer to have a more direct path like the existing TV Recordings and Movies path. We discussed all of those options when Luke was developing that. Sport came up a few times. http://emby.media/community/index.php?/topic/34419-recorded-tv-direction/
jasonmcroy 320 Posted July 30, 2016 Author Posted July 30, 2016 Yeah, I recall that thread. I just went through it again since you linked to it. I do remember trying it out the way it's set up now by checking the box to create the sub folders and it's not too bad of a way to handle what I am asking about. I think I am just too accustomed to having each type of media displayed by itself to click into.
