frumpl 5 Posted July 26, 2016 Posted July 26, 2016 So I noticed a few of my tv shows, not all, are showing multiple files for the same episode. Looking at the the metadata, one file is at: \\192.168.0.55\TV\.... the other is at \\UNRAID5\TV\.... This is the same location (ip address = computer name), so it is seeing the same file as 2 different files. My library is set to \\192.168.0.55\TV, so I'm not sure how it is using the computer name as a location. In the metadata for the series the path is correct (\\192.168...). The path to the season is not (\\UNRAID5\....). I can't edit the path, so I'm not sure how to fix it. I hope that's clear. Log attached. Thanks log.txt
Luke 42186 Posted July 26, 2016 Posted July 26, 2016 Hi, I would double check your library setup and make sure you don't have the same tv library added twice with two different paths.
frumpl 5 Posted July 26, 2016 Author Posted July 26, 2016 All my paths start with the IP address. I've never used the computer name for a path. And, it's only a 2 out of 89 shows in that path.
Happy2Play 9800 Posted July 26, 2016 Posted July 26, 2016 The database is pulling \\UNRAID5\TV path from something. Line 18031: 2016-07-26 08:58:38.8495 Info App: Deleting item from database Two Soldiers because path no longer exists. type: Episode path: \\UNRAID5\TV\Hell On Wheels\Season 5\Hell on Wheels.s05e08.Two Soldiers.WEBDL-480p.avi Line 18032: 2016-07-26 08:58:38.8963 Info App: Deleting item from database Chevrolet Camaro SS because path no longer exists. type: Episode path: \\UNRAID5\TV\MotorWeek\Season 29\MotorWeek.s29e06_R20160503_0428.mkv Line 18033: 2016-07-26 08:58:39.0526 Info App: Deleting item from database The Mattress because path no longer exists. type: Episode path: \\UNRAID5\TV\Brooklyn Nine-Nine\Season 3\Brooklyn Nine-Nine.s03e07.The Mattress.SDTV.mp4 Line 18034: 2016-07-26 08:58:39.4590 Info App: Deleting item from database Raw Deal because path no longer exists. type: Episode path: \\UNRAID5\TV\Deadliest Catch\Season 12\Deadliest Catch.s12e11.Raw Deal.SDTV.mkv Line 18035: 2016-07-26 08:58:39.4590 Info App: Deleting item from database Settling the Score because path no longer exists. type: Episode path: \\UNRAID5\TV\Deadliest Catch\Season 12\Deadliest Catch.s12e12.Settling the Score.HDTV-720p.mkv Line 18036: 2016-07-26 08:58:39.9902 Info App: Deleting item from database Wolfgang Puck because path no longer exists. type: Episode path: \\UNRAID5\TV\MasterChef\Season 7\MasterChef.s07e03_R20160618_0100.mkv Line 18077: 2016-07-26 08:59:06.3518 Info App: Deleting item from database Return to the Garden because path no longer exists. type: Episode path: \\UNRAID5\TV\Hell On Wheels\Season 5\Hell on Wheels.s05e09.Return to the Garden.SDTV.mkv Line 18078: 2016-07-26 08:59:06.3674 Info App: Deleting item from database A Mexican Mystery because path no longer exists. type: Episode path: \\UNRAID5\TV\MasterChef\Season 7\MasterChef.s07e05_R20160702_0100.mkv Line 18079: 2016-07-26 08:59:06.4611 Info App: Deleting item from database A MasterChef Wedding because path no longer exists. type: Episode path: \\UNRAID5\TV\MasterChef\Season 7\MasterChef.s07e04_R20160625_0100.mkv Line 18080: 2016-07-26 08:59:06.4924 Info App: Deleting item from database Gordon Ramsay Masterclass because path no longer exists. type: Episode path: \\UNRAID5\TV\MasterChef\Season 7\MasterChef.s07e06_R20160709_0100.mkv Line 18081: 2016-07-26 08:59:06.5705 Info App: Deleting item from database Fire at Sea (1) because path no longer exists. type: Episode path: \\UNRAID5\TV\Deadliest Catch\Season 12\Deadliest Catch.s12e13.Fire at Sea (1).SDTV.mkv Line 18082: 2016-07-26 08:59:06.8205 Info App: Deleting item from database Vets, Jets, and Home Cooks because path no longer exists. type: Episode path: \\UNRAID5\TV\MasterChef\Season 7\MasterChef.s07e07_R20160716_0100.mkv Line 18083: 2016-07-26 08:59:07.0080 Info App: Deleting item from database Pawning Pistols because path no longer exists. type: Episode path: \\UNRAID5\TV\Pawn Stars\Season 2016\Pawn Stars.s2016e12.Pawning Pistols.WEBDL-480p.mp4
frumpl 5 Posted July 27, 2016 Author Posted July 27, 2016 In the web interface and Kodi. In the web, the series and season appear once, but the episodes in the season appear twice. In Kodi, the series appears twice and inside each is the season and each episode. Those delete item lines appear several times, so it doesn't like look they are actually being removed from the database. And I have no idea how they would have got there in the first place. Web: Kodi:
Angelblue05 4132 Posted July 27, 2016 Posted July 27, 2016 Do you have cross-libraries? Meaning two libraries under emby dashboard > library that contain the same series or point to the same path? Sent from my iPhone using Tapatalk
nickyrat 2 Posted July 27, 2016 Posted July 27, 2016 I have this exact same issue, except the 2 paths are identical minus the letters being capitalized or not. \\familyroom versus \\FAMILYROOM. Only one TV series is affected.
Angelblue05 4132 Posted July 27, 2016 Posted July 27, 2016 What if you run a manual sync by launching the emby for kodi add-on. Does it remove the duplicates? Strange because nothing changed on our side as far as the syncing process goes. Sent from my iPhone using Tapatalk
nickyrat 2 Posted July 27, 2016 Posted July 27, 2016 I personally don't use kodi. My duplicates are showing up in the web interface, WMC and android app. I thought it was only happening for one TV show, but after looking into it last night it is happening to multiple TV series, but not all. I only have one path in the TV library. Pretty much identical to frumpl's issue, just with my own folder and server names. I just removed the TV path from my Emby and re added it, scanned library, but the issue is still there.
frumpl 5 Posted July 27, 2016 Author Posted July 27, 2016 Do you have cross-libraries? Meaning two libraries under emby dashboard > library that contain the same series or point to the same path? Sent from my iPhone using Tapatalk I don't think so. You can see my libraries in the pic in my second post. All libraries have 1 folder using the IP address. What if you run a manual sync by launching the emby for kodi add-on. Does it remove the duplicates? Strange because nothing changed on our side as far as the syncing process goes. No
frumpl 5 Posted July 27, 2016 Author Posted July 27, 2016 So, I thought once I watched those shows and deleted them, the issue would be gone. But, now I'm not so sure. It seems to be spreading. There are now 5 series that have this problem, up from 2 when I noticed it. For one series, it's only one season and not the other one. Also, another strange event. In my TV Kids library I had 2 folders. I deleted one (\\192.168.0.88\TV.Kids.Online$). I didn't delete the tv shows from the disk, I just wanted them out of my libraries. In the web interface, these episodes now show up in TV Streams library with a path of \\WIN8VM\TV.Kids.Online&\... The TV Streams' one and only folder is \\192.168.0.55\Streams\MyLibrary\TV Shows, which is an entirely different computer. I'll attach the current log. log.txt
nickyrat 2 Posted July 30, 2016 Posted July 30, 2016 I was pointed to this thread/answer and it worked for me. Delete the file, then run the media scanner manually. It will take awhile, but it did the trick for me! http://emby.media/community/index.php?/topic/35945-duplicate-episodes-from-sonarr/?p=338737
