Happy2Play 9800 Posted July 24, 2016 Posted July 24, 2016 (edited) If TMDB doesn't have an English rating for a movie why do I get a foreign rating? Can this be change to return no rating if there is no rating for selected country? Why would I want KR15 if I am from the US? Viewer shows the same as Metadata Manager Edited July 24, 2016 by Happy2Play
Luke 42186 Posted July 24, 2016 Posted July 24, 2016 You shouldn't, unless the english data is wrong on Tmdb, or unless it came from Omdb.
Happy2Play 9800 Posted July 24, 2016 Author Posted July 24, 2016 Sorry but omdb doesn't return a rating. It isn't a new issue, been like this for awhile. I know there is an old topic on this also.
Happy2Play 9800 Posted July 24, 2016 Author Posted July 24, 2016 Don't know if the json files will help. json.zip
Happy2Play 9800 Posted July 24, 2016 Author Posted July 24, 2016 (edited) Here is the url for this example. https://api.themoviedb.org/3/movie/307168?api_key=xxxxxxxxxxxxxxxxxxxxxx&append_to_response=casts,releases,images,keywords,trailers&language=English&include_image_language=English,null,en Edited July 24, 2016 by Happy2Play edited key
Solution Happy2Play 9800 Posted July 27, 2016 Author Solution Posted July 27, 2016 Thanks for the update in beta 3.1.78.0.
