scope99 7 Posted July 26, 2016 Posted July 26, 2016 Hello I have changed my notifications from Pushbullet to Pushover and pushover does not install properly. It is shown and can be configured in the general plugin area but the test fails and the plugin does not show under notifications/installed services. The same thing happened when I tried to install Pushalot.
Luke 42251 Posted July 26, 2016 Posted July 26, 2016 Tested, no problem found installing any of them. Please try again and if the issue persists, please provide the information requested in how to report a problem. Thanks.
scope99 7 Posted July 27, 2016 Author Posted July 27, 2016 Thanks Luke I did a bit more testing and got it to work. The only problem is Pushover and Pushalot, while accessible through the standard plugins area are not visible in the notifications / installed services area. Could just be a glitch in my long running emby server.
Luke 42251 Posted July 27, 2016 Posted July 27, 2016 I tried installing Pushover and then when I go to configure a notification, Pushover is there and available for use.
