Spaceboy 2573 Posted July 31, 2016 Author Posted July 31, 2016 log attached i'm sure its path substitution, i've never really understood this that well. i have tried ip address my server is on a windows machine, media on a nas. on the server libraries are set up with unc paths no path substitution is used, kodi is on a shield pretty sure credentials are correct ta
Angelblue05 4132 Posted July 31, 2016 Posted July 31, 2016 How did you initiate playback in your last log (was it a library or a widget)?
Spaceboy 2573 Posted August 1, 2016 Author Posted August 1, 2016 How did you initiate playback in your last log (was it a library or a widget)? widget
Angelblue05 4132 Posted August 1, 2016 Posted August 1, 2016 Can you repeat the test from library instead? Post your Kodi log, because nothing was captured in the last one, thanks.
Spaceboy 2573 Posted August 1, 2016 Author Posted August 1, 2016 try this one also, can i recap on what was said about soundcloud music being imported or scanned? i'm still seeing location not found errors using the soundcloud api as the address and i'm not sure why. you said not to worry but these errors keep popping up. it also slows the initial scan down significantly. can music from emby plugins be excluded from the sync process?
Angelblue05 4132 Posted August 1, 2016 Posted August 1, 2016 (edited) Indeed - just go to the emby add-on settings > sync options > Disable Music. Soundcloud could be coming from the script skin helper. @@marcelveldt What the heck, there's nothing in your logs again. It doesn't even call the function as it should. Are you missing the Emby dependencies? How did you install Emby for Kodi, from the emby repository right? Can you validate by going to Kodi add-ons > My add-ons > All > Scroll to Emby and make sure you see 3 Emby dependencies and 1 Emby add-on. Let me know. If you are indeed missing the dependencies, please follow the steps here and reinstall Emby for Kodi: https://github.com/MediaBrowser/plugin.video.emby/wiki/Emby-Repository Edited August 1, 2016 by Angelblue05
Spaceboy 2573 Posted August 2, 2016 Author Posted August 2, 2016 yep 4 entries in the add on listing all with the emby logo and emby name but if i check the detail of each it says 3 are dependencies and one is the add on, all enabled. i'll try and pay some more media and catch it in the logs. but would you mind letting me know what path kodi on a nvidia shield will be able to access directly? what do i need to map my unc paths to in path substitution cheers
Angelblue05 4132 Posted August 2, 2016 Posted August 2, 2016 (edited) To find the end path you need to use, in Kodi settings > add-ons > install from zip > SMB > navigate to your content, the path will be displayed at the top. Note in Kodi it should display as smb://path/to/content but the emby equivalent will be (you'll want your path substitution to reflect this), note there's no "smb://" and they become backward slashes: \\path\to\content The client will take care of converting your path appropriately in your apps. Edited August 2, 2016 by Angelblue05
Spaceboy 2573 Posted August 2, 2016 Author Posted August 2, 2016 cheers, ok new log attached. i can see the playback request right at the end, its 11.22.63 - the rabbit hole
Angelblue05 4132 Posted August 2, 2016 Posted August 2, 2016 (edited) Ok, give me a few moments - something is wrong with the logging. I can't see the expected log lines to see where it's going wrong. I am also using 16.1 and I don't have this issue, btw. Playback works just fine. @@Spaceboy just out of curiosity, if you enable play from http in the add-on settings > playback tab, are you able to play content? Let me know. This could be due to the fact we don't fall back to http playback anymore.... hmm Edited August 2, 2016 by Angelblue05
Angelblue05 4132 Posted August 3, 2016 Posted August 3, 2016 @@Spaceboy Ok, I've fixed the logging - please check for updates in Kodi, you should receive an update for the emby dependencies. Then, grab a new log. It should work this time, thanks.
Spaceboy 2573 Posted August 3, 2016 Author Posted August 3, 2016 i'm pretty sure its that my nas isn't allowing non windows clients to connect. i can't navigate to the media folder through tryiong to add a source in kodi, i can see the server but if i try to go to a share then it tells me that the operation isnt permitted. when i was using kodi on a pi i had to set up nfs access i think, but i disabled it when i took them out. does this need re-enabling? ta 1
Angelblue05 4132 Posted August 3, 2016 Posted August 3, 2016 It's worth trying. I do agree with you tho, if you can't access it from Kodi then something is up with the share itself. Sent from my iPhone using Tapatalk
Spaceboy 2573 Posted August 6, 2016 Author Posted August 6, 2016 ok, i'm still no closer! what i have done: i was able to add a SMB network location for the nas using both the ip address and the server name and the credentials and i can navigate to subfolders so there is no issue with kodi or the shield accessing the nas. i created sources for both network locations as well but still nothing direct plays. even if i set the ip address in the network credentials for the emby add in the error message tells me its trying to direct play using the server name. that is about the only clue i have to what's going on here. do i need a path substitution from the unc paths used in the server libraries to the ip address? cheers
Spaceboy 2573 Posted August 7, 2016 Author Posted August 7, 2016 hi, one problem fixed, another has cropped up. i managed to get stuff to direct play. i did this by adding my own case sensitive share using the add sources bit of file manager, this way you can enter your network credentials. not having it capitalised was the final hurdle. so thats working but tday on the shield i am getting library sync failures, log attached cheers
