McChen 7 Posted July 18, 2016 Posted July 18, 2016 When watching Live TV, Emby for Android TV does not release the tuner when you stop the stream or change channels. This issue seems to be only with the Android TV version, the Android phone version of Emby does release the tuner properly. Even worse, somehow the reset tuner button in the Emby management interface seems to have disappeared so I can't manually release the tuner. These are the versions that I'm using: Emby for Android TV 1.2.24g Emby Server 3.0.5986.0 (Windows) ServerWMC Build 1225, assembly version 1.0.0.60 ServerWMC Emby Plugin 1.0.0.67
ebr 16337 Posted July 18, 2016 Posted July 18, 2016 I cannot reproduce this with the built-in TV provider. If you wait a bit, does the tuner finally release?
McChen 7 Posted July 18, 2016 Author Posted July 18, 2016 No, it never releases even after a couple hours. I have to go into the Windows desktop on the Emby Server and reset the tuner with the ServerWMC UI. Oddly enough, the Android phone version of the Emby client releases the tuner just fine, only the Android TV version has this bug. It also just cropped up recently, in the past couple weeks or so. Before that I never had this problem with the Android TV client.
McChen 7 Posted July 18, 2016 Author Posted July 18, 2016 it happens on both the nexus player and shield tv
ebr 16337 Posted July 18, 2016 Posted July 18, 2016 Okay, both Google devices so it will be easy for you to test a beta if we find something to try. Thanks.
McChen 7 Posted July 18, 2016 Author Posted July 18, 2016 Thanks, just let me know if there is something you want me to test
trhoffmanmd 0 Posted July 19, 2016 Posted July 19, 2016 I second this post. All specs are the same except using Emby for FireTV 1.2.24a. Of note, it did release before I set maximum stream bandwidth to 5Mbps, but that is the only way I can get live TV streamed. I hope this helps...
loganone 3 Posted July 20, 2016 Posted July 20, 2016 I am having the same issue with a Nexus Player. The app will not release the tuner, but if I use Kodi on the Nexus Player it will release.
ebr 16337 Posted July 20, 2016 Posted July 20, 2016 I am having the same issue with a Nexus Player. The app will not release the tuner, but if I use Kodi on the Nexus Player it will release. Also ServerWMC?
loganone 3 Posted July 20, 2016 Posted July 20, 2016 Also ServerWMC? yes, ServerWMC sorry, I should have included software These are the versions that I'm using: Emby for Android TV 1.2.24g Emby Server 3.0.5986.0 (Windows) ServerWMC Build 1225, assembly version 1.0.0.60 ServerWMC Emby Plugin 1.0.0.67
ebr 16337 Posted July 21, 2016 Posted July 21, 2016 Please try this with 1.2.26 and let me know if it is resolved. Thanks.
McChen 7 Posted July 21, 2016 Author Posted July 21, 2016 tried the 1.2.26 beta and still has the same problem
ebr 16337 Posted July 21, 2016 Posted July 21, 2016 tried the 1.2.26 beta and still has the same problem If that's the case then what is happening may not be what I thought it was and may be due to some other changes somewhere else. Can you please play some Live TV and then send the log from the app. Then come here and tell me when you did it and the Emby user that was logged in. Thanks.
hakras 5 Posted July 23, 2016 Posted July 23, 2016 I am seeing the same issue. For me, it seems to only be occurring with the HDHR Prime tuner. I have 1 HDHR Prime and 2 HDHR Connects. When I go to the Devices page in Live TV, the Prime tuners all say "watching" while the Connects say "available". I missed a recording this week due to this issue as well. If there is anything I can do to help troubleshoot, let me know.
ebr 16337 Posted July 23, 2016 Posted July 23, 2016 I am seeing the same issue. For me, it seems to only be occurring with the HDHR Prime tuner. I have 1 HDHR Prime and 2 HDHR Connects. When I go to the Devices page in Live TV, the Prime tuners all say "watching" while the Connects say "available". I missed a recording this week due to this issue as well. If there is anything I can do to help troubleshoot, let me know. And, again, with ServerWMC...? If the change I made to the app does not make a difference then this is most likely something at the server or serverwmc plug-in level. However, I would still like someone to do this with the latest beta: Can you please play some Live TV and then send the log from the app. Then come here and tell me when you did it and the Emby user that was logged in. Thanks.
hakras 5 Posted July 23, 2016 Posted July 23, 2016 I am using the Emby built-in TV components (no plugins). I rebooted my Prime and the tuners are now showing available.
lcasadonte 3 Posted July 25, 2016 Posted July 25, 2016 Was there ever any resolution to this? Running emby on a firetv same versions w/serverwmc and emby never releases the tuner. I have a second config with a firetv/prime and no serverwmc and it does appear to release the tuner properly.
ebr 16337 Posted July 26, 2016 Posted July 26, 2016 Was there ever any resolution to this? Running emby on a firetv same versions w/serverwmc and emby never releases the tuner. I have a second config with a firetv/prime and no serverwmc and it does appear to release the tuner properly. Still waiting for someone to do this: Can you please play some Live TV and then send the log from the app. Then come here and tell me when you did it and the Emby user that was logged in. Thanks.
McChen 7 Posted July 26, 2016 Author Posted July 26, 2016 I will get you a log soon, haven't been able to get around to it yet, sorry! I don't believe this is an issue with serverwmc or emby server because the emby web and emby for android phone clients all release the tuner properly, only the Android TV client doesn't
lcasadonte 3 Posted July 26, 2016 Posted July 26, 2016 There is a post today on a related topic indicating to try switching direct play on/off in the client and see if it changes the behavior. I will also look at trying to get the logs created and include a scenario/test where I change the direct play option. Thanks,
mit3gt 6 Posted July 28, 2016 Posted July 28, 2016 Still waiting for someone to do this: i just sent you a log. User is test. I tuned to channel WXYX. When I stopped watching the tuner was not released. I am also using serverwmc using a nexus player with direct play turned off.
ebr 16337 Posted July 29, 2016 Posted July 29, 2016 Unfortunately, I don't see your log. Did you get a confirmation pop-up that said the log was sent?
mit3gt 6 Posted July 29, 2016 Posted July 29, 2016 Unfortunately, I don't see your log. Did you get a confirmation pop-up that said the log was sent? Okay. I just sent another log. I did get a confirmation popup. User is test. I tuned to channel WXYX. When I stopped watching the tuner was not released. I am also using serverwmc using a nexus player with direct play turned off.
