claytonb 2 Posted July 24, 2016 Posted July 24, 2016 Sometimes while watching content it will stop like pause, exiting out of emby and back in is ok, also sometimes when I pause a episode and go back later and play I have no audio. And the main bitch I have is that when an episode as finished it doesn't forward to the next. Otherwise good work team..
ebr 16335 Posted July 24, 2016 Posted July 24, 2016 Sometimes while watching content it will stop like pause, exiting out of emby and back in is ok, also sometimes when I pause a episode and go back later and play I have no audio. We'll need to look at a specific example of that happening with this information: How to Report a Problem And the main bitch I have is that when an episode as finished it doesn't forward to the next. Did you turn on the option in playback settings to "Auto Queue Next Episode"...?
Michael K. 24 Posted July 31, 2016 Posted July 31, 2016 ...when an episode as finished it doesn't forward to the next. Did you turn on the option in playback settings to "Auto Queue Next Episode"...? I'm having this issue as well. I have the option enabled to Auto Queue Next Episode but it does not work. I hadn't found this thread yet, so I've already started a new thread here: http://emby.media/community/index.php?/topic/37464-auto-play-next-episode/?hl=%2Bqueue+%2Bnext+%2Bepisode&do=findComment&comment=351267
claytonb 2 Posted August 1, 2016 Author Posted August 1, 2016 Is "Auto Queue Next Episode"...? the same as "Auto Queue Episodes" if so the answer is no because I don't want them to continuous play, just queue to the next unwatched episode so I can press play when I'm ready to watch it.
