bozrdnag 75 Posted July 31, 2016 Author Posted July 31, 2016 Without rereading this entire topic has anyone deleted library.db and allowed it to rebuild? I wonder with all the clean database update if something in the library.db has been corrupted? You asked that earlier in this thread and I replied that I did a fresh Emby install which would be a brand new library.db and I still have the problem.
bozrdnag 75 Posted July 31, 2016 Author Posted July 31, 2016 (edited) as a test, if you add a new series, does it happen with the new series? I just tired this by actually downloading the series Doctor Who. On my 3.0.5986.0 install season 1 showed but as I have added more seasons (up to 5 full seasons now) it still only shows season 1 and none of the others, but the green dot on the show thumb shows 65 episodes which is the correct number. They just aren't all visible. On my 3.1.6049.30327 install it would show each season as they were downloaded through season 4. And now that I have 5 full seasons, it is still only showing 4 even though it is also showing 65 episodes in the green indicator. So this is the first I've seen this whole new issue. Edited July 31, 2016 by bozrdnag
the1legend 45 Posted July 31, 2016 Posted July 31, 2016 I'm having the same issue on 3.1.83. I have been having this issue for the past few weeks but just started looking into it. I have a flat folder for each series. A show like 24, with 9 seasons, the web will show the seasons after 20 seconds. I found the same results browsing the meta data. Branching out from the series is will take about the same amount of time so it is an issue with the Emby server. On Emby theater the seasons will not show up even after three minutes. I was using a work-a-round by searching for the show but now search as taken a step backwards. I think it used to be maxed at thirty results but now search is only returning 8 results on the web, and seven (sorted by media type in Emby theater). I fully understand that I'm on a beta version of the software and things can break, but lately it seems like one step forward and two steps back. I'm a lifetime supporter of Emby and can appreciate the amount of work you are putting into this application. I see a beta product as something that is usable, but a work in progress, but at the moment this is not usable. Please work toward a resolution ASAP as I can not recommend Emby to anyone at this time.
bozrdnag 75 Posted July 31, 2016 Author Posted July 31, 2016 Not so new info than.. I was just happy to discover a way to use Emby to watch series again :-)The more info the better. I'm glad you brought it up again because the devs may have missed me mentioning that earlier too. Sent from my XT1585 using Tapatalk
omnilogix 0 Posted August 1, 2016 Posted August 1, 2016 (edited) I have recently added a new season to to a show, It does not display the new season poster on any app, but on Theater from XBox One, it shows "Next Up" properly so I can actually watch it in the proper order. Also the main show poster tag shows the correct number of unwatched episodes. In a browser the "Next Up" is not correct, it shows the first episode even though I have watched several Edited August 1, 2016 by omnilogix
iBoss 31 Posted August 1, 2016 Posted August 1, 2016 Please, any progress on this? do you need more log from me? Anyway, I'm using Anime plugin (AniDB metadata)
BinaryShrub 3 Posted August 1, 2016 Posted August 1, 2016 Seasons and Episodes are not showing up for me. I completely purged emby-server and did a fresh install with the latest on 16.04 LTS -- it's still broken. This is a huge bug, I essentially cannot watch any of my TV shows until this is fixed.
Luke 42287 Posted August 1, 2016 Posted August 1, 2016 Thanks for the report. It's being looked into.
iBoss 31 Posted August 1, 2016 Posted August 1, 2016 Thanks for the report. It's being looked into. Thanks
madjomack 0 Posted August 4, 2016 Posted August 4, 2016 Just recently I've noticed that my TV shows that don't have subfolders for seasons no longer work using the Roku or Web client. All of the shows appear in the Metadata. In Emby on Roku if i go to TV Library - Then Open a Show it then pops up No items to display This directory appears to be empty. I can search for the episode i want to play and it does play I just cannot navigate the tv show / seasons / episodes. I don't know which update they stopped working but it seems to be pretty recently. They all follow the normal naming of S01E01 and S01E02, S02E01 etc.
BinaryShrub 3 Posted August 4, 2016 Posted August 4, 2016 Is this fixed in 6030? I am waiting for it to be available via apt-get
Luke 42287 Posted August 4, 2016 Posted August 4, 2016 Is this fixed in 6030? I am waiting for it to be available via apt-get No, I am still trying to reproduce it. I was unable to see the problem with a fresh library. I have been given a copy of a database from another user so hopefully with that i'll be able to track it down.
bozrdnag 75 Posted August 4, 2016 Author Posted August 4, 2016 Well if you need anything else, post here. I'll provide whatever I can to help resolve this issue.
iBoss 31 Posted August 6, 2016 Posted August 6, 2016 No, I am still trying to reproduce it. I was unable to see the problem with a fresh library. I have been given a copy of a database from another user so hopefully with that i'll be able to track it down. If you need anything to help you, I'm happy to support. I can give you my server admin details if you want to see the issue and look at logs. (it has 740 episodes of TV shows)
Luke 42287 Posted August 6, 2016 Posted August 6, 2016 Try to refresh one of the affected series from the detail screen. That resolved it for another user.
iBoss 31 Posted August 6, 2016 Posted August 6, 2016 I have already tried to refresh but does not work. Actually I have one series with 740 eps Thanks
madjomack 0 Posted August 6, 2016 Posted August 6, 2016 (edited) As you can see below some of my shows have Season folders and some do not. The ones with season folders work correctly. The ones that don't do not (example 24). Also the show 112263 works but it only has one season and it does show in the web with season 1 and all the shows. Multi seasons in the root of the show folder do not work. E:\TV +---11.22.63 | 11.22.63.S01E01.mkv | 11.22.63.S01E02.mkv | 11.22.63.S01E03.mkv | 11.22.63.S01E04.mkv | +---2 Broke Girls | +---Season 2 | | 2.Broke.Girls.S02E01.mkv | | 2.Broke.Girls.S02E02.mkv | | 2.Broke.Girls.S02E03.mkv | | 2.Broke.Girls.S02E04.mkv | | 2.Broke.Girls.S02E05.mkv | | 2.Broke.Girls.S02E06.mkv | | 2.Broke.Girls.S02E07.mkv | | 2.Broke.Girls.S02E08.mkv | | 2.Broke.girls.S02E09.mkv | | 2.Broke.Girls.S02E10.mkv | | 2.Broke.Girls.S02E11.mkv | | 2.Broke.Girls.S02E12.mkv | | 2.Broke.Girls.S02E13.mkv | | 2.Broke.Girls.S02E14.mkv | | 2.Broke.Girls.S02E15.mkv | | 2.Broke.Girls.S02E16.mkv | | 2.Broke.Girls.S02E17.mkv | | 2.Broke.Girls.S02E18.mkv | | 2.Broke.Girls.S02E19.mkv | | 2.Broke.Girls.S02E20.mkv | | 2.Broke.Girls.S02E21.mkv | | 2.Broke.Girls.S02E22.mkv | | 2.Broke.Girls.S02E23.mkv | | 2.Broke.Girls.S02E24.mkv | | | +---Season 3 | | 2.Broke.Girls.S03E01.mkv | | 2.Broke.Girls.S03E02.mkv | | 2.Broke.Girls.S03E03.mkv | | 2.Broke.Girls.S03E04.mkv | | 2.Broke.Girls.S03E05.mkv | | 2.Broke.Girls.S03E06.mkv | | 2.Broke.Girls.S03E07.mkv | | 2.Broke.Girls.S03E08.mkv | | 2.Broke.Girls.S03E09.mkv | | 2.Broke.Girls.S03E10.mkv | | 2.Broke.Girls.S03E11.mkv | | 2.Broke.Girls.S03E12.mkv | | 2.Broke.Girls.S03E13.mkv | | 2.Broke.Girls.S03E14.mkv | | 2.Broke.Girls.S03E15.mkv | | 2.Broke.Girls.S03E16.mkv | | 2.Broke.Girls.S03E17.mkv | | 2.Broke.Girls.S03E18.mkv | | 2.Broke.Girls.S03E19.mkv | | 2.Broke.Girls.S03E20.mkv | | 2.Broke.Girls.S03E21.mkv | | 2.Broke.Girls.S03E22.mkv | | 2.Broke.Girls.S03E24.mkv | | | +---Season 4 | | 2.Broke.Girls.S04E01.mkv | | 2.Broke.Girls.S04E02.mkv | | 2.Broke.Girls.S04E03.mkv | | 2.Broke.Girls.S04E04.mkv | | 2.Broke.Girls.S04E05.mkv | | 2.Broke.Girls.S04E06.mkv | | 2.Broke.Girls.S04E07.mkv | | 2.Broke.Girls.S04E08.mkv | | 2.Broke.Girls.S04E09.mkv | | 2.Broke.Girls.S04E10.mkv | | 2.Broke.Girls.S04E11.mkv | | 2.Broke.Girls.S04E12.mkv | | 2.Broke.Girls.S04E13.mkv | | 2.Broke.Girls.S04E14.mkv | | 2.Broke.Girls.S04E15.mkv | | 2.Broke.Girls.S04E16.mkv | | 2.Broke.Girls.S04E17.mkv | | 2.Broke.Girls.S04E18.mkv | | 2.Broke.Girls.S04E19.mkv | | 2.Broke.Girls.S04E20.mkv | | 2.Broke.Girls.S04E21.mkv | | 2.Broke.Girls.S04E22.mkv | | | \---Season 5 | 2.Broke.Girls.S05E01.mkv | 2.Broke.Girls.S05E02.mkv | 2.Broke.Girls.S05E03.mkv | 2.Broke.Girls.S05E04.mkv | 2.Broke.Girls.S05E05.mkv | 2.Broke.Girls.S05E06.mkv | 2.Broke.Girls.S05E07.mkv | 2.Broke.Girls.S05E08.mkv | 2.Broke.Girls.S05E09.mkv | 2.Broke.Girls.S05E10.mkv | 2.Broke.Girls.S05E11.mkv | 2.Broke.Girls.S05E12.mkv | 2.Broke.Girls.S05E13.mkv | 2.Broke.Girls.S05E14.mkv | 2.Broke.Girls.S05E15.mkv | 2.Broke.Girls.S05E16.mkv | 2.Broke.Girls.S05E17.mkv | 2.Broke.Girls.S05E18.mkv | 2.Broke.Girls.S05E19.mkv | 2.Broke.Girls.S05E20.mkv | 2.Broke.Girls.S05E21.mkv | 2.Broke.Girls.S05E22.mkv | +---24 | 24.S00E09.mkv | 24.S01E01.mkv | 24.S01E02.mkv | 24.S01E03.mkv | 24.S01E04.mkv | 24.S01E05.mkv | 24.S01E06.mkv | 24.S01E07.mkv | 24.S01E08.mkv | 24.S01E09.mkv | 24.S01E10.mkv | 24.S01E11.mkv | 24.S01E12.mkv | 24.S01E13.mkv | 24.S01E14.mkv | 24.S01E15.mkv | 24.S01E16.mkv | 24.S01E17.mkv | 24.S01E18.mkv | 24.S01E19.mkv | 24.S01E20.mkv | 24.S01E21.mkv | 24.S01E22.mkv | 24.S01E23.mkv | 24.S01E24.mkv | 24.S02E01.mkv | 24.S02E02.mkv | 24.S02E03.mkv | 24.S02E04.mkv | 24.S02E05.mkv | 24.S02E06.mkv | 24.S02E07.mkv | 24.S02E08.mkv | 24.S02E09.mkv | 24.S02E10.mkv | 24.S02E11.mkv | 24.S02E12.mkv | 24.S02E13.mkv | 24.S02E14.mkv | 24.S02E15.mkv | 24.S02E16.mkv | 24.S02E17.mkv | 24.S02E18.mkv | 24.S02E19.mkv | 24.S02E20.mkv | 24.S02E21.mkv | 24.S02E22.mkv | 24.S02E23.mkv | 24.S02E24.mkv | 24.S03E01.mkv | 24.S03E02.mkv | 24.S03E03.mkv | 24.S03E04.mkv | 24.S03E05.mkv | 24.S03E06.mkv | 24.S03E07.mkv | 24.S03E08.mkv | 24.S03E09.mkv | 24.S03E10.mkv | 24.S03E11.mkv | 24.S03E12.mkv | 24.S03E13.mkv | 24.S03E14.mkv | 24.S03E15.mkv | 24.S03E16.mkv | 24.S03E17.mkv | 24.S03E18.mkv | 24.S03E19.mkv | 24.S03E20.mkv | 24.S03E21.mkv | 24.S03E22.mkv | 24.S03E23.mkv | 24.S03E24.mkv | 24.S04E01.mkv | 24.S04E02.mkv | 24.S04E03.mkv | 24.S04E04.mkv | 24.S04E05.mkv | 24.S04E06.mkv | 24.S04E07.mkv | 24.S04E08.mkv | 24.S04E09.mkv | 24.S04E10.mkv | 24.S04E11.mkv | 24.S04E12.mkv | 24.S04E13.mkv | 24.S04E14.mkv | 24.S04E15.mkv | 24.S04E16.mkv | 24.S04E17.mkv | 24.S04E18.mkv | 24.S04E19.mkv | 24.S04E20.mkv | 24.S04E21.mkv | 24.S04E22.mkv | 24.S04E23.mkv | 24.S04E24.mkv | 24.S05E01.mkv | 24.S05E02.mkv | 24.S05E03.mkv | 24.S05E04.mkv | 24.S05E05.mkv | 24.S05E06.mkv | 24.S05E07.mkv | 24.S05E08.mkv | 24.S05E09.mkv | 24.S05E10.mkv | 24.S05E11.mkv | 24.S05E12.mkv | 24.S05E13.mkv | 24.S05E14.mkv | 24.S05E15.mkv | 24.S05E16.mkv | 24.S05E17.mkv | 24.S05E18.mkv | 24.S05E19.mkv | 24.S05E20.mkv | 24.S05E21.mkv | 24.S05E22.mkv | 24.S05E23.mkv | 24.S05E24.mkv | 24.S06E01.mkv | 24.S06E02.mkv | 24.S06E03.mkv | 24.S06E04.mkv | 24.S06E05.mkv | 24.S06E06.mkv | 24.S06E07.mkv | 24.S06E08.mkv | 24.S06E09.mkv | 24.S06E10.mkv | 24.S06E11.mkv | 24.S06E12.mkv | 24.S06E13.mkv | 24.S06E14.mkv | 24.S06E15.mkv | 24.S06E16.mkv | 24.S06E17.mkv | 24.S06E18.mkv | 24.S06E19.mkv | 24.S06E20.mkv | 24.S06E21.mkv | 24.S06E22.mkv | 24.S06E23.mkv | 24.S06E24.mkv | 24.S07E00.mkv | 24.S07E01.mkv | 24.S07E02.mkv | 24.S07E03.mkv | 24.S07E04.mkv | 24.S07E05.mkv | 24.S07E06.mkv | 24.S07E07.mkv | 24.S07E08.mkv | 24.S07E09.mkv | 24.S07E10.mkv | 24.S07E11.mkv | 24.S07E12.mkv | 24.S07E13.mkv | 24.S07E14.mkv | 24.S07E15.mkv | 24.S07E16.mkv | 24.S07E17.mkv | 24.S07E18.mkv | 24.S07E19.mkv | 24.S07E20.mkv | 24.S07E21.mkv | 24.S07E22.mkv | 24.S07E23.mkv | 24.S07E24.mkv | 24.S08E01.mkv | 24.S08E02.mkv | 24.S08E03.mkv | 24.S08E04.mkv | 24.S08E05.mkv | 24.S08E06.mkv | 24.S08E07.mkv | 24.S08E08.mkv | 24.S08E09.mkv | 24.S08E10.mkv | 24.S08E11.mkv | 24.S08E12.mkv | 24.S08E13.mkv | 24.S08E14.mkv | 24.S08E15.mkv | 24.S08E16.mkv | 24.S08E17.mkv | 24.S08E18.mkv | 24.S08E19.mkv | 24.S08E20.mkv | 24.S08E21.mkv | 24.S08E22.mkv | 24.S08E23.mkv | 24.S08E24.mkv | 24.S09E01.mkv | 24.S09E02.mkv | 24.S09E03.mkv | 24.S09E04.mkv | 24.S09E05.mkv | 24.S09E06.mkv | 24.S09E07.mkv | 24.S09E08.mkv | 24.S09E09.mkv | 24.S09E10.mkv | 24.S09E11.mkv | 24.S09E12.mkv | +---A to Z | A.to.Z.S01E01.mkv | A.to.Z.S01E02.mkv | A.to.Z.S01E03.mkv | A.to.Z.S01E04.mkv | A.to.Z.S01E05.mkv | A.to.Z.S01E06.mkv | A.to.Z.S01E07.mkv | A.to.Z.S01E08.mkv | A.to.Z.S01E09.mkv | A.to.Z.S01E10.mkv | A.to.Z.S01E11.mkv | +---Allegiance | Allegiance.S01E01.mkv | Allegiance.S01E02.mkv | Allegiance.S01E03.mkv | Allegiance.S01E04.mkv | Allegiance.S01E05.mkv | Allegiance.S01E06.mkv | Allegiance.S01E07.mkv | Allegiance.S01E08.mkv | Allegiance.S01E09.mkv | Allegiance.S01E10.mkv | Allegiance.S01E11.mkv | Allegiance.S01E12.mkv | Allegiance.S01E13.mkv | +---Almost Human | \---Season 1 | Almost.Human.S01E01.mkv | Almost.Human.S01E02.mkv | Almost.Human.S01E03.mkv | Almost.Human.S01E04.mkv | Almost.Human.S01E05.mkv | Almost.Human.S01E06.mkv | Almost.Human.S01E07.mkv | Almost.Human.S01E08.mkv | Almost.Human.S01E09.mkv | Almost.Human.S01E10.mkv | Almost.Human.S01E11.mkv | Almost.Human.S01E12.mkv | Almost.Human.S01E13.mkv Edited August 6, 2016 by madjomack
madjomack 0 Posted August 6, 2016 Posted August 6, 2016 You can close or merge this. Sorry I just not saw this post which looks to be the same issue. http://emby.media/community/index.php?/topic/36966-majority-of-tv-shows-not-showing-seasons-or-episodes/
bozrdnag 75 Posted August 6, 2016 Author Posted August 6, 2016 Refresh does not work for me either. Sent from my XT1585 using Tapatalk
bozrdnag 75 Posted August 6, 2016 Author Posted August 6, 2016 (edited) Luke - were you able to replicate the issue with the db the other user sent you? Sent from my XT1585 using Tapatalk Edited August 6, 2016 by bozrdnag
Luke 42287 Posted August 6, 2016 Posted August 6, 2016 Yes and the issue with the db that the user sent me could be rectified by refreshing the individual series from the series detail screen.
bozrdnag 75 Posted August 9, 2016 Author Posted August 9, 2016 (edited) Yes and the issue with the db that the user sent me could be rectified by refreshing the individual series from the series detail screen. Well here's a OneDrive link to mine (it's greater the 10MB). Maybe it will help shed some light. https://1drv.ms/u/s!AjVnhushK5Vl0WF4vUT-12INntb0 Edited August 9, 2016 by bozrdnag
simoesj 0 Posted August 10, 2016 Posted August 10, 2016 I found this issue to happen on shows that i have more then 4 seasons of. Refreshing does not fix it for me.
omnilogix 0 Posted August 10, 2016 Posted August 10, 2016 Refreshing the detail from the browser UI resolved the issue in my browser, but Media Center is still a problem:
