karnshome 0 Posted July 27, 2016 Posted July 27, 2016 Hey guys I am new to emby and would like to get a better understanding on how to install this on my current system. I am running on a DS212 on DSM 6. I am not able to find the appropriate mediainfo file in packages center. I am also not able to determine the correct ffmpeg and Emby file based on my CPU/architecture which is 88f6282(armv5) . Does the appropriate file exist for my nas or do I need to downgrade my DSM in order for it to work. Can anyone help me out?
Abobader 3485 Posted July 27, 2016 Posted July 27, 2016 Good day, At beta at the moment (for easy setup, and working very well indeed), but you can provide info if you want to be on it at: http://emby.media/community/index.php?/topic/34866-synology-package-in-development/ My best
Luke 42240 Posted July 28, 2016 Posted July 28, 2016 We have a new installation procedure for Synology users. It's very easy and is now on our website: http://emby.media/nas-server.html All Synology users are recommended to use this going forward (if your model supports it).
Solution solabc16 379 Posted September 10, 2016 Solution Posted September 10, 2016 Hello @@karnshomeThe Emby package for Marvell based systems is now available, see this post for more details: http://emby.media/community/index.php?/topic/22921-synology-setup/page-20&do=findComment&comment=365086Best- James
karnshome 0 Posted September 16, 2016 Author Posted September 16, 2016 thanks man, I got it installed and running
karnshome 0 Posted September 16, 2016 Author Posted September 16, 2016 guys so I got Emby installed on my server, but It is running so slow that I started yesterday afternoon to add my libraries and I am still attempting that at this time is this normal?
Happy2Play 9811 Posted September 17, 2016 Posted September 17, 2016 Depending on the size of your library, it can take awhile. Even on a machine with power a new library build can take more than a day.
shad0h 8 Posted September 25, 2016 Posted September 25, 2016 Internet speed may be a factor too, depending which options you chose for metadata lookup during the scan. If your internet is slow, each of those meta lookups / image downloads can take a while. Once it has finished the first scan, it should be much quicker on each of those tasks.
solabc16 379 Posted September 26, 2016 Posted September 26, 2016 Hello @@karnshome Just wanted to check-in how are you getting on. If you're not running release 3.0.7200, then you can update easily via Package Center. Feel free to send across your support logs and I can take a look at how your system is performing: https://github.com/MediaBrowser/Wiki/wiki/Synology-:-How-to-Send-us-Support-Logs - James
karnshome 0 Posted October 2, 2016 Author Posted October 2, 2016 guys well it has been a few weeks and my library is updated ,but even though emby is running i am unable to log im and get to my movies in the browser page. On my amazon fire all I am getting is server not available. Although I have the correct ip and port ? Any help would be great at this point. I am a bit disappointed
Luke 42240 Posted October 2, 2016 Posted October 2, 2016 Hi, when you try to login to the browser page what does it say?
solabc16 379 Posted October 2, 2016 Posted October 2, 2016 Hello @@karnshome Just wanted to check-in how are you getting on. If you're not running release 3.0.7200, then you can update easily via Package Center. Feel free to send across your support logs and I can take a look at how your system is performing: https://github.com/MediaBrowser/Wiki/wiki/Synology-:-How-to-Send-us-Support-Logs - James Hello @@karnshome Are you able to send your support logs across? Let me know if you need any assistance. - James
karnshome 0 Posted October 11, 2016 Author Posted October 11, 2016 I do not know how to send reports. I am very much a windows guy, Linux is very new to me. How do I send it ? Also the new update is out but my system does not show the update option.
solabc16 379 Posted October 11, 2016 Posted October 11, 2016 Hello @@karnshome The 3.0.7300 package for your platform was published yesterday, you should find that it is now available within Package Center. Instructions for sending the logs are on the Wiki here https://github.com/MediaBrowser/Wiki/wiki/Synology-:-How-to-Send-us-Support-Logs - James
