davedick 19 Posted July 18, 2016 Posted July 18, 2016 Hello, I had to do a Windows reinstall, thus reinstalled the latest stable release of Emby. When I went to the password tab to create a password, I only see Easy Pin Code. When I enter in a pin code & click on save, it shows a swirly circle & doesn't save. Did Emby move away from passwords to using pin codes? What would cause the pin code not to save? Thanks!
Luke 42186 Posted July 18, 2016 Posted July 18, 2016 Hi there, welcome. can you show us what you see, perhaps with a screenshot? You should always have the ability to set a password. 1
mjktg99 35 Posted July 19, 2016 Posted July 19, 2016 I was creating a new user the other day (Sunday) and I experienced a similar issue. The password field was completely missing. I had a pending upgrade so I installed and restarted and the password field came back. I am currently on 3.1.68.0 and this was probably about 2 releases ago that I had this issue.
