djlf 40 Posted July 16, 2016 Posted July 16, 2016 Running latest theatre but DVDs and mpeg files will no longer go to full screen . H264 and blurays play fine. Any ideas??
Guest asrequested Posted July 16, 2016 Posted July 16, 2016 (edited) Can you post a screen shot? And the media info for the files....folder rips? Converted files? What container? etc.... Edited July 16, 2016 by Doofus
djlf 40 Posted July 16, 2016 Author Posted July 16, 2016 Mpegs and DVDs letterboxed. Changed settings from edged to stable but made no difference. Running 2.5.2 .
Guest asrequested Posted July 16, 2016 Posted July 16, 2016 Mpegs and DVDs letterboxed. Changed settings from edged to stable but made no difference. Running 2.5.2 . That doesn't help. We need detailed information of the file or maybe you can give us access to a sample of the file. Is this a folder rip or did you convert it to MKV, MP4 etc? This will help to provide the details, if you need help with that: https://mediaarea.net/en/MediaInfo
AdrianW 1058 Posted July 16, 2016 Posted July 16, 2016 (edited) Go into Settings > Video and change the Video Renderer to "MadVR". I just tested it and the old letterbox issue with EVR is happening again with anamorphic videos. Here's the video details of one that has the issue: Video ID : 1 Format : AVC Format/Info : Advanced Video Codec Format profile : High@L3 Format settings, CABAC : Yes Format settings, ReFrames : 5 frames Codec ID : V_MPEG4/ISO/AVC Duration : 1 h 53 min Nominal bit rate : 1 400 kb/s Width : 720 pixels Height : 572 pixels Display aspect ratio : 16:9 Frame rate mode : Constant Frame rate : 25.000 FPS Color space : YUV Chroma subsampling : 4:2:0 Bit depth : 8 bits Scan type : Progressive Bits/(Pixel*Frame) : 0.136 Title : Happy Go Lucky Writing library : x264 core 80 r1376M 3feaec2 Encoding settings : cabac=1 / ref=5 / deblock=1:0:0 / analyse=0x3:0x113 / me=umh / subme=8 / psy=1 / psy_rd=1.0:0.0 / mixed_ref=1 / me_range=16 / chroma_me=1 / trellis=1 / 8x8dct=1 / cqm=0 / deadzone=21,11 / fast_pskip=1 / chroma_qp_offset=-2 / threads=3 / sliced_threads=0 / nr=0 / decimate=1 / mbaff=0 / constrained_intra=0 / bframes=3 / b_pyramid=0 / b_adapt=2 / b_bias=0 / direct=3 / wpredb=1 / wpredp=2 / keyint=250 / keyint_min=25 / scenecut=40 / rc_lookahead=50 / rc=2pass / mbtree=1 / bitrate=1400 / ratetol=1.0 / qcomp=0.60 / qpmin=10 / qpmax=51 / qpstep=4 / cplxblur=20.0 / qblur=0.5 / ip_ratio=1.40 / aq=1:1.00 Language : English Default : Yes Forced : No Edited July 16, 2016 by AdrianW 3
djlf 40 Posted July 16, 2016 Author Posted July 16, 2016 Yeah cheers for that. Changing to madvr did the trick alright
beeker 0 Posted August 22, 2016 Posted August 22, 2016 Thanks for that. I was having the same problem with anamorphic videos, and changing to madvr now shows them in full screen again.
Luke 42243 Posted January 1, 2017 Posted January 1, 2017 Please try this version with EVR and let me know if the scaling issue is resolved: https://www.dropbox.com/s/qfkyvfqj5l2ibe3/et.zip?dl=0 Just unzip it to any folder and test it out portable. thanks,.
