killride 47 Posted July 22, 2016 Posted July 22, 2016 Hello, I'm using Android MXQ Box with emby for kodi. And I'm using alternative device name to identify each boxs. As alternative name I put the mac address of the each box (then only the 3last digit change). On Emby server, I attempt to see each box on the Device Dashboard but only 2-3 of 15. And on the Dashboard it's the same problem with active devices, It seems stacked or something cause when 2 users or more are watching something at the same time, I've only one active device but the preview switch between the 2 streams. I hope I was clear enough.
killride 47 Posted July 22, 2016 Author Posted July 22, 2016 And I've seen another problem with that. It put watched status on the other account !!!
killride 47 Posted July 22, 2016 Author Posted July 22, 2016 For information, I use the same copy of kodi for each box and change the user and alternative device name maybe it's cause of that ?
killride 47 Posted July 22, 2016 Author Posted July 22, 2016 Ok my bad, you have to go to emby for kodi settings and make "generate new id device". Now it works properly 1
Angelblue05 4132 Posted July 22, 2016 Posted July 22, 2016 Indeed. If you copy the setup from one device to the other, you need to run that option. Glad you fixed it. Sent from my iPhone using Tapatalk
