bozrdnag 75 Posted July 19, 2016 Author Posted July 19, 2016 I will try that when I get home later but I can say that the more recently added series work just fine on both my installs. I added three new series over the weekend and they show seasons and episodes just fine. On another note, I have also noted that while seasons (and therefore episodes) don't show on many Shows, I am able to press the green play button and both play and shuffle work. So I am assuming the library sees all the episodes and that it's just a season problem.
bozrdnag 75 Posted July 21, 2016 Author Posted July 21, 2016 (edited) I just added two episodes of a new show (video files only) and Emby picked it up and it shows season 1 with two episodes just fine. The more I go through my library the ones that seem to work fine seems to have 4 seasons or less and it doesn't seem to matter if it's a show I recently acquired or one I've had for many years. I can;t seem to find any shows with more than 4 season that works right. I did notice that one time I entered a show with no seasons showing and left the computer like that and I returned an hour later and they were then showing. I browsed around Emby and then cam back to the show and they were not showing again. Not sure if that helps at all but this gets weirder the more I play with it. Edited July 21, 2016 by bozrdnag
Happy2Play 9814 Posted July 21, 2016 Posted July 21, 2016 I did notice that one time I entered a show with no seasons showing and left the computer like that and I returned an hour later and they were then showing. I browsed around Emby and then cam back to the show and they were not showing again. Not sure if that helps at all but this gets weirder the more I play with it. You would need to post a log of this. Since you appear to be having issues with existing series, have you tried removing the series that are having issues, performing a Clean database, then Library Scan, add the series back, then another library scan? Last resort delete your library.db and let it rebuild. Added Doctor Who (2005) with random episodes from 9 season and everything appears.
bozrdnag 75 Posted July 21, 2016 Author Posted July 21, 2016 Remember, I created an entirely fresh install of Emby and scanned the library from scratch. Wouldn't that be the equivalent or even better than what you're saying to do?
Happy2Play 9814 Posted July 21, 2016 Posted July 21, 2016 Yes, that would be the same as a new install. This has to be something to do with Non-Windows builds since you are not the only one having this issue on Non-Windows server.
Happy2Play 9814 Posted July 21, 2016 Posted July 21, 2016 But is also sound like the same issue here, if they do eventually appear.
Happy2Play 9814 Posted July 21, 2016 Posted July 21, 2016 Do all the season show up in Metadata Manager?
bozrdnag 75 Posted July 21, 2016 Author Posted July 21, 2016 No. The problem shows just show loading. Again, if you leave it sit some will eventually show seasons. Sent from my XT1585 using Tapatalk
bozrdnag 75 Posted July 21, 2016 Author Posted July 21, 2016 Is there I version thats known to work then? This a bit of a serious issue since it renders most of my shows unwatchable. Sent from my XT1585 using Tapatalk
Happy2Play 9814 Posted July 21, 2016 Posted July 21, 2016 The only person that can answer that is you since Stable, Beta, and Dev are known to work for me. Best guess previous stable 3.0.5972.0.
Luke 42287 Posted July 21, 2016 Posted July 21, 2016 If it works for you with the same directory structure then maybe he could try zipping up his nfo files and you could replace yours with his as a test?
llygoden 6 Posted July 22, 2016 Posted July 22, 2016 I seem to be having the same issue. I use the FreeNAS plugin so the server is running on FreeBSD. The only things I can think that have changed that may have caused this issue are: - Updating Emby to the latest stable version - Taking the option to have Sonarr create my NFO files in the Kodi format.
omnilogix 0 Posted July 22, 2016 Posted July 22, 2016 I am having this issue also on a Windows server. So far, only one series has disappeared (Doctor Who 2005). It has been missing several days despite database cleanings. This series has been on my server for several years. Problem seemed to start after recent server update Running server Version 3.0.5986.0
bozrdnag 75 Posted July 22, 2016 Author Posted July 22, 2016 The only person that can answer that is you since Stable, Beta, and Dev are known to work for me. Best guess previous stable 3.0.5972.0. Anyone know how to get that version in a Docker container? I'll happily send my NFO files if you think that will help. Which ones do you want? I tried getting rid of all my NFO files for the show Seinfeld (which is a problem show), removing the TV Show share under Library, cleaned db, re-added share and scanned library and it still acts the same. So even with info files created by Emby and no others, it still doesn't work. Back to my theory on number of seasons worsening the issue, Seinfeld with 9 season takes ~3 minutes for the seasons to appear. Law & Order with 18 seasons took 13 minutes for them to appear.
bozrdnag 75 Posted July 22, 2016 Author Posted July 22, 2016 (edited) I am having this issue also on a Windows server. So far, only one series has disappeared (Doctor Who 2005). It has been missing several days despite database cleanings. This series has been on my server for several years. Problem seemed to start after recent server update Running server Version 3.0.5986.0 Can you try leaving it sit at that screen for a while and seeing if the seasons appear after a while. Mine do. Edited July 22, 2016 by bozrdnag
omnilogix 0 Posted July 23, 2016 Posted July 23, 2016 Thanks bozrdnag, I tried leaving on that screen in Chrome and it showed after several minutes, Edge browser took a few more. Never did come up in my iOS app, and freezes trying to get to this screen in the Media Browser edition (xbox 360). Any thoughts on the getting my non browser displays working again? I primarily watch using Emby for Media Center (Waiting patiently for Xbox One native app)
ebr 16354 Posted July 23, 2016 Posted July 23, 2016 Waiting patiently for Xbox One native app Have you tried Emby Theater on it lately...?
omnilogix 0 Posted July 23, 2016 Posted July 23, 2016 I have, but I much prefer the MB edition. It feels like I am working too hard to do something simple with Theater on XBONE
bozrdnag 75 Posted July 23, 2016 Author Posted July 23, 2016 So is there a developer or admin who has been able to duplicate this issue? There seems to be a lot of us with this issue and I am just wondering if this an acknowledged issue that is actively being worked on or if the poewrs that be aren't seeing the same issue.
Luke 42287 Posted July 23, 2016 Posted July 23, 2016 It's being looked into for a future release. Thanks. 1
omnilogix 0 Posted July 23, 2016 Posted July 23, 2016 Have you tried Emby Theater on it lately...? ebr, Had another look at Theater on XBOX ONE. It is much improved over what I looked at months ago, but still is lacking as a suitable replacement for Media Center Emby for the following reasons 1) Media Center launches auto on my Xbox 360, +1 for wife approval. Theater needs go to edge->login... etc. If I have used Edge for other than Theater, nobody else in my household can figure out how to get back to Theater. 2) Media Center is usually responsive, Theater is quite laggy for many activities. Not sure why. I have Gigabit wired Lan + fast Wan. My iPhone app non-wifi usually performs better than Theater By the way, I have been "with" Emby since early Media Browser. Love what you guys are doing, and prefer it over the alternatives regardless of feature set. Kudos...
bozrdnag 75 Posted July 24, 2016 Author Posted July 24, 2016 (edited) This has to be something to do with Non-Windows builds since you are not the only one having this issue on Non-Windows server. I just tried a Windows install of Emby Server 3.1.77.0 Beta and it is doing the exact same thing. The same shows initially show no seasons upon opening the series in the Web GUI but they eventually appear after a while. So, at least for me, this is not relegated to non-Windows installs. EDIT: I've also noticed that the seasons never seems to show up on Emby Theater. It seems like they are either there or not. Whereas on the Web GUI they do eventually show up. Edited July 24, 2016 by bozrdnag
Happy2Play 9814 Posted July 24, 2016 Posted July 24, 2016 Only other thing I can think of is how are your libraries paths setup? All my data is local - on the same machine. I tested with a remote Windows share and didn't have any issues either with series with no season folders.
bozrdnag 75 Posted July 24, 2016 Author Posted July 24, 2016 (edited) All my media is stored on an UNRAID server. If you are not familiar with it, it is like a NAS and is Linux based. So my paths are //Server/TV Show/Seinfeld/Seinfeld - s01e04 - Soup Nazi - DVD Rip.mkv Sent from my XT1585 using Tapatalk Edited July 24, 2016 by bozrdnag
