dimmiemedia 3 Posted July 20, 2016 Posted July 20, 2016 (edited) Hi peepz, i have some struggles to organize my adult content... The Collections are not very usefull for this part. I share this with a couple of roommates, and i like to combine some movies with more episodes, with single movies (DVD's or single vids for example) The struggle with Collections is that every user is able to edit add and delete stuff to the Collections.. And if i use the mixed content option in the libary, than it's impossible to search on Studio or genre... (because the tab bar is missing then) Is there somebodey who can give me some usefull tips for this ? Thanks! D Edited July 20, 2016 by dimmiemedia
bfir3 117 Posted July 25, 2016 Posted July 25, 2016 I thought only admin users could modify collections? Also, you are concerned with being able to browse the library by Studio and Genre, but I don't think that is currently possible if the library contains mixed content.
Luke 42241 Posted July 26, 2016 Posted July 26, 2016 You could try movies and then using the movie extras feature: https://github.com/MediaBrowser/Wiki/wiki/Movie%20naming The only thing there is that it with the movie content type it will try to fetch internet metadata.
softworkz 5133 Posted July 26, 2016 Posted July 26, 2016 The current version of the ADE provider (adult metadata) works for movies, but the problem is that sometimes normal movies are identified as adult and vice versa, so I really hope that we will have a way to separate this, soon. Also, adult content should not be displayed as suggestions in normal movie libraries (we had a discussion on this previously)
